#13531 |
I'm trying to read up on steering angle stuff, but theirs so many factors I'm getting lost.
my car has all stock suspension except 2" lowering springs. For extra angle, I use tien (s13?) tie rods spacers(Which one do you guys recommend, or can I use washers?) Stock outter tie rods? Nevermind - I found a video that helped a lot. My new question is: Which outter tie rods do you suggest? |
#13532 | |
I have Kyoto JDM plates for Yashio factory, and 'Go for Death' that I sell on Forza4, also a Signal Auto one, but whenever I see a plate on a car from the 'net looking for Silvia's I always try to figure out where it is from. Got a Kyoto prefecture plate all made up for my Zenki too. Fake as hell, but from 20' looks real enough
#13534 | ||
2. If you put it on the lip, it may spray too high. If you put it on the more level area, it will spray the hood. |
#13535 | |
![]() Join Date: Jun 2012
#13536 | |
Yes a hole and I mean while driving
#13537 | |
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
DLG - DIRTYLOVE |
#13538 |
#13539 |
i was gonna do a painless setup for my chassis , has anyone ever done this before and if so could you tell me what i need to buy from painless to do so . thanks
#13540 |
Nothing if you don't hit anything.
If you aren't *trying* to do anything (drift, drag, hard park) and you don't know enough to know which direction to go in, then don't go wild. ALLLLLLLLLLLLL 240's have worn out bushings. Start replacing those. They won't cost you a lot and you'll learn a lot doing the work replacing them. |
#13541 |
can someone post a few pictures of the driver side fuse box of an s13 , most importantly the square plug wired right before the fuse box, it has a black wire that looks like a ground on it ,it used to plug into my old charge harness , the other side plugs in and has a white wire with what looks like the same kind of ground , does one of these attach to the starter or alternator?
i put on a chasebays engine harness and charge harness they told me there charge harness eliminates all the stuff on the oem sr charge harness . please help!! i just need the previously asked for pics and whatever else you think would be helpfull as far as chassis sub harness pics ,charge harness pics and fuse box plug pics . its a 89 hatch with a s13 redtop, chasebays harness and chase bays charge harness, i moved the chassis/fuse boxes behind the dash . i get no crank unless i touch the starter wires together ,and im not getting any fuel even a prime,and no check engine light on the gauge cluster. please help |
#13542 |
and yes i am going to drive it
#13543 |
#13544 |
Get a Exhaust Pipe sleeve style clamp, and Copper Exhaust Gasket Maker Permatex.
Cut the pipe where the hole is(you have to replace it later on anyway), slide the clamp sleeve on. Squeeze a line of the permatex on each side as close to the cut as you can. Squeeze a second line 1/2" away from it, the another 1/2 from that one. Hold the pipe together and slide the clamp and fit the clamp. Get it nice and tight, then wait for the stuff to cure, at least 8 hours. http://www.summitracing.com/parts/wlk-36439/overview/ Gasket Makers : Permatex® Ultra Copper® Maximum Temperature RTV Silicone Gasket Maker plus the permatex sets you back maybe $20...also similar is available at Autozone etc. This will work until you can replace the pipe...ask me how I know ![]()
#13545 | |
#13546 |
Does the SR20 Greddy oil pan generally come with stainless steel, 8.8, or 12.9 steel bolts?
Is it alright to use stainless steel hardware to mount the lower oil pan? I am not sure if I should order 12.9 hardware instead of the stainless bolts I have, or if they are fine to use. |
#13547 |
QUESTION!!!!!!
So today i had to replace the battery in my clifford car alarm remote. And i went out to go start my car (95 S14) and it wouldnt turn over, the dome lights wouldnt turn on. Nothing. So my guess is that the car alarm is killing the connection to the battery. The model of my alarm system is Clifford Matrix 50.5x I didnt put in the alarm or had it put in, they guy who i bought it from had it installed im pretty sure. Im reaching out here im desperate. |
#13548 | |
#13549 | |
And yeah today when I was under it I noticed the bushings are toast. I am saving to do inner tie rods+spacers. Should I upgrade the outter tie rods and the tension rods? |
#13551 | |
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 |
#13552 |
Well, don't disconnect it while driving, I think you would get hurt.
* S14SR22 * 9.0 c/r * GT3071R * |
#13553 | |
8.8 Minimum proof strength = 600 MPa Minimum tensile strength = 830 MPa minimum Yield strength = 660 MPa Material = Medium carbon, Q&T 12.9 Minimum proof strength = 970 MPa Minimum tensile strength = 1220 MPa minimum Yield strength = 1100 MPa Material = Alloy, Q&T Q&T means quenched and treated Minimum strengths are exceeded by 99% of fasteners
#13555 | |
I swear I saw the red car had windshield washer nozzles on it. I don't know... Screw it, I'll just get an M-Sports hood and not have to worry about a lip. Thanks for the response!
#13556 |
![]() Join Date: Jul 2006
![]() Feedback Score: 14 reviews
Bad ass hood for cars with some power underneath, needing some serious air flow. I went hunting around on the webs to possibly buy this hood and the cheapest I found this hood for is 1400 USD and shipping to FL via "ocean" was 821. As functional and pretty neat looking as it is, I can't justify spending 2k for a hood. A damn shame! |
#13557 |
![]() Join Date: Nov 2012
Will s13 pignose lip fit on s13 sharknose bumper?
Follow us on Instagram @Driftculture_ s14 Weekend Warrior s13 Drift Missile |
#13558 |
Hello fellow Zilvians. Quick question for ya.
Any ideas on why my coilovers squeak (on one side) when turning?? I'm pretty sure it has something to do the preload on my coilovers. Which i've been told by some should be zero, than others tell me i should use one coilover wrench (spanner wrench??) width of preload. Any suggestions? Thanks, I appreciate it ![]() |
#13559 |
#13560 | |
Reason: It's rare and I want it. There. lol..! You just gotta keep saving, that's how I see it. But if that lip is going to interfere with windshield washer nozzles, I'll have to consider a different one. I swear I saw that their red demo car had washer nozzles...
