Old 09-05-2017, 03:15 PM   #1231
Will.
Will.'s Avatar
Will. is an unknown quantity at this point
Originally Posted by slider2828 View Post
Man must be so awesome to drive at the track there in Australia!.... You going to WTAC? take some pics if you do... Jealous you have a S15....
Haha, i only live 15mins from Sydney Motorsport Park, I go to WTAC every year but probably not this year
Instagram: willssilvia
Will. is offline   Reply With Quote
Old 09-05-2017, 11:03 PM   #1232
BigKriss
BigKriss's Avatar
BigKriss is making a name for him/her selfBigKriss is making a name for him/her self
Track-2014-12-13-023.jpgKyalami-South Africa.
File Type: jpg 10509709_10152291905048565_2953320736051491429_n.jpg (61.2 KB, 37 views)
BigKriss is offline   Reply With Quote
Old 10-13-2017, 03:01 PM   #1233
battery1882
battery1882's Avatar
battery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enough
instagram : battery1882
www.sterculture.com
battery1882 is offline   Reply With Quote
Old 10-13-2017, 03:19 PM   #1234
slider2828
slider2828's Avatar
Dude that splitter looks sick. What material did you make it out of? How far does it go back? Any flex? So awesome!
Turn and Burn!
Old 10-18-2017, 03:44 PM   #1235
battery1882
It's made out of aluminum composite material (similar to alumalite it goes back to front subframe) with minor flex (flex at 140+ mph). i damaged it at the track so I'm doing a new one with custom apr carbon piece. I would recommend plywood if you are on a budget.
www.sterculture.com
Old 10-18-2017, 04:07 PM   #1236
SSJ-S15
SSJ-S15's Avatar
SSJ-S15 is a jewel in the roughSSJ-S15 is a jewel in the roughSSJ-S15 is a jewel in the roughSSJ-S15 is a jewel in the roughSSJ-S15 is a jewel in the roughSSJ-S15 is a jewel in the roughSSJ-S15 is a jewel in the roughSSJ-S15 is a jewel in the rough
SSJ-S15 is offline   Reply With Quote
Old 10-19-2017, 12:35 AM   #1237
slider2828
slider2828's Avatar
How much is that material and where do you get it from?
I really hate plywood cause I tried 1/2 inch and I still got flex... Need like 3/4? is what people usually say, but that is so heavy.....
any help would be appreciated to source this.
Turn and Burn!
Old 10-19-2017, 10:02 AM   #1238
gills
gills's Avatar
gills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the roughgills is a jewel in the rough
3/4" plywood is crazy. I've seen many people getting away with 1/2" birch plywood. I'd go over your mounting provisions and make sure everything is properly supported.
I've also heard great things about alumilite composite panel and probably what I'll go with. There's also stuff that's called Dibond that's similar, but it's not a strong as per anecdotal chatter.
]It's made out of aluminum composite material (similar to alumalite it goes back to front subframe) with minor flex (flex at 140+ mph). i damaged it at the track so I'm doing a new one with custom apr carbon piece. I would recommend plywood if you are on a budget.
What thickness did you use for that alumalite stuff? 3/8"?
Are you using an existing APR piece from another make/model or are you actually having them make one for you?
IG: core4motorsports
www.core4motorsports.com
gills is offline   Reply With Quote
Old 10-19-2017, 11:41 AM   #1239
slider2828
slider2828's Avatar
Yeah, its get away with but really even 1/2" home depot birch play is terrible.... Not a fan.
I can get dibond through someone local, but he said his all his supplier isn't carrying alumalite... Apparently its being phased out in signage industry due to cost....
Alumalite would be my first choice, but hard to find
Turn and Burn!
Old 10-19-2017, 11:50 AM   #1240
gills
gills's Avatar
You can always make it more rigid by skinning it in fiberglass and perhaps getting away with 3/8". Again, maybe you can make the mounting provisions more robust.
Keep in mind, nothing is going to be perfectly rigid. There will always be some flex, and even if there is, how much is it actually taking away from what you are trying to achieve? A small change in driver skill goes a much longer way than flex in a splitter.
