05-03-2010, 11:00 AM | #1351 |
05-03-2010, 11:52 AM | #1352 |
so if i dont use the automatic brake booster..will there be a difference in the pedal feel? will it be more firmer without the brake booster? In another word will it be necessary to use the brake booster? FYI..my setup will be 30mm 300zx up front and stock rear brakes with the altima rotors/z31 bracket? if that will have answering my questions..
05-03-2010, 01:52 PM | #1353 |
not giving a fuck
Trader Rating: (104)
Feedback Score: 104 reviews
what is the PROPER way...to convert R12, to R134?
LOL 240... whats better than 1? 5 1's ...lol PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r |
05-04-2010, 01:18 AM | #1356 | |
Bandwagon.
im running 215/40 on that size wheel. and i needed to roll and very tiny pull, not much but just a tee bit, unless you wanna be jdm and let it run go for it lol. |
05-04-2010, 01:26 AM | #1357 |
Trader Rating: (50)
Feedback Score: 50 reviews
does anybody have a pic of the grommets used to attach an s14 oem kouki side skirt to the under body.?
or know another method to attach them besides using the original clips and grommets.?
wtb s14 roof wing/spoiler! pm me |
05-04-2010, 01:41 AM | #1358 | ||
Bandwagon.
lol, self tap screws. |
05-04-2010, 02:12 AM | #1360 |
Trader Rating: (44)
Feedback Score: 44 reviews
this is on my s14 rhd.
its under the dash, to the right of the steering column. has a grey single wire coming from it, but its cut. what does it do or what? this is an s13 clip, but you get the idea. the part on the top pic goes bolted on this part of the bottom pic
taking corners just as good as a drunken rhino.. Last edited by miravete; 05-04-2010 at 02:35 AM.. |
05-04-2010, 08:55 AM | #1362 | ||
And yes, use the brake booster. Find a shop equipped to completely drain the system of r12. Then, they will recharge it with 134. There will probably be a nice conversion/disposal fee. Quote:
I have ZERO rocker rust and plan to keep it that way. I am going to two-sided tape the hell out of them. Get the good two-sided tape (3M from autobody store) if you go that route. Another member on here said he taped his successfully and has no issues. Removed and reinstalled and still good.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
05-04-2010, 09:53 AM | #1363 |
quick question cause i need it now before i order new belts.
what is the part numbers for the Gates SR20det alternator belt and power steering belt
18g and 20g turbo users click on me http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html |
05-04-2010, 11:00 AM | #1364 |
hey guys, i have a cooling problem. my temp gauge says i'm running hot, but no signs of overheating
SPEED KILLS!! Drive a Honda and live forever!! |
05-05-2010, 07:39 AM | #1365 | |
To get better help, you have to give better info.
BRICKHOUSE PRODUCTS
05-05-2010, 10:34 AM | #1368 |
Yes you can
My shoe is undesired |
05-05-2010, 11:38 AM | #1371 |
Im currently rebuilding my Sr, I honed my cylinder walls and got my new pistons and rods in there and really just wanna get this thing going, but my dad says I should sun-hone them, magnaflex and boil the block..Is it really worth it?
05-05-2010, 12:39 PM | #1372 |
Trader Rating: (26)
Feedback Score: 26 reviews
Right under the center of the exhaust manifold. It may be dirty so wipe around and look for it.
You definitely should, you'll thank yourself (and your dad) later. |
05-05-2010, 03:38 PM | #1377 | |
PS - K040345
.com |
05-05-2010, 06:58 PM | #1379 |
to adjust camber, you spin the middle (biggest nut)? is this the correct way to set up ruca? or does the heim joint thread part needs to come in more? which side of the toe arm do i adjust? do the one futherest away or the one close up? |
