#13682 |
![]() Join Date: May 2011
Just picked up an RB20 2nd gen.... the ecu says it offs an R32 GTST but I wanna know if u can tell by the motor if its off the R32 or the cefiro... anybody know how u can tell by just the motor?
#13683 |
Keep searching for an sr20 wiring harness kit, all I keep finding is the one wiring spec sells... Which happens to be back ordered till 2023 lol. Anyone know of someone else that makes one? Thanks!!
Wat |
#13685 |
for sr20 skinny oxygen sensor wiring...the sensor has a red, white, and black. my harness has a black, black/gray, and a brown/gray...which do i connect to which?
#13686 | |
You can also check out Chase Bays for their harness Chase Bays Engine Harness - Nissan S13 SR20DET - Nissan 240sx - ChaseBays.com |
#13687 |
Im currently doing my 5 speed swap on my 1993 240sx KA.
I dont want to have a bunch of cut wires and wire plugs all over my car and engine bay. I would like to know if anyone can point me toward a detailed write up of the s13 auto trans wiring harness. I wanna know what i have to cut to complete the swap and what i can remove completely. I plan to remove the harness from the car, split the tape open, remove the un-needed wires and re wrap it all back up. I also plan to actually harness all of my plugs back in so that they aren' just spliced wires. I have also began to remove my emissions equipment. I noticed that my AIV will have a wire harness left over. How could i plug this and be sure that it wont effect my car at all? Any help is appreciated and a quick reply will also be very helpful. I will be completing assembly in the morning. Thanks guys. |
#13689 |
![]() Join Date: Jun 2007
Trying to take off everything that may be useful for my brake swap off this z32.
Got calipers, rotors, lines to the body, and brake master cylinder. Anything else??? I'll be doing the rears too, so maybe e-brake parts? ![]() Was planning to get the dust shield covers but I think the whole hub has to come out for that. |
#13690 | |
#13692 | |
I hope that rambling helps. Good luck. |
#13694 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Unsure what you're asking here...
#13695 |
Trader Rating: (58)
I'll be the first to admit that RP sucked big time once temps got up. GL4 MT90 works best.
#13697 |
i hope you have gl4 fluid cause gl5 is gonna eat your syncros real quick
street dancer. GLEAM |
#13698 | |
minus the fact that any simple swap won't work with the braking ratio between s13/s14 rear calipers and z32 master/fronts, the z32 rears/ebrakes are far better than the shitty single piston caliper. the rotor is bigger which means better leverage on braking, as well as more pistons means more clamping force. The ebrake has a greater braking surface that the pads themselves, plus they won't warp the rotors when cooling. yeah, theres more parts which means its kind of a bitch, but unless you don't know how to learn anything then its not hard figuring it out.
#13699 | ||
![]() Join Date: Nov 2011
![]() Feedback Score: 13 reviews
It's just that most people don't know how to do the rear right or how to adjust the rear e-brake properly. |
#13700 |
So i have an Isis intake manifold with the stock throttle body.
the FMIC piping cold pip i have is for stock intake manifolds. what coupler can i use to make the cold pipe fit on my car? |
#13701 | |
#13703 | |
PS- Don't forget the Brake Booster also. It improves brake pedal feel. |
#13707 |
What would the perfect pipping size be for a KA24DE be? I currently have stock exhaust manifold to a test pipe and a buddy club spec 2 which is 3". Would running 2.5 be better?
#13708 | |
Also, what is the point of getting the hubs? |
#13709 | |
the hubs have an adapter plate that is needed to run the z32 anchor bolt, if you don't want to get the hubs LMK i have adapters i made that i can replicate for you, if you want. in all honesty, just take everything from the brakes that you can. ebrake lines, soft lines, calipers, rotors, master cylinder, everything. if you don't need it just throw it out later, but once its gone you cant get it back. IIRC the one i have is a 8mm 12-point socket, 5/16 12point works a bit better. if you are super anal, you can do what i did and cover the insides of the socket with some liquid electric tape. let it fully dry and it'll act as a rubber shield from fucking up the paint on the work hardware (some hardware is plastic and the paint flakes)
#13710 |
Locate your MAF. Look down about 8" and back about 4" for a little silver A/C line. See the little thing that looks like a tire valve?(It may have a cap on it). I also may be hidden by the airbox or the filter. If you are running an Injen type it's right there by that, but lower and farther back
