#14491 |
hey guys. preparing to do my 5spd swap in a few days, and i have a question.
ive read people dont connect all the sensors, like the 5th gear and neutral safety. is this ok to do? i can use the wires from my auto? give me details please. also if someone with experience would take the time to text me, i'd like to ask a few questions/get a little guidance as this is my first swap. 973-eight03-six802 |
#14492 |
I'm using god speed rods in my 25 making over 500 whp with over 15 Dyno runs and it's still going strond so I personally think that name brand parts are a waste of money for street/drifting and I know first cuz I BEAT the balls off this car and I have no problems.....ever
#14493 | |
* S14SR22 * 9.0 c/r * GT3071R * |
#14494 | |
AFC #1
![]() Join Date: Oct 2003
You probably aren't wring in the clutch switch ether so the safety aspect of starting in gear is mute. The only other thing is later models drop into a lower idle when in Neutral at idle. 5th gear is for the speed(rpm) cut. The car has two speed(rpm) cuts one in 4th and one in 5th. It's not possible to hit speed cut in the other gears so it uses the 5th gear sensor to determine this. You also still have the speed cut from the VSS.
#14495 |
![]() Join Date: Jan 2010
![]() Feedback Score: 10 reviews
ok so im down to last thing i need for my hydro i got all the good stuff already i just need to get the lines so i was wondering if anyone could help me out with a diagram or some info on sizings i need??.... im running the ASD hydro with the dual Z32 rear caliper setup on my s14
thanks guys |
#14497 |
It depends on your gearing. You can google gear ratios and it shows the speed for whatever RPM you want to know
#14498 | |||||
![]() Join Date: Dec 2004
Trader Rating: (58)
Enter the info, and you'll be set. Quote:
You won't need either hooked up for it to work. Quote:
In the suspension angle thread, they are listed on page one. Agreed!
#14500 |
AFC #1
If you get Adapter plates to mount the S14 compressor on the SR mount. ^Someone^ has a link in their sig...
#14501 |
If anyone on here has a blacktop/S14/S15 SR oil pickup lying around, could you please measure its height from the mounting surface to the lowest point?
Thank you kindly. ![]() |
#14502 |
![]() Join Date: Mar 2009
Quick question I am putting a s15 Silvia motor and trans into my s14. Noticing this wont work with my s14 driveshaft and diff, do I need to just buy a s15 diff to make it work?
#14503 |
does anybody know for a FACT that the 350z steering wheel will fit into a s13? and what modifications need to be done? i can't seem to find any hard info on this just people saying "it fits" but no hard evidence...
#14504 |
When reinstalling front hub on s13 the outer side of the bearing looks like it does not have a grease seal:
- do you guys wipe old grease and pack new grease in that gap? - can you use synthetic moly high temp. wheel bearing grease like Red Line CV-2 - is it compactible with OEM grease or will it mix together and become one harmful goo? - is there a rubber or fleece seal to keep that grease inside the bearing? ![]() Last edited by cured13; 08-06-2013 at 06:34 PM.. |
#14505 |
![]() Join Date: May 2011
![]() Feedback Score: 23 reviews
Since I have some Tein Winding masters and the rears don't go as low as I'd like I've been looking for a different coilover set up. As I was roaming the PBM website I realized that they sell replacement dampers that seem to be shorter than my teins. So this will allow me to achieve the ride height I need without having to buy coilovers just yet.
My question is if anyone tried their dampers with other hardware? and would bolt up to the tein hardware (top hats, collars, etc.)? any info is greatly appreciated. |
#14507 | |
also, forgot to mention. its a 93 ka. is there a marking on the ka that tells the year? this is my second engine, so im just assuming its from an s13. |
#14508 |
#14510 | ||||||
Trader Rating: (58)
With that said if you don't get anything 'blowing' you need to loo into why the blower motor isn't even turning on. Also if you don't have any heat, check to see if you have water lines going to the heater core. Quote:
Thank you ![]() ![]() Quote:
It's best to use similar type grease when installing stuff...unless it's new then use whatever you wish. Also take this into consideration: Project Silvia - The Official Guide to Not Screwing Up Your Wheel Bearings Like I Did > MotoIQ - Automotive Tech, Project Cars, Performance & Motorsports Quote:
If you need to bounce off the ground, go get some Racelands and slam it. If you need performance you won't need to go that low, and should just keep what you have. Quote:
My car makes 400 to the tire, and the trans (current one) has been good for almost 3 years now. Shift smoothly and 'a little' slow and it will last you. It's not so much the trans, but the harsch gear engagement and sudden torque blast that eat stuff up in most street cars.
#14512 |
#14513 |
Do you guys know of any decent car customizing games/websites? And where do people make those little cars for there sigs? Looks like it could be fun.
thought of another question I might as well ask since i posted - I have a champagne hatch, with no tint. I've been contemplating doing black roof. I'm on the fence about it. Also, would vinyl wrap work well? How would it hold up to weather? (Oregon rain) |
#14515 |
![]() Join Date: Feb 2010
![]() Had some rust of top of window metal trim, removed trim to fix now im having a hard time seeing how its gonna be put back. Any suggestions??? Thanks |
#14516 |
#14517 |
That is only "some" rust?!?!? I would not have touched that automobile with a $5 footlong.
* S14SR22 * 9.0 c/r * GT3071R * Last edited by bc.; 08-08-2013 at 07:44 AM.. |
#14519 |
![]() Join Date: Oct 2012
Okay ya'll can hate or not i dont care but I was interested in these headlights and I have HID's in my car now so I was wondering if the housings for the bulbs would fit into these ones or not
89-94 Nissan 240SX S13 7x6 H6054 Headlights - Yellow :: 240SX :: Nissan :: Lighting - Crystal Headlights :: Dash Z Racing |
#14520 |
I hate more that you used the word "ya'll"
Are you saying you are gonna put HID's behind these yellow lenses? That is gonna blind the shit out of people, is it not?
