Off Topic Chat All non related chat goes here. |
09-05-2008, 10:31 PM | #124 |
Needs front ball jaints
New front shocks Exhaust leak relocate harness in fender power steering is out TIRES! front main seal
89 240sx hatch #933-the hot rod 91 240sx coupe #131,603-the daily |
09-05-2008, 11:13 PM | #125 |
Super Moderator
Trader Rating: (29)
Feedback Score: 29 reviews
loose rear view mirror (probably the ball joint part? i already tightened all the screws)
squeaky steering wheel when turning right buggy driver side power windows dirty dirty dirtyyyy ...plus others lol any fixes/solutions you can think of can be greatly appreciated! |
09-06-2008, 12:12 PM | #127 |
pass gp by door a lil jacked up.... pass headlight a lil tweaked..... dash lights dont work.... temp gauge dont work.... plate lights dont work... no f-ing radio... beat up suspension... trunk release doest open... works only with key... valve guides are worn to shit...
09-06-2008, 01:40 PM | #128 |
Trader Rating: (30)
Feedback Score: 30 reviews
*sigh* here goes
salvage title black fender ziptied on (broken corner light) vacuum leak transmission only hanging on by one side of the mount leaking small amounts of oil leaking small amounts of tranny fluid leaking diff fluid stock radio is not mounted radio trim has a broken clip small amounts of random rust here and there no windshield wipers no powersteering bov not working for some odd reason im sure theres more...but im hungry |
09-07-2008, 03:11 AM | #130 |
On the s14;
blown tranny (just got a z32 replacement, hope thats not broken too) driver's side body and wheels all scraped up (from hit & run driver that got away) fading & ugly paint windshield fluid container falling off dead battery inconsistent boost (prob turbo wear & tear) window motor unresponsive lots of annoying miscellaneous interior rattles horrible looking tint that needs to be removed/replaced On the evo; (only 7k miles) has a huge dent on rear quarter panel needs front brake pads needs oil |
09-07-2008, 03:26 AM | #131 |
:sigh: another broken axle
2015 Subaru Outback Overlander - Wagonofdoom |
09-07-2008, 05:48 AM | #132 |
- unfinished lien on my car
- motor bogs mid rpm's - smashed oil pan - leaking oil every time i start my car - all my speakers are blown - cracked tail light - and there's some stupid thing called a KA in my engine bay. who knows what that things for. |
09-07-2008, 09:48 AM | #133 |
Replace dented fenders with wider frp ones
Install bricks Mount tires Put dash, seatbelts, console back in Ziptie rear bumper back to the garnish Put lower radiator hose back on, fill radiator and see if it leaks again |
09-07-2008, 08:16 PM | #134 |
axle leaking
boost at 1.4 bar and it has no boost controller and a t25 so i cant floor it till i fix it, thinking its the waste gate..? idles low battery is leaking and dies over night lights are dim and some times stop working untill i wiggle the switch bout it for now
FOR SALE |
09-08-2008, 08:17 AM | #135 |
-Shitty Welded Diff.
-Shitty Carpet -Cracked Windshield -Exhaust Leaks -Ripped Leather Seats
------------------------- www.carolinanissans.com ------------------------- |
09-08-2008, 10:13 AM | #136 |
-both tie rod ends leaking (tein inners and outers already here)
-tie rod boots broken (new ones already ordered) -wrong LSD backlash (diff is noisy as hell) -oil leak on oil cooler fittings (fixed 10 mins ago) -front tires worn out (new ones are already here) -brakes worn out (parts already ordered) |
09-08-2008, 11:51 AM | #142 |
the Z- radiator support is bent, front bumper is bent, terrible positive camber wear up front, no radio, random noises, rusting frame
s13- new fuel pump no worky, e-fan switch burned up s14- no longer runs.. dont know why, window motor/regulator needs replacing, no reverse gear
Slide 'n Hide -'72 240z LS1 project |
09-08-2008, 12:08 PM | #143 |
-registration
-insurance -electrical demons (shitty trunk relocation job from previous owner) cable is running directly under the car, into the trunk w/o a grommet, all connectors are corroded for the grounds, alternator took a shit being covered with oil so my car is dead at my alarm installers pad. -need to install my car alarm =( -need to put on my aero and paint it, but need core support and still waiting on replacement roof skin from nissan. |
09-08-2008, 12:57 PM | #144 |
-One ichiba hub with to much play.
-One siezed T28 at the track day on Friday. A replacement T25 is in route to get me through the last track day and HPDE school in October. |
09-09-2008, 08:17 PM | #145 | |
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
-Blower doesn't work for A/C and heat, and I'm not sure if its the motor, control, or relay
-Tachometer doesn't work like its supposed to. Sometimes it works, sometimes it chills at random RPMs. -My rear calipers are close to the end of their lifespan -Its missing the factory wing -Clutch doesn't grab for shit, despite having only 1k miles -And this: lol.
http://zilvia.net/f/sale-items/24807...-stuff-fs.html |
09-09-2008, 09:23 PM | #146 |
-Clutch engagements too far back for my tastes.
-Power steering fluid leaks craptastically -Running ultra rich, likely boost leak or something, ill check this week. -Axle boots broke in TX, now axles have a bit of play -Something smells like gas everytime i turn car on, i guess leaking at some line. -Old kit had 3/4s" of bondo to mould kit
Hookers and blow. |
09-10-2008, 01:30 AM | #149 |
Cosmetic: Dents, Clear coat peeling
Mechanical (Engine): Nothing that I know of Mechanical (Steering): Power steering leak some where, and I need new steering column boots. Suspension: The usual stuff, old worn out suspension bushings.
Do need the Factory Service Manual? Click here. |
