Old 04-10-2017, 01:20 PM   #121
bardabe
bardabe's Avatar
Originally Posted by Vatche View Post
Bardabe, we have 4 classes now. Last year was just 3.
sweet! I have updates on my car so hoping to shake down over the summer!
Review Thread
bardabe is offline   Reply With Quote
Old 04-21-2017, 04:26 AM   #122
Marphie21
Marphie21 is an unknown quantity at this point
Any more updates?
BTW, what did you use for the rubber that seals the gap between the splitter and the bottom of the front bumper?
Marphie21 is offline   Reply With Quote
Old 04-21-2017, 04:46 PM   #123
battery1882
battery1882's Avatar
battery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enough
Originally Posted by Marphie21 View Post
Any more updates?
Hey Marphie,
That is ebay rubber lip. I wouldn't recommend it if you are using it for high speed as it will deform under high speeds.
Just picked up the head.. got busy weekend ahead.
battery1882 is offline   Reply With Quote
Old 04-22-2017, 05:46 PM   #124
UG-T
UG-T is an unknown quantity at this point
Love the build
Thought you may want to look into this
https://www.rhdjapan.com/jun-high-fl...ctric-fan.html
UG-T is offline   Reply With Quote
Old 05-01-2017, 03:00 PM   #125
battery1882
Originally Posted by UG-T View Post
Love the build
Thank you! e-pump would be cool!
Almost done with putting the engine back in. some wiring to do for the new injectors/ rearrange intercooler pipe, etc.
Next event is on 5/13 so gotta get moving to finish and have it tuned. will report back!
Old 05-04-2017, 09:50 AM   #126
koukimonst3r
koukimonst3r's Avatar
koukimonst3r is an unknown quantity at this point
Originally Posted by battery1882 View Post
Pulled head and found that #1/#4 pistons are slightly melted around the edges. This is probably from extreme exhaust temperature..
This is what I'm afraid of, finally gonna get a compression test after owning my s14 sr for 4 years
ig : koukimonst3r
koukimonst3r is offline   Reply With Quote
Old 05-08-2017, 10:33 AM   #127
battery1882
Haha. Yeah I do compression test pretty often. Matter of fact, I just performed one after putting everything back in. 150psi on all 4 so I'm relieved
completed everything
went back to Koji for another session; I guess this is what proper dyno numbers look like on 2871r .86.
It's hard to see but first set of graphs is high boost (19psi) with hood open (350hp 330hp with hood closed) /low boost (15psi) with hood closed (291hp)
Second set of graphs is before the head gasket/ ID injectors / Freddy manifold (260hp) / after (350hp)
All tuned on 91 pump gas
To summarize: don't go high compression for turbo unless going e85.
Old 05-08-2017, 11:18 AM   #128
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Nice work.
Any idea on the spike?? Is that a boost spike @ 4500 RPM??
Old 05-08-2017, 12:02 PM   #129
battery1882
Originally Posted by RalliartRsX View Post
Nice work.
Hey! yeah I'm still running internal and looking to upgrade to tubular + external. we had some difficulties using the greddy profec as well. I guess we will reserve that for next tune.
Old 05-08-2017, 12:23 PM   #130
RalliartRsX
Trader Rating: (32)
Cool. I had problems with the Greddy, but on an entirely different turbo lol.
Standard gate does have problems both keeping shut at the higher boost levels and just impeding flow/causing back pressure in general.
Old 05-08-2017, 12:24 PM   #131
koukimonst3r
Yeah I'm gonna do a compression test on thursday, track day on the 14th, hopefully the numbers are good. I have a Tomei 7960 with a failed internal, went external turbosmart 40mm and it stopped my boost creep.
ig : koukimonst3r
Old 05-16-2017, 07:51 AM   #132
battery1882
yeah I think internal is not working out so well.
5/13/2017 Nissan challenge rd. 4.
Engine was running strong w/ egt max at 1350 F, ect max at 209 F, and oil temp max at 210 F. This was probably the first time engine ran this good finally.. of course I had to mess something up. I forgot to tighten the oil cap so it flew off somewhere
went to test out the camping gear and realized I didn't have blanket lol. slept in the 4runner with the heat on
went out to autozone to buy a stupid oil cap cover. this is the second time I had forgot to tighten that cap..
New Number for remaining of 2017!
Hapy with the result
http://www.youtube.com/watch?v=vTFuOu_XbtY
Best lap time of the day was 1:23:36 which was enough to win the Class 2!
Old 05-20-2017, 10:06 AM   #133
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
How is towing with a 3rd Gen Runner? I just got one earlier this month.
Old 05-21-2017, 12:35 PM   #134
locodrftr
locodrftr is an unknown quantity at this point
Looks good Peter, it's me Ted by the way
locodrftr is offline   Reply With Quote
Old 05-22-2017, 08:44 AM   #135
battery1882
Cool! these cars are becoming pretty popular with overlanding. They are ok with towing. Obviously lacks power so going up hills with OD off is challanging sometimes. I have a really small trailer so I think it helps.
Hey Ted!
Welcome back to zilvia! hope to see your work on here!
