#1231 |
![]() Join Date: Jan 2012
![]() Feedback Score: 13 reviews
I'm picking up an r154 with 1j housing for 500. I know of another guy wants 500 buts it's 7m housing.
I've been kinda thinking of doing z33 trans. I find them usually for about 600ish for cd009. "Supposedly" just as strong as v160. I just want to kinda wait. And find people that have actually used/abused them. |
#1232 | |
Looking at my picture, how do we make it fit in a 240sx? Other than hacking up the tunnel and console? |
#1233 |
Shorten the shifter as much as possible, I think you can shorten them a good 4in if I recall right. I know I read somewhere to we're the xterra shifter assembly is a possibility. But can't remember. Be awhile, back when I was thinking bout this for my sr.
#1234 | |
This is taken from the ebay ad:
Sent from my LG-E970 using Tapatalk 2
http://www.youtube.com/boostedgt3567r |
#1235 |
Oh. Lol. I was thinking that was stock, which makes sense now that ima actually and and typing. Yeah, that def is a problem. I don't know how a custom bent/extended shift rod would be under the plastics.
Who's car was that, had an sr With is moved back into the firewall like 6". Weld racing? They had a pivot setup. Im going to see if Ivan find pics. But don't think it's really oem look friendly. |
#1236 |
Where should i look for Used and/or reasonable priced parts for my 2j? I need to pick up:
* downpipe for the stock twins * shifter for w58 trans * proper motor oil, trans fluid, coolant, and filter Please let me know what you can. Thanks guys |
#1237 |
Driftmotion usually has pretty good deals on downpipes. They sell fluids to.
A lot of people say to use the Toyota red coolant. They say it actually makes a difference. Shifter assembly, probably eBay or dealer. |
#1238 | |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
- shifter = Idunno - oil = I use rotella, trans = redline, coolant = TOYOTA RED (or equivalent coolant from world pac), filter = I use purolators (tundra filter is larger and basically the TRD version without the badge)
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#1240 | |
#1241 |
He didn't specifically say, but judging by the conversation, yes.
#1242 |
![]() Join Date: Mar 2009
got a question i have a kouki with 1jz single turbo. i have the ac working in my car. but when i run the ac the car starts to slowly over heat it takes time before it starts to over heat but it does.
soon as i see it start to go up i turn the ac off then in will come back down to half way on the stock gauge. im running the stock gauge cause i dont like gauges all over my car. i do have the 1jz temp sensor in witch makes me think the reading might be wrong. this happen to me back when i had my sr20 with a s13 temp sensor in a s14 and it did the same thing with the ac on. i get a s14 temp sensor and the problem was fixed never showed over heating again. im thinking im having the same problem here. anyone know if the 1jz tempo sensor will read the same output as a s14 temp sensor? this is driving me crazy and i want to fix this problem im running a mishimoto rad with flex-A-lite fans (2500cfms) and a pusher fan in front. but the motor runs hot as hell in these cars so i don't no. i know u all will saying get a after market gauge but i don't want that rig it up with a sensor in the water neck looking stupid. thanks Last edited by BadazzSr20; 01-12-2013 at 07:12 PM.. |
#1243 |
I tapped my water neck and used the s14 temp sensor and mine has never shown over heating. And I put it where the Toyota sensor goes so it doesn't look stupid, it looks factory
#1245 | |
this is what i wanted to do!! please details im going to get this done next weekend!!!also are u running ac and one last question are u useing the 1jz harness plug or did u change the plug on the harness to a s14 plug or does that not matter? |
#1250 |
best thing u can do is the same as 2jzs14 ill be doing this just fill in the stock 1jz temp hole and retap it with the tread pitch of a s14 temp sensor and boom your good to go. i just hope that this is the problem why i am seeing high temps when ac is on. when the car starts to show higher temps the car still drives and acts the same this is why im thinking its a fooling temp sensor. i wont know for sure till i install the s14 one. im thinking i have a great cooling system set up so i cant see it being that. i had my sr20det with ac and it was not over heating with the same set up. i did how ever had to change the sr20 temp sensor to a s14 one cause it was doing the same thing my 1j is doing now. |
#1252 |
sorry to derail the temperature discussion but I need a quick answer.
Has anyone used this style shifter successfuly on a 240sx? ![]() As you can see its placed back a bit, but not as much as the tripod. if you bent the shifter to a swan neck would it work? |
#1257 |
![]() Join Date: Aug 2008
![]() Feedback Score: 7 reviews
Some pics of my build ive been holding out, she runs good i just need suspension and front end and a few gauges hooked up. sorry for shitty cell phone pics
#1258 | |
If my explanation is kinda crappy shoot me a pm and ill be more than happy to give you a call and explain ![]() |
#1259 |
On my aristo water neck it actually had a plug and no sensor, I had to drill and tap it. On non vvti engines I'm pretty sure the sensor is there and it is bigger, mine definitely fits though. I don't recall the thread size. Ill take a picture tomorrow for everyone
#1260 | |
Thanks for this tid bit, I had pretty much accepted that my factory temp gauge was just not gonna work. I still think I'd like to have a gauge w/numbers (ocd) but I'll definitely be doing this as well. |
