04-20-2013, 06:57 AM | #13501 | |
Really, open it up, look hard at all the internal parts. Clean it up, and check the seals, syncro's, gear teeth, shafts for bends. If you find seals that are bad(you probably will) replace them. If you find other parts that need attention and do not have the manual, time, or ability, take it to a shop and have it rebuilt. You have two. My bet is you can make a deal with a shop for them to keep one and rebuild the other one for you. Then you have one GOOD tranny to put into your ride and not worry about. Of course putting tranny's in your car might also make you appear odd to your friends because those bitches are ugly!
04-20-2013, 02:59 PM | #13502 |
So, I bought an SR and the PO replaced the turbo oil return fitting with a threaded fitting that isn't going to work with my Tomei M7960. I new to replace it with the stock fitting or something similar. It seems like the stock fitting is a 1/2" BPT, would it be safe to use a 1/2" NPT?
04-20-2013, 04:22 PM | #13504 |
I got my flywheel resurfaced, the guy resurfaced it as a two step. So the flywheel isn't completely flat. Is that fine or should it be completely smooth?
04-20-2013, 05:03 PM | #13505 | |
1993 Nissan 240sx Instrument LED Replacement Bulbs | LED Lights for Cars | 12v | Super Bright LEDs |
04-21-2013, 02:21 PM | #13507 |
so i put recently did a chassis harness/fuse box relocation , all i did was unplug the chassis harness by the passenger side shock tower , pull it thru the wheel well on the drivers side ,organize everything behind the dash bar and put the tw0 fuse boxes over by where the glove box would be , i bolted down evry ground and hooked up my new chasebays harness and plugged it into all the proper chassis plugs , when i turn the key the fuel pump sounds way different ,kinda like its stuck or clogged, and when i try to start i get nothing.
any ideas? could the battery just need jumped? its new but has sat for about the last 6 months. any help would be greatly appreciated. also its a sr20det redtop,in a 89-90 chassis. it has after market cobra alarm on it aswell wich may or may not be completely installed at the moment.im lost Last edited by tengo240; 04-21-2013 at 02:25 PM.. Reason: added info |
04-21-2013, 07:35 PM | #13508 | |
BustedS13: anything you can hide on your person is free. junkyard law. |
04-21-2013, 08:27 PM | #13510 |
Can a OEM kouki 180sx body kit/style I.E (front bumper, side skirts, extra..) or the RPS13 body kit/style I.E (front bumper, side skirts, extra..) (i dont know the proper term every one says different things from it) but can it fit a 89 or 90 240sx s13? ive only seen it done to 91-93 240sx.
04-21-2013, 08:50 PM | #13513 |
no one answered my question so i think ill ask again:
okay quick question im about to do a 5 speed swap and on my manual tranny its missing a connector and also 1 or 2 are damaged (from the looks of it) could i simply snip the ones off the auto tranny after its removed and solder them on? so basicly my question is are the connectors the same between auto and manual?
04-22-2013, 06:28 AM | #13514 |
Looking to do a 5 lug conversion on my 93' s13. Just need to know if J30 hubs will fit s14 spindles? The guy I'm buying from has a s14 stock front suspension and J30 hubs. The s14 hubs are 4 lug. But I remember reading that s14 (4lug) and s14(5 lug) spindles are the same. Is that correct? Just don't wanna buy the wrong parts and waste money. Thanks for any help.
04-22-2013, 09:21 AM | #13516 | |
* S14SR22 * 9.0 c/r * GT3071R * |
04-22-2013, 09:22 AM | #13517 |
Cam Angle Sensor?
04-22-2013, 04:55 PM | #13520 |
Hey I bought a new shell but unfortunetly it was previously in an accident and the bumper support stud, that has the sliding adjustment, sheered off. Is there any way to remove the old stud and put a new one in? And I can't just use the front one cause that one is funky to.
04-22-2013, 05:14 PM | #13521 |
so i worked on a few things , it cranks now but no start, would that be the ecu not getting power? im gonna go over all the relays with a multimeter and see what i get, a friend suggested it is probly the engine harness?
04-23-2013, 04:20 PM | #13523 |
i have sr20derblack top the car had been sitting for over a year finally got it running! ran for a while. was cruising, was stepping on the gas pedal and could hear the turbo start to spool and feel this stutter and car looses power and dies,i pullover and see oil in the ground and my oil filter blew off . i put a new one in and filled it with oil cranks but wont start! what caused it to blow over boosting or what? help any one?
04-24-2013, 06:21 AM | #13525 | |
Bad news brah; you get to tear your engine apart and rebuild it Good news? Maybe you didn't break anything real bad, but if you have ever seen a 671ci 6 cylinder turbo diesel engine do this, it is spec...TACULAR! Freeze plugs blown out the sides, oil filter blown 30' away, and the noise, oh man, it sounded like a wookie just got shot or something as the engine died and the turbo spun down. Man, USMC does get to see cool shit once n a while!
04-24-2013, 06:24 AM | #13526 | |
Love my Zenki, but the RPS13 hatch is always sweet
04-24-2013, 06:53 AM | #13527 | |
Vehicle registration plates of Japan - Wikipedia, the free encyclopedia |
04-24-2013, 04:38 PM | #13528 | |
04-24-2013, 06:56 PM | #13529 |
wheel replating service? specifically getting one of my 18x4" lips re-chrome plated, does anyone know of a reputable shop? please.
04-24-2013, 09:02 PM | #13530 |
I was looking into getting this hood, and I to questions about her that I like some opinions on. Both questions are about the lip, or built-in spoiler, at the back of the hood.
1. do you think it would obstruct vision at all from inside the cabin? 2. It doesn't appear to have holes mounted for the windshield washer fluid nozzles, not like drilling new ones is any problem. Would the lip get in the way of the windshield washer fluid?