Old 10-23-2017, 07:34 AM   #1241
Feast Japan
Feast Japan's Avatar
Feast Japan is an unknown quantity at this point
14's been on stanby all season and managed to get out just few weeks ago at local course in southern ontario. Car responded well to my winter updates; rear multi-link and solid member bushings out back, 2 pot rear brakes and 4.3 final update.
Feast Japan is offline   Reply With Quote
Old 11-06-2017, 01:23 PM   #1242
battery1882
i used 9mm. This was not light by any means. i think plywood would weigh about the same. i'm using APR carbon splitter custom cut and will be putting in on.
kit will be offered soon!
www.sterculture.com
Old 11-06-2017, 01:25 PM   #1243
battery1882
Originally Posted by SSJ-S15 View Post
pic
Good to see you here!
www.sterculture.com
Old 11-19-2017, 06:25 PM   #1244
NickIsAZero
Trader Rating: (41)
NickIsAZero is an unknown quantity at this point
Feedback Score: 41 reviews
NickIsAZero is offline   Reply With Quote
Old 03-12-2018, 09:53 PM   #1245
gills
gills's Avatar
I've developed, machined and have been testing/using some new brake goodies on my S14 VQ endurance race car that some of you road race guys may be interested in.
1st is a rear 2-piece rotor Wilwood BBK for OEM S-chassis and Z32 uprights that utilizes heavy duty Wilwood/Coleman 12.2" x 0.81" rotor rings, and a Wilwood 4 piston caliper that brings braking balance (among a bunch of other pros) back to ideal if you already have a front BBK (and are using Z32 rears). This is the only kit on the market that doesn't require you to chop off the OE upright caliper mounting ears.
The next thing is that radial mount caliper bracket I shared a few posts earlier that is now ready for production. Again, this bracket uses Wilwood FSL6R calipers (6 piston, staggered) to convert Defsport's front BBK from the Wilwood lug mount 4 piston FSL, or for those that don't have Defsport, this bracket can also be used with off-the-shelf Z33 track/brembo sized rotors and FSL6R's.
For more information on either, check out this thread or PM me: http://www.nissanroadracing.com/showthread.php?t=6186
Rear BBK:
Front Radial Bracket shown on Z33 track rotor:
Old 11-09-2018, 08:38 AM   #1246
240sx_sr20det
240sx_sr20det's Avatar
240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection
Hey guys, new to this thread, but not new to Zilvia!
Short story; started racing in 2014. Dove head first by picking up this Evo off a friend in Chicago. Drove 20 hours there and back straight to get it, I was so excited!
Drove all over the east coast with NASA, GTA, NARRA and local events - I loved going fast! My Evo was pretty reliable too. Stock Motor + Cams + Race Gas tune/ Ohlins/ TRE 12 disc diff and as LIGHT as possible. I loved this car! 280whp @ 2850lbs landed me in TT3 territory.
Won tons of Time Attack events, Time Trials with NASA, and learned so much! Had an absolute blast with this car. Unfortunately, it all ended when a shop I partnered with for so long parted out my Evo (With all new upgrades for the new season; new motor, rebuilt Ohlins, new AP Racing Comp Brakes etc and scrapped the shell. It was heartbreaking.
But, I have a new chassis to start with and I'll be updated my build thread with future plans and updates.
Here's my old Evo 8 RS..I'm sure you guys might be able to recognize some of these tracks!
http://www.youtube.com/watch?v=I_QKl0yaqwU
240sx_sr20det is offline   Reply With Quote
Old 11-09-2018, 11:08 AM   #1247
slider2828
slider2828's Avatar
How the hell the part out your evo? that is messed up... Was it owned by the shop?
Turn and Burn!
Old 11-09-2018, 11:17 AM   #1248
240sx_sr20det
Owned by me. They liquidated the company when I was in Japan. I asked for them to move everything to a storage unit (they closed within 2 weeks of announcing) and I told them I’d pay for moving, but the car was already stripped of its parts. $2500 custom dual element wing gone too. Brand new. Thrown away. So pissed.
Old 11-09-2018, 11:30 AM   #1249
derass
wtf?! did you get all the money from the partout? was the shop entitled to any of it?
