#14341 | ||
I have replaced the EGI and EGI pump relays with new ones, with no help. When it doesn't start, I can still hear that the fuel pump is not priming. The weird thing is that I don't touch anything, and bam, it starts right up the next day. Vice versa, after driving it for a day and not touching anything, it decides not to start the next day. At this point, I do not turn it off anywhere except my house, trying to avoid getting stranded. It is VERY frustrating because the car is running so well right now.
* S14SR22 * 9.0 c/r * GT3071R * |
#14342 |
![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Thank you. I don't have the car with me, but I don't think I have that.
With that figured out... My brake master cylinder is leaking. What should I change it to? Just buy an oem non abs mc ((( Brake Master Cylinder Non ABS 1995 98 Nissan 240sx s14 Used | eBay for example))) or upgrade it to the 300zx bmc? My set up is 4 lug. Keeping it that way. I am upgrading the rotors, pads, ss lines, fluid, to aftermarket pieces. Thanks!
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
#14343 | |
#14344 |
Yeah that's what I thought, but figured I would ask first.
Oem piece it is. Hopefully it will last. Besides I think if I did get a bigger one it would throw off the balance iirc from a post I read while searching.
#14345 |
![]() Join Date: Apr 2012
![]() Feedback Score: 8 reviews
So I Rb20 Swapped my S13 Bled the hell out of the clutch... And so when I'm engage the clutch its like at the very top about 85% full retracted is when I engage. So I read some forums and adjust the little Rod thing behind the pedal and still... At the top so imrunning out of ideas please help.
WTB: Dmax Coupe roof spoiler.
#14347 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Shouldn't need springs with the poncams...only the pro cams. If you do need springs get Tomei springs.
#14348 |
Bandwagon.
how can you tell if your cas is bad? sr20det
#14349 |
![]() Join Date: Jun 2008
![]() Feedback Score: 11 reviews
OK so I have my JDM vlsd on my car and I have the J30 5 bolt axles ALSO installed and now I see that my driveshaft is too short! When I did my 5 speed swap I got it from a sohc coupe which I believe had no abs. I was reading some posts and majority says that the abs driveshaft is shorter. So my question is why is my non abs driveshaft not reaching my vlsd that doesn't seem to have an abs sensor on it? And what driveshaft would I need to make this work because this is my daily driver?
#14350 | |
#14351 |
I want to say about an inch or so. I'll take a picture when I get home and upload it. I thought your driveshaft is supposed to go all it can into the transmission?
#14352 |
![]() Join Date: May 2009
Need a complete s13 long block , came across sr20de for cheap is there any difference in the de and det other than a turbo and the coilpack setup. Thanks!
#14353 |
![]() Join Date: Jun 2009
It goes all the way in, then maybe out a half inch to an inch or so. If you were supposed to put it all the way in it would be a bitch to get it onto the diff.
#14354 |
![]() Join Date: Jan 2013
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
What is the size and pitch of the screws used for S13 Headlight surrounds? I bought my 240 without them, I found a pair but I don't have the screws to mount them.
#14355 |
sorry guys I gave it another shot and it turns out that the driveshaft bolted up nicely. So my non abs driveshaft worked w/the JDM s13 vlsd I bought. Thanks for the help.
#14356 |
so i had to re pin my maf plug on my chasebays harness, now the car starts and idles fine but ,when it starts you can hear the idle kinda catch itself and pick up to where it will idle the whole time its running, my tach isnt working so im not sure exactly where its idleing at but it sounds kinda high .
also when i turn the motor off everything is really hot , even my intake manifold ,EVERYTHING .when i adjust the iacv to all the way closed it still idles the same .my temp gauge isnt working right either.the gauges where working the first few times i started the car then they stopped , fuse maybe? so my questions are , where is the link that someone posted here before to show how to properly pull codes? why is my car not responding to closing the iacv? why is my motor so hot? i have a thermal intake spacer gasket on but its still super hot . it acts like its trying to warm up the whole time its running . any help would be appreciated . btw its a redtop sr, stock injectors and stock sr maf, walbro fuel pump . im hoping more of my chasebays harness will not need to be re pinned ,and that this is just a leaky injector or a bad ect sensor? thanks zilvia . |
#14357 | |
Does your radiator get hot? Do you have fans directing air over your radiator?
#14358 |
I'm having coolant smell inside the car. No leaks inside the car. I'm thinking maybe the heater core is going out but hasnt crapped out to full leakage OR turbo coolant line is leaking and is burning on some exhaust pipe.
Anyone have a similar issue with a resolution? Thanks! G. |
#14360 | |
It may be leaking from just a tiny pinhole, so it doesn't have to be wet on your carpet to be leaking inside the car. Also, are you losing a bunch of coolant.
#14366 |
![]() Sent from my SGH-M919 using Tapatalk 4 Beta |
#14368 | |
![]() Join Date: Sep 2010
#14370 |
Its a 1990 s13 stock sohc I thought there was no diagnostic port? Ive been pulling codes through the ecu according to led flashes.
