08-08-2013, 11:17 AM | #14521 |
God speed sucked back when they first started because no one knew who they were. But then again so did cp, eagle, and all the other "name" brands. They made cheesy parts that broke then fixed their flaws and if eagle is such a good "name" brand how come I bent 3 of their rods in my all motor 350 that was putting down the same power as my rb with Godspeed rods???
08-08-2013, 12:15 PM | #14522 |
Because your build sucked, either you or somebody else did something wrong to cause premature failure in your '350' (I assume 350Z?)
* S14SR22 * 9.0 c/r * GT3071R * |
08-08-2013, 02:07 PM | #14523 |
i need to know which crossmember i have.
I have a trans x member that has a little arrow stamped on it and what looks like a "D" i was told it was a s13 5spd x member and i saw a thread that showed a "A" and a "B" style and mine APPEARS to say D.
95 S14 se RB25DET 348whp |
08-08-2013, 05:46 PM | #14524 | |
AFC #1
08-08-2013, 06:43 PM | #14525 | ||
Trader Rating: (58)
Feedback Score: 58 reviews
You get what you pay for. There is a reason you take a chick to a nice place toe at when you're on a date, and go with your buddies to a shithole dinner on the other nights. Both fit the bill, but that is not to mean they are the same.
08-08-2013, 09:29 PM | #14527 |
Fitment
Currently lookin to buy new wheels and was just wondering how the fitment of some 18x9 +32 would fit on the front and back of my stock body s14?
Or would +20 be better in the front or maybe even in the rear? Somewhat, actually pretty big noob at offset and all that with wheels First set of wheels I'm buying for my s14 actually Thanks |
08-09-2013, 02:58 AM | #14528 | |
08-09-2013, 08:50 AM | #14529 | |
Trader Rating: (58)
18x8.5 Z33 track wheels fit with decent rubber, but are close to the coilovers. You should be able to fit the 9, but I'd check the wheel thread to make sure. It will easily clear the body, but just worried abotu coilover clearence. With that said you can always get small spacer to get it to 20/25 offset too
08-09-2013, 12:49 PM | #14530 |
When I had my motor out, I replaced the rubber steering bushing with a DIF aluminum piece (which was a big old PITA) and now I seemed to have turned it into a bigger one: my steering wheel is off-center. I guess I clocked the linkage one tooth when I put it back, even though I marked the spot. Car tracks straight btw.
Is there a way to fix this without messing with the connection at the steering rack? Can this be taken care of with an alignment?
08-09-2013, 01:12 PM | #14531 | |
Although if you do that make sure you remember that you had done that lmfao |
08-09-2013, 02:02 PM | #14532 |
If it is easy enough to clock the steering wheel, I will do that.
My issue with the alignment shop doing it is that I am afraid to have different amount of full lock to the left vs. the right.
08-09-2013, 06:23 PM | #14533 |
Power steering issue
Okay, so I've been trying to figure out what this problem is for a few weeks now. My power steering started whining at me a few weeks ago and I unknowingly put ps fluid in it which fixed the immediate problem for a while.
But the problem kept coming back and I kept putting ps fluid in while trying to figure out where the leak was coming from. This happened quite a few times (this being before I became a member and actively searched forums for answers) and one day while changing the oil I saw it fluid leaking from both steering boots so I thought I needed a new rack. Come to find out I'm supposed to use atf so I've used that the past few times it's happened and it seems the problem resolved itself. I haven't gotten whining in 2 weeks, so now I'm not sure if I need a new rack or I was just using the wrong fluid. I've spent the past two days searching google, zilvia, and other 240 forums and can't figure it out. Any help is appreciated. stock KA24de |
08-10-2013, 08:10 AM | #14534 | ||
The best way to fix this slight misalignment is to loosen the rack so you can move the steering either left or right to get back to center(12 o'clock). You know as well as I do that if you reclock the steering wheel you will LOSE some full lock to the side you clock towards. You need to reclock this AT the rack. You KNOW how to do this right, and you have the skill. drive the car in a straight line. Mark the 11 - 1 area where your wheel is running straight so you can insure you have the wheel set when you get under the front. Loosen up the rack and reclock it. This can also be checked at the wheel after you tighten as the wheel SHOULD be at 12. As we like to say when we are driving, DUDE, you GOT this fucking shit! Quote:
I am thinking that using the wrong fluid may have caused the seals to constrict a little, but when you replaced the atf in the system the seals then swelled back up to normal. Oil based and synthetic fluids DO react differently on some seals. The seal may constrict with one fluid, but swell with another through simple chemical reaction.