If you guys wanna see ted's welds instagram: heliarc_hustler
instagram : battery1882
www.sterculture.com
Old 05-22-2017, 10:58 PM   #136
koukimonst3r
My compression numbers were 160, 160, 156, 160. Track day went fine except I now have a turbo manifold problem for the 3rd time ��. Upgrading flange studs to arp and adding locking tabs as well as stover lock nuts. It may also have to do with my cusco engine mounts, chopped the test pipe and added a flex pipe.
What did you use to keep yours together?
ig : koukimonst3r
Old 05-23-2017, 06:09 AM   #137
RalliartRsX
Trader Rating: (32)
I can almost promise it will pull apart again.
The key to all the woes is simply the exhaust to transmission mount bracket. That and a flex in the downpipe is what cured my problem.
If you think about it, the turbo is in a constant state of trying to pull away from the manifold (turbo is hanging down off the manifold). Couple that with several thousand heat cycles and vibrations and no matter type of adamantium you use for hardware, the turbo and manifold will inevitably separate. The problem is exacerbated with more power (heat) and track usage (heat cycles). The studs is what the issue is btw, and NOT the mounting/locking hardware. The studs themselves see several thousand heat cycles and end up stretching and contracting hundreds of thousands of times with no cooling being available. Once the studs are compromised, the locking hardware is useless. And this is why I ALWAYS recommend OEM Inconel studs and not any aftermarket bling bling trash. That or the TSE $100 kit from the miata guys (Inconel studs and stage 8 locking hardware).
Not sure how many times I have said this to folks lol. a few options
1) weld a bracket to the compressor housing and suspend the turbo/manifold combo off the engine
2) Run the exhaust/transmission bracket with flex section
3) Weld them together.
Old 05-23-2017, 08:02 AM   #138
greenwood
greenwood's Avatar
greenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymoregreenwood is not welcome here anymore
Just put in a flex pipe, get a stainless one for 10 dollars or so off ebay and have it welded in.
greenwood is offline   Reply With Quote
Old 05-23-2017, 08:08 AM   #139
RalliartRsX
Trader Rating: (32)
That does not solve the inherent problem.......especially for a track day vehicle
Old 05-23-2017, 11:57 AM   #140
Extreme Dimensions
Extreme Dimensions's Avatar
Extreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to behold
From start to finish is a fun read.
- Chris Gary
p: 714-278-8000 x 19
E: [email protected]
Extreme Dimensions is offline   Reply With Quote
Old 05-23-2017, 12:35 PM   #141
battery1882
well explained! I have mine welded. I have titanium cat-back and flexible hose on the down pipe. It was still backing out.
Cheapest solution is factory hardware + tack welds. or v-band. If you go back few pages, you will see how mine was welded.
Thank you!
Put carpet back in to run Global Time Attack Street Class!
looking forward to 6/3/2017
www.sterculture.com
Old 06-06-2017, 03:33 PM   #142
shaggyjake
shaggyjake's Avatar
shaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choices
Enjoyed the build so far. If you're interested, there is another time attack league called racefreely (ig: racefreely) that has events at grange motor circuit. The next event is July 22. I've taken my car to the canyons a few times but this is going to be its first (and my first) track shakedown.
Anyways, keep up the good work! Those look like good times and the car looks good, too!
shaggyjake is offline   Reply With Quote
Old 06-06-2017, 07:15 PM   #143
TheRealSy90
TheRealSy90's Avatar
Man, grange is such a small "track" to run a grip car on lol. Great for drifting though.
Such a good signature.
Old 06-07-2017, 11:52 AM   #144
battery1882
Thanks! I'll try to make it if I can!
I'll check it out!
Entered GTA (Global Time Atttack) rd. 3 @WSIR.
Personal best time of 1:32.411. 2nd place in Street class.
I will update with in-car footage.
Images above by Amanda Gift SNAPS Studio If sharing please give photo credit by tags & hashtags. Photo: @snapsstudio #snapsstudio @globaltimeattack #globaltimeattack
Images above by Matt Viramontes MCV Imagery If sharing please give photo credit by tags & hashtags. Photo: @mcv_imagery #mcvimagery @globaltimeattack #globaltimeattack
www.sterculture.com
Old 06-08-2017, 09:09 AM   #145
battery1882
water temp peaked out at 225. I'm gonna switch over to nismo thermostat.
I was talking to Koji and he told me that there is alot of timing pulled at that temperature.
I don't think I should be this much slower than e90 m3..
http://www.youtube.com/watch?v=CsTEK4Q547U
www.sterculture.com
Old 06-08-2017, 09:53 AM   #146
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
you have any idea if time attack is done in the midwest. so i can get track time.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 06-09-2017, 10:11 AM   #147
battery1882
not sure 123, I'm sure there are plenty of track days over in mid-west though.
www.sterculture.com
Old 06-11-2017, 12:44 PM   #148
koukimonst3r
ARP studs, OEM Nissan locking tabs and stover lock nuts held fine! Sayonara turbo manifold problems. Followed you on instagram too!
ig : koukimonst3r
Old 06-12-2017, 08:59 AM   #149
battery1882
Awesome! your car looks super clean!
www.sterculture.com
Old 07-07-2017, 02:58 PM   #150
battery1882
Swapped to nismo thermostat
temp @ around 170 degree F cruising. Hopefully this helps out at the track!
Not sure if I can make it to next GTA but will definately go to the next nissanchallenge on 8-20-17!
www.sterculture.com
