#13561 |
![]() Join Date: May 2011
so i just swapped my s13 sr into another shell, and i went to fire it up for the first time today in class (its sitting on a lift at school where i work on it) and the fuel pump doesnt turn on, starter doesnt click, etc. but i have battery voltage at the starter and all the relays, and the ignition. there's some relay inside the cabin by the fuse box that buzzes whenever i try to start the car. either im forgetting a ground somewhere, that relay is bad, or maybe my ignition is bad? any one have any ideas?
#13562 | |
anybody know? |
#13563 |
![]() Join Date: Jun 2009
![]() Feedback Score: 11 reviews
Got 99 probs and my battery relocation is one
Basically I bought a nice coupe a while ago with a haggard ka-t setup. I pulled it all apart and got it put back together NA for now. Well the car had the battery relocated to the trunk. I got everything put back together today and go to start it and I'm getting 0 power. No headlights, no dash lights, nothing. It's like the battery isn't even connected. I know the battery cable is good going from the engine bay to the battery, ground from the battery to chassis is good. The ground cable in the engine bay is bolted to the battery tray, then intake mani but the oem terminal is just chilling. There are also 2 aftermarket wires coming off the positive terminal connector that are maybe a few inches long. One was for an amp the po had in the car, and the other I can't recall. I'm sure I cut it off of something though. The car started up everytime when I bought it and had no issues. I'll grab some pictures in a second.
#13566 |
![]() Join Date: Dec 2007
Is it possible to run coilovers made for another Nissan on an S13 with few modifications or parts from the original intended application? If so, what chassis and what parts are needed to make it work?
BOOYAH! |
#13568 |
all my stuff worked when i took it out of the other car, thats the thing. im even using the same harness's. but the starter won't even click or anything either. just the relay inside the cabin. someone has to have had a similar problem that can help us.
#13569 | |
![]() Join Date: Jul 2006
![]() Feedback Score: 14 reviews
#13570 |
How about you tell us what one you want to swap around and maybe we can help you see if they work? mmmmmK?
* S14SR22 * 9.0 c/r * GT3071R * |
#13571 |
i removed my heater,blower,and just looped the coolant lines back into eachother , would this effect anything when bleeding the system? i assume i would just wanna jack up the front end like usual with a rad cap jug to keep adding as air comes out, any downside to not having the heater core and looping the lines back into eachother?
#13572 |
I've done several transactions with other members and the first time it let me leave a trader rating. Now it's telling me that I don't have permission to do so anymore. Am I doing something wrong?
#13573 | |
#13574 | |
No, he is very correct. Although 'rare' may not be a good enough excuse, 'I WANT IT' will always win out in the end. Why? Because when you set your car against another with a $200 dollar hood, same paint, same wheels that are currently 'hot', you win because of I Want It, because that $2000 hood is just different enough to make the car more noticeable. Did you settle fort the fat chick, or did you go all the way for the hot chick, because I Want It? Uh huh, wait, you went after the fat one didn't you?
#13575 |
![]() Join Date: Oct 2008
Trader Rating: (30)
![]() Feedback Score: 30 reviews
On a 97 240, the z3 connector for the airbags, horn, etc, (right by the steering wheel) there are 2 yellow wires that go on the top of the plug. Theyre not shown in the fsm from what ive seen and they dont seem to go anywhere. Is this simply a test point or am i missing something?
#13576 |
Sr20 aftermarket starters
Hey all, small question.... I think.
How good are the aftermarket sr20 starters? Which it's the best of them? I kinda searched but all I get are FS threads and junk. Looking for something that will be reliable and start my stroked SR23... THANKS IN ADVANCE Last edited by sr20detpl510; 04-30-2013 at 11:07 AM.. |
#13578 |
#13579 |
SR starters can be rebuilt using a 92 s13 ka starter from autozone. Ive done it twice. You can turn the old sr guts in as a core too. Just make sure to somewhat put it together first
#13580 |
What is needed/recommended to run close to 400hp. I've been piling up goodies to put into my sr20det redtop. Currently I have a Greddy tdo6 L2 20g turbo, Greddy Sus exhaust manifold, Greddy type s Waste gate, Freddy intake manifold, 850cc power enterprise injectors, tomei rocker arm stoppers, apexi 1.5 head gasket, circuit sport 7 layer exhaust manifold gasket, Arp head studs. stuff I still want to buy power FC, circuit sport intake manifold spacer gasket, circuit sport fuel rail, sard FPR... I have a walbro fuel pump, fmic, exhaust basic stuff on my car already.
Do you guys recommend any aftermarket internals to be on the safe side? If so what brand?
#13582 |
yea I was thinking CB stage 2 cams, but what about pistons, or rods. I've read that you start bending rods at around 350-400 hp. haven't read anything on the oem pistons.
#13583 |
Read the last 2 pages, weve been having about the same discussion
http://zilvia.net/f/tech-talk/124925...-new-post.html |
#13584 |
Anyone ever have a problem with a turn signal staying on constantly? Not blinking, just constant. The left green arrow on my cluster is always on when my lights are on. The turn signals themselves are also on. My light stalk is kinda finicky so there's a possibility that might be it. Anyone ever hear any other causes for this?
#13585 |
I've searched online but get random antenna and radio search results. I may be using the wrong terms.
S14 with factory power antenna and pioneer unit. My power antenna comes up when the cd player is on. Isn't there a way to have the power antenna powered only if I'm using the radio? Thanks in advance. |
#13587 | |
![]() Join Date: Nov 2011
![]() Feedback Score: 13 reviews
#13588 |
93 240sx
#1. nismo power brace? does it make a noticable difference? #2. have KA right now, i enjoy it and compression is great, but next year i want to swap it with something non-turbo maybe an inline6? need a few suggestions to get the ball rolling.
#13589 | |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
#13590 |
GRrrrr, Frustration sets in...
Where do I locate new fuse box labels for the underhood label for a 1996 240SX SE? I have found photos, took a photo of a friend's, but I want a new label and cannot find one on the 'net. Every search comes up with a photo of one on NICO Club All this over a dang passenger side door that stopped working during troubleshooting
