#14701 |
![]() Join Date: May 2011
yeah, they obviously wont fall out but theres still a bit too much room for them to move for my liking lol. thanks! i'll check it out
#14702 | |
* S14SR22 * 9.0 c/r * GT3071R * |
#14703 |
![]() Join Date: May 2013
When coming back home from work today my car started heating up, so I look under the hood and I find coolant everywhere. So I started looking around the hoses, on the floor to see If I have any leaks. And...found nothing.
I don't know what It could be. Any suggestions? |
#14704 | |
#14705 | |
#14706 | |
#14707 |
![]() Join Date: Mar 2010
Trader Rating: (34)
![]() Feedback Score: 34 reviews
^If i leaked everywhere when it overheated, then start looking into the pressure relief valve/lines to overflow tank. If not there then its the pressure cap itself.
#14708 | ||||
![]() Join Date: Jun 2009
![]() Feedback Score: 11 reviews
As long as your KA is lowish miles (under 120k) and not ragged on, you can do 350 on an unopened motor. A 2871r, at least 550cc injectors, z32 mafs, and a GOOD Rom tune will get you there pretty easily for maybe $2000-2500 depending on how good you are at finding deals and what you decide to buy new or used. Just make sure you get a good tune and not some SAFC bullshit that your ese's amigo tuned for you.
#14710 | |
If you have the 'lowish miles' engine, AND it can hold between 8# - 10# of boost, you will see a nominal 340hp - 375hp running an air to air FMIC. Water to Air FMIC allows lower boost pressures(9# at 375hp) The big thing on turbocharging an older KA is at higher boost, you WILL blow out the rings and cause other damage if you do not do it right. The Isis turbo kit runs ~$1400 shipped, a good Water to Air FMIC will run another ~$700. A GOOD ECU from RS Enthalpy, Enjuku, JWT, for the set up, will run $500 - $800. Turbo tuner, and other small tech, well son, how fast you wanna go? Speed costs. The key is setting the engine up right. Sure, you can go low boost numbers with cheap add ons and see 300hp...until you blow out your rings. OR, you can rebuild your engine the right way, get good parts, and if your parts can handle it, run max pressures and see 450hp and higher(max pressures net about 450hp on a built engine). Add meth and a stand alone AEM Infinity system, and you can get 500hp - 600hp. The question you have never answered here, is HOW MUCH CAN YOU SPEND? How far are you willing to go? How much work do YOU want to do to get to your goal point? The above are important questions that will get you to a solid, reliable 350hp or higher. BTW, a little coupe that put 346hp to the wheels was FAF to drive...although it probably was not built safe enough to do so for very long. I am certain Gentlemen Drift can tell you more about that particular car. All I know, is I watched it disappear into the sunset, stalling out at every stop when a wee little Mexican bought it and took it down to Alabama. I watched that car kick his ass for the two miles to get off base, and there is no tellin how bad it kicked his ass all the way to Alabama!
#14711 |
[QUOTE=David48;5398008]New engine harness and not revving past a certain point sounds like the Mafs isn't hooked up or not hooked up right. Try unplugging it and see if it makes a difference. Does it smell like it's running richer than normal?
the maf was wired wrong , i had to switch the ground with another wire then the car idled fine ,i went to drive it the other day and thats when it wouldnt rev out right ,or at all . was it in limp mode? so i had to swap the power wire and the ground wire pins cause they were in each others place , but when i started the car with it wired wrong the first time couldn't that have grounded out my maf or burnt it out? ive been over my chassis harness dozens of times , my engine harness is hooked up right ,i put in new plugs,im gonna replace the cts when i got to my garage today and also pull codes .im about to just tear out the chassis harness and use a painless setup , then i guess have this chasebays harness looked at again. |
#14715 |
where can you buy a rear main seal housing for an sr20
#14716 |
That's where it came out from. And I kind of exaggerated when I said "everywhere" It was more like where the pressure cap was. Apparently It wasn't tightened which was weird. But It's all good now.
#14717 |
![]() Join Date: Apr 2007
Firestone's lifetime alignment for $199, is it worth it? i understand that they'll only align it to factory specs. my future car mods will include a name brand steering angle kit and modded rear lower control arm.
Full Time Student for Life |
#14718 | |
If you get a cool tech, you can get him to align it to whatever you want. Within reason.
#14719 | |
Let it cool, and allow the fuel lines to cool down, fire it up, and 'speed on'
#14720 | |
#14721 | |||
![]() Join Date: Dec 2004
Trader Rating: (58)
O/P, take plugs out and see how they look. Willing to bet OP didn't take the lower 2 nuts off the studs that go into the upper pan
#14722 |
![]() Join Date: Feb 2011
Trader Rating: (25)
![]() Feedback Score: 25 reviews
hi guys so my car wont start right away all the time it. it takes like 20-50 times for it to start, this is a problem i've been having for a year i have since replaced my
lower harness including the battery cable starter ignition switch and I'm still fairly new to these cars what other things should i take a look at or replace? |
#14723 |
![]() Join Date: Dec 2009
![]() Feedback Score: 8 reviews
Nah. Actually, one of my injectors was leaking and I kept cranking the engine to make it start. I ended up flooding my engine. Now would it be ideal to change my spark plugs after fixing this
#14724 |
#14726 |
He didn't finish saying it, but change your oil too.
#14728 |
if i started my car with the maf ground going to the wrong pin would that have fried my maf? my car will not rev past what im guessing is 3000 rpm's . i did since put the wires in the right order but chasebays had them wrong so i wanna know if it would have ruined my maf or anything else cause since i put this harness on nothing really works it seems.
