11-14-2013, 10:44 PM | #15391 |
Ahhhhhh you hammered down the edges that were sticking out to sit the wiring lower! At least that's what it looks like and am planning to do that now. Thanks so much for the pictures! Definitely helped.
11-15-2013, 06:32 AM | #15392 | |
Start the engine, and let it run to 2500rpm to set everything and seat the rings. Adjust tuning either on or off dyno and run no more than 4k (On a dyno 5 pulls is broken in). Tune it, run the piss out of to see what final adjustments it needs, change the oil, drive it like ya stole it
11-15-2013, 01:19 PM | #15393 |
clutch master cylinder ?
have a brand new OEM clutch slave cyl ,and a slightly older autozone master ..
everything is bleed (no damper) .but i am getting clutch creep "car wants to creep forward" and is a bear to get into gear. my thoughts are that the autozone is craptastic and not OEM,and that i am getting a fluid bypass internally in the master ,due to the new slave is giving the master alot more resistance . is this a possibility? should i buy a OEM $100 master?
11-15-2013, 01:39 PM | #15395 |
My gauge cluster were all working when I turned the car on and then I turn it off it clicked and no power to the cluster. The fuses in the cab are all good, but I check the fuses on the battery side and the alt fuse is broken. What to know if this happen to anyone with a ka24de swap?
Sent from my SGH-M919 using Tapatalk
Love her like ya bitch and i aint talkin about ya girl |
11-15-2013, 02:43 PM | #15397 |
yeaaaah,. if you dnt have any leaks or pinched lines along the way, i would assume the master has to be the culprit
cONtRol FReAkS |
11-16-2013, 12:01 AM | #15398 | |||||
Trader Rating: (58)
Feedback Score: 58 reviews
The VatoZone stuff simplydoesn't work. Quote:
WIth that said don't forget studs and lugnuts. Quote:
Any quality lube will do. Well, for engines that is. I like the sticky lucas stuff, but have thrown stuff together with the cheapest moly lube and had no issues either. Just make sure you crnak until you get oil pressure.
11-16-2013, 12:05 AM | #15400 | |
Lol. As long as it is 25 years old, down to the exact month it was manufactured I believe, you can. Check out Nostalgia Imports; maybe they can help you out: https://www.facebook.com/NostalgiaImports |
11-16-2013, 12:28 AM | #15401 |
yeah i am stationed here and leave to my next duty station this dec.
i would have liked to ship one but if down to the exact month that might not work out for me. i will check out the page. thanks. |
11-16-2013, 12:31 AM | #15402 |
Ahhh okay. Enjoy Japan while it lasts. I have a friend who is stationed there as well right now, until December too, I believe. Thanks for your service, and good luck!
11-16-2013, 12:28 PM | #15403 |
Didn't hammer anything lol, it's sitting on top of the seam. Just don't put it too high and it won't touch anything.
11-16-2013, 01:35 PM | #15404 |
Wha-? I swear I tried putting it at the lowest point I could above the seam...it looks like my tube of wires is abnormally larger than your tube of wires...I'll have to take a look at it again and make the necessary adjustments. Thanks again.
11-16-2013, 03:18 PM | #15405 |
Maybe try to ziptie it in place and flatten it with a hammer.... I dunno, it's not even close to touching my fender.
11-16-2013, 08:45 PM | #15406 |
Does anybody know the part number for OEM kouki side skirt clips? Some of mine are broken and I'd like to replace them all so that my skirt fits properly. I don't want to do a cheap zip-tie or double sided tape repair. I have already searched these boards and nissanparts.cc with no luck - only found a bunch of WTB threads.
Edit: Some more digging has found me the information. Courtesy Parts has the clips and grommets: http://www.courtesyparts.com/76897ea...-p-138694.html http://www.courtesyparts.com/76500j-...8-p-18144.html
2006 Holden Monaro - 700+whp ; 2014 Holden Commodore SSV - 400whp |
11-17-2013, 08:18 AM | #15407 | |
Current legal GTR is R31, R32 is 2014, R33 is 2015(JOY! I wanna GTR, I wanna Nismo 400R!) but seriously, it's freakin cold, wet, and rainy now. I would settle for having my car back from the body shop with it's new shiny BMW high aluminum content Gunmetal Grey
11-18-2013, 01:07 AM | #15408 |
how come i cant post in the "scammers" thread?
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
11-18-2013, 11:14 AM | #15409 |
Bandwagon.
thats a question for the mods, not here lol
11-18-2013, 12:08 PM | #15410 |
So i recently bought a new upper harness for my 95 manual zenki. The harness i bought is for an 97 auto kouki. I know that im going to have extra connectors, but the only one im worried about is the o2 sensor. The harness has 3 wires to a connector and my o2 sensor only has a single signal wire. Is it possible to splice directly into the signal wire on the new harness? Im goin to be using my stock zenki ecu so just buying a 3 wire o2 sensor wouldnt work.
11-18-2013, 01:27 PM | #15411 | |
AFC #1
11-18-2013, 07:10 PM | #15412 |
what are the best rear speakers for a hatch? i searched and everyone says to go 6.5s but i dont really wanna deal with having to cut stuff out just to fit them.
11-18-2013, 09:37 PM | #15413 |
Bandwagon.
anyone know the measurement from driver to passenger side quarter panel in inches?
Trying to find out if my wing is wider than my car. |
11-19-2013, 06:08 AM | #15414 |
Stock S14 spoiler is 54". That help?
11-19-2013, 05:03 PM | #15417 | |
Trader Rating: (58)
If push comes to shove take the 4 allen headed bolts off, and then get it in a vise and use a chisel/hammer to 'walk it off'. You may be able to do it in car too but ya never know.
11-19-2013, 07:27 PM | #15418 |
Yeah, the tool I have can't be taken to the base as it is a socket. I'll see if I can get another type of tool. I did indeed rip it mostly to shreds with the screwdriver, thanks for the advice. I think after this I'm going to invest in an oil filter relocation kit lol.
11-19-2013, 08:03 PM | #15419 |
s13 headlights
I have an s13 and i jsut got it, it is my dream car, but with the head lights, with the switch when i turn them off only the right side goes down, whenm i put the left down Manuely and then turn them on it comes up but doesnt go down? has anyone else had this problem or anyone know how to fix it?
11-19-2013, 09:08 PM | #15420 | |
Trader Rating: (58)
Just remember there are two o rings behind that oil filter block where it goes into the block, they are special to that applcation, so don't drop them. If they get ruined, you can get them at your local dealer as they are the same o ring used n the VQ front covers