08-10-2013, 09:48 AM | #14535 | |
08-10-2013, 10:14 AM | #14536 | ||
AFC #1
Rear, you could get more rubber under there with a +32 but it would mess up your track width. Quote:
The only difference is the extended life oils have more detergents in them to last longer. Because the oil wouldn't wear out the detergents would be consumed. The detergents would clean up the deposits around the old seals and they would leak because the seals were gone and the deposits were actually keeping the seal. The problem he had was the PS fluid is a different weight than ATF. That is why it got past the seals. I would flush out what you can but it will eventually all weep out. So, you will still have some leaking till it's all gone. The bigger problem than the leaking is the PS won't protect the pump from wear. That is the big reason I would flush or drain and refill a couple times to get it all out. It is also where the wining was coming from. I wouldn't worry about the rack too much. Those seals should recover after being in the right fluid for a while
08-10-2013, 12:26 PM | #14537 |
Almost finished doing my 5 speed swap on my 97 s14 (95 transmission), i am only stuck on the wiring, (5th gear sensor, revers lights, and neutral) wanted to get the original plugs but i cant find them anywhere, i checked autozone and pepboys but i couldnt find them, is their any car i can take them off from the junk yard?
08-10-2013, 10:08 PM | #14538 |
Ok riddle me this. In my hatch, the lock cylinder on the driver door is left for unlock, and right for lock. In my s14, it is opposite. The only reason I am asking this is because the hatches hatch is right for unluck. So my question is could my lock cylinder(s) be rotated 180 degrees? like flipped around for this or do all s13s come this way? Thanks guys.
08-11-2013, 12:37 AM | #14539 |
I broke a rocker arm and then lost the shims, i couldnt find them in the head, and then i took off the oil pan and baffle plate, and i still cant find them. what should my next step be?
It was on the exhaust side of cylinder number four, so im kind of thinking it fell in that back oil passage. would using an air gun to blow it out be a possible answer, or could it blow it back somewhere farther?
08-11-2013, 03:03 PM | #14540 |
Just recently got my car up n running.
Having a little issue with my Z brakes. Keep in mind everything is new expect the caliper it self. Issue: if i step on the pedal, after a second or 2 i start hearing a loud screech like if im running on low brake pad. As soon as the screeching started these lines start on my rotors started showing up. Could this be a potential problem later on? Running: Z32 26mm Calipers (rebuilt & not split) 88rotors drilled n slotted rotors Onyx Ceramic brake pads Agency power SS lines Z32 BMC & Booster ATE blue brake fluid. I have properly bleed my brake system. brakes run great, its just the screeching and the "lines" on my rotors are worrying me. Appreciate the help. |
08-11-2013, 04:10 PM | #14541 | |
08-11-2013, 04:19 PM | #14542 | |
08-11-2013, 04:42 PM | #14543 |
I just picked up a set of Work VS-XX in 17's and I have a quick question. I tried searching but nothing really answered my question.
Is it ok to drive with 3 assembly bolts missing from the wheel? I'm ordering the replacement bolts soon and just wanted to know if its ok to drive on them temporarily |
08-11-2013, 09:55 PM | #14545 |
NEED Suggestion...
I've got a 92 HB. It just got painted a month ago to Metallic Grey. I got some clear front turn signals. Question is: Should I light tint my turn signal or leave it clear? |
08-12-2013, 06:51 AM | #14548 | |
Is it just me, or does this forebode a bad ending in the near future? Hip Hop, you know we love you man, but have you considered finding a friend who knows what he, or she is doing and can do it well without breaking parts or losing stuff down the engine? You could truly benefit from a good mentor
08-12-2013, 08:24 AM | #14549 | |
08-12-2013, 08:42 AM | #14550 | |
