#14432 |
![]() I kept turning it clockwise but then it got to the point where it turned the little gasket and trim. I'm a noob at doing my own things. Anyone else deal with this? How can I take it off?
#14435 |
oh alright, i didnt see it at first because i thought it was right up near the steering wheel
#14437 | |
![]() Join Date: May 2006
#14440 |
Bandwagon.
anyone who which side driver/passenger side powers the defrosters on a s13 hatch?
Im talking when you lift up the hatch, there's 2 sides of where the wiring are at the top. |
#14441 | |
![]() Join Date: Jun 2007
////////////////////////////////////////////////////////////////////////// Do SPL bronze Z32 shifter bushings with the Mazworx Z32 shifter and if so do you like them? Called Mazworx already- They weren't sure.
#14442 | |
![]() Join Date: Jun 2012
Call FRS and ask them or email SPL. But I dont see why they wouldnt work. [email protected] |
#14443 |
![]() Join Date: Dec 2004
Trader Rating: (58)
For as cheap and easy as LS coil packs are to do, I'd see no reason not to go this way. You could have a better performing, more reliable setup and spedn half as much as a splitfire setup.
#14444 | |
![]() Bushings are here already, shifter will be here with the rest of the installation kit soon enough- Then I'll know. Thanks dude!
#14445 |
Is it possible that my walbro fuel pump is gradually dying? It doesn't prime with the ignition on occasion and I can't figure out why. (Every time it doesn't work, it does so at a time when I don't have time to trouble shoot.)
The other day, I was driving it and the car sputtered under boost and ran lean, like the pump was shutting off, later it drove fine.
* S14SR22 * 9.0 c/r * GT3071R * |
#14446 |
![]() Join Date: Mar 2008
My Walbro pump died gradually. It would be fine until the car warmed up and the fuel in the tank got warmer from the fuel that was running through the rail and returning.
It eventually got to the point where it would lean out under boost and sputter/break up. I put in an Aeromotive Stealth 340. |
#14448 |
KA24DE, 220K Miles.
I changed my mounts today, and while doing so I changed my oil. It was a little over due, so the oil was black and thin. I put Castrol Syntec 5W-30 back in. Shortly after start up I noticed the Oil Pressure light was on. You could hear the timing chain really loud. After it warmed up though, the light will go on and off. at ~2K RPM there is a weird ticking nose that sounds like it's coming from the middle of the engine. I really hope its not the oil pump. Any ideas? |
#14450 | ||
WAG's: You have a timing chain guide out Timing chain tensioner is out Rod is showing stress cracks before it detonates out the side of the block Center bearing on crank is bad Cam bearings are bad Bad shim/bucket I can go on and on, but you get the idea. Until you listen to it and locate exactly where it's coming from, you won't know Quote:
Run 8 of either one, but not a mix and you will be fine
#14451 | |
I would absolutely not do this, but I don't know what is gonna happen if you do. The part of me that wants a well built car that isn't gonna break says "fuck no", but the part of me that is curious says "why the fuck not".
#14454 |
Anyone here running a recirculated SSQV? Do I need to buy the 19mm or 29mm fitting? Getting tired of running pig rich and idle drop so I'm going to be buying this in the next few days.
#14455 |
![]() Join Date: May 2012
My stock SR exhaust manifold has a small hole drilled into it from where the previous owner had an EGT guage probe installed and I was wondering if there was a way to safely plug it. There are no threads left in the whole so I'm looking for a recommendation on what to do. Thanks
#14457 | |
I just know Hip Hop is going to DO IT ANYWAY because he has the parts or it's the cheap way out. SO we just might get to know. Me, you, we would never ever entertain the idea...ever. Hip Hop, though, well, he DID ask! Hip Hop; do the words catastrophic failure of valve train mean anything to you? Let me tell you exactly how a SR20 reacts to valvetrain failure(I know this from recent experience). The valve closes and due to a rocker lifter or a shim/bucket/spring fails. The valve stays closed and the cylinder has no (in my case) exhaust valve opening. The intake continues and the cylinder fills. The detonation happens. It stresses the rod and rod cap. The rod cap stresses until it breaks and BAM, out the side of the block. Catastrophic Valvetrain Failure = Blown engine block in an SR0. Now in my case, I was on the freeway doing 75mph. I tried to get off the side of the road in heavy traffic, but could not. I was pretty much forced to 'stay in it' because big truck behind me. I could not just stop in a fast lane of traffic when I heard the clink clink clink of valvetrain breakage. SO guess what, Catastrophic valvetrain failure led to blown engine at speed...that fuckin truck backed the fuck off when teh engine blew though, all the motherfuckers did...I just wish they would have when I had a signal and was looking over my shoulder with that aw fuck look...then it would have only cost $200 instead of $1400 So go ahead, mix your shit up and make a crappy built engine
#14458 | |
#14459 |
good thing too, otherwise your engine would be hiphop a knock'n til your rods fly out your block'n...... beyatch!!!
#14460 | |
I broke a rocker arm one time, a lifter a different time, and nothing came flying out the side of my engine.