Is the new chassis another Evo? Or an S-chassis?
Old 11-09-2018, 11:50 AM   #1250
240sx_sr20det
I got nothing and had to hear from a third party about what had happened. All of their employees that scrapped and took parts blocked me on all social media. I’ve been tagged in numerous FS threads of the parts.
I’ll be using a GTST Type M. Goal is 250-300hp. Light weight. Fiberglass panels, basic splitter, and single element wing. 245-265’s.
Old 11-09-2018, 11:58 AM   #1251
slider2828
slider2828's Avatar
look at battery1882 (hster here on zilvia)
Turn and Burn!
Old 11-09-2018, 11:59 AM   #1252
slider2828
slider2828's Avatar
Oh man... I would have been ready to come back to US with a sledge hammer and kick some ass... geezus......
What were you doing in Japan?
Turn and Burn!
Old 11-11-2018, 09:45 AM   #1253
gills
gills's Avatar
How in the hell does stuff like that happen?? So frustrating man. Sorry to hear about that happening, but sounds like you're getting back in the game.
Great pics from both of you though!
A couple of mine from the American Endurance Event at Mid-Ohio last month. First time at that track. Might be my new favorite.
Still running my front and rear BBK's. Accumulating 100's of hours on the setup.
Old 11-11-2018, 11:48 AM   #1254
240sx_sr20det
Interested in talking with you more about this BBK.
Old 11-11-2018, 07:38 PM   #1255
gills
gills's Avatar
Absolutely. I responded to your original pm regarding AER. Ask away in that convo.
Old 11-12-2018, 08:17 AM   #1256
Dolph_KYAS13
Dolph_KYAS13's Avatar
Dolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond repute
This past summer after years of drifting, I took it upon myself to give lapping a try and now have been bitten by the bug pretty bad.
I did the first track day with the car as is. Did a thorough bolt check, changed the fluids and bled the brakes. I ran it with used Zestino tires up front, cheap china tires in the rear and standard brake pads.
The car was a little loose but the 225s in the rear seemed to be enough to withstand the 230hp ish the car puts down.
The glaring issue was the brakes so before the next track day I upgraded to Powerstop Trackday pads all around. They worked really well considering they are 1/2 the price of Hawks but are noisey / dusty. The next track day I was more confident on the brakes and was able to progress a little more.
I think what I enjoy about lapping and trackdays is that you can see and monitor progression and find weak points in the car. I havent even tried timing myself yet.
I'm excited for next season (winter here now) as I have some Ns2r to try. And I think I will play it safe and install an oil cooler.
-Jordie Lewis
'93 Skyline Type M
Dolph_KYAS13 is offline   Reply With Quote
Old 11-12-2018, 08:39 AM   #1257
240sx_sr20det
Pads and proper tires (as well as correct/monitored pressures) will be the most noticeable change!
Love your car. Interested in hearing more about it as I plan to run my Type M as well. Can’t find too many Track Day GTST’s on the web. Many people just go straight to GTR.
Old 11-12-2018, 07:08 PM   #1258
Dolph_KYAS13
Thanks! The best thing is to just go out and try. It was a little strange being outside my usual element but just know the proper track etiquette and you'll do fine
So far, My friend and I have been the only two at the track with R chassis. Both GTST's but his is Rb26 swapped with about 550+ at the wheels. Its hard for me to keep up
-Jordie Lewis
'93 Skyline Type M
Old 11-14-2018, 08:01 AM   #1259
gills
gills's Avatar
Gorgeous man and welcome to the track club! It's definitely a strong hook.
Old 11-14-2018, 12:34 PM   #1260
slider2828
slider2828's Avatar
COngrats and welcome! Those look like two beasts.... Two things i always do now to prevent big issues.
Upgrade brake fluid and lines. Fluid Motul RBF600 and steel lines for sure. Helps a lot.
Pads are expensive, but you can swap them in and out after events. I love cobalt pads really and lot of confidence and no fade.
Also check all your hoses. If anything is older than 5 years, change them. One pin hole leak = blown engine.... Trust me I know :'(
But so jealous other people can run R chassis' on the street. Stupid california...
Turn and Burn!
