#12061 |
![]() Join Date: Feb 2012
![]() Feedback Score: 17 reviews
From my understanding the middle port on z32 bcm doesnt come flared but after taking the alen bolt noticed that looks the same than the others.so was confused for a second and wanted to confirm before start bleeding the system.
#12062 |
![]() Join Date: Dec 2010
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
None of the ports are flared. The brake lines are supposed to be flared. Which they all are. They came that way. Only thing that should be flared is the middle BRAKE LINE if your BMC did not have the third fitting to accept the stock flare on your brake line.
Long story short your BMC has all you need. Bolt that bitch up |
#12063 |
Thanks for the help. Next questions ate cody ace a/c brackets still for sale. Ive been trying.to get in touch with him but.havent.got.any answers at all
#12064 | ||
![]() Join Date: Nov 2011
![]() Feedback Score: 13 reviews
Contact CodyAce SR20 Air Conditioning Bracket |
#12065 |
someone broke into my glove box and broke off the handle piece and the glove compartment is still in one piece. so i was wondering if i could get the handle for it somehow or do i need to replace the whole glove compartment
#12066 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
#12067 |
When cutting out my rear guards I went ahead and cut out the rear inner wheel wells ,so now you can see the wheels from inside the car ,anyways I cut off a bit of the metal that wraps around coilover/ shock tower ,not a lot just enough to flatten out the round part like the rest of the well .everything seems fine but did i weaken / lead to bending or warping over time of that shock tower .ill post a pic if it helps ,thanks
#12068 | ||
![]() Join Date: Feb 2010
![]() Feedback Score: 11 reviews
Sooooo I'm in the market for lug nuts and I'm trying to make my mind up.
I have extended arp studs in M12x1.50 pitch. So I need extended, open-ended lug nuts. But I also want lock nuts too. Any recommendations? I was looking at the WORK RS-R lug nuts. Any experience with them?
#12070 |
Hey, so I'm looking at some 5zigen rims 17x7. My question is... I love 17's on the 240, but would the 7 width be too small for that large of a rim? If so what's a good size? I'm not looking to go too hella flush. Just to look good. Thanks.
#12071 | |
![]() Join Date: Aug 2009
Trader Rating: (77)
![]() Feedback Score: 77 reviews
If you track your car a lot and have to change your wheels often, i recommend the steel ones instead since they're much stronger and more durable. |
#12072 | |
Trader Rating: (77)
There are plenty of fitment threads out there for you to leark around. |
#12073 | |
#12075 | |
If you want speed, hardcore reliability and want to use a gun, get American made racing lugs at Summit Racing made of tool/forged steel...then you can air gun all you like and replace studs instead of lug nuts...and yes, I get ya, those tuner lug nuts are hella high on price, but they do look nice ![]()
#12076 |
So there is a new goodie coming from RS Enthalpy for S14's with NA/KA's... 3" S13 AFM to give better intake and reading performance for the tune(the little black box behind the air filter)...waiting for Friday!
#12077 |
![]() Join Date: Nov 2007
Trader Rating: (33)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 33 reviews
So...tonight i filled up on fuel and went to tighten my gas cap and it clicked once and started spinning freely. Tried taking it off with no luck. How would i go about removing it or am i screwed lol.
#12079 | ||||
Trader Rating: (58)
As stated a few times above, you need to look at your application and usage. If the wheels are going to come of more than 2x a year, i'd opt for steel lugnuts. With that said, I'm on the same Carquest lugnuts since day one. Wheels have been off countless times, with multiple air guns and sockets. ZERO issues. Sure they aren't fancy shiney purply colors, but they work, and don't fall off when I'm cranking 5th gear at the top of the esses at Watkins Glen. I know it may not score modification or JDM points, but I'd rather my wheels stay on...and not worry about their color or lightness. Quote:
Take a small pry bar/screwdriver under the cap and unscrew. Should help.
#12080 |
anyone know the ID and OD of the bearing in their camber plates? specifically megan racing camber plates?
looking to replace mine but I cant find a write up or detailed info on which bearing to use... |
#12081 | |
Polishing(the above is the 'Porting') allows the work done in porting to remain smooth through the motor, or cause swirl where it is needed. It also allows better, more even detonation free fuel burn in the combustion chamber(IMPORTANT HERE) by removing the casting marks, and machine marks from the head, this process smooths out the combustion chamber allowing the fuel to burn fully, and faster. This causes better power delivery, and also stops detonation in higher compression motors running crap gas. Answering your question, YES. The hp numbers won't be huge, but maybe 1 or 3 here and there across the range, and torque numbers will broaden and smooth out. The BEST RESULT, though, will be the way the motor performs and runs. These processes smooth out the motor causing less vibration which translates to free power, better mileage, and performance and QUALITATIVE feel This operation takes time and money, but is well worth it in the end when reliability is desired
#12082 | |
The wire diagrams for a 95 and a 96 are different, and systems are on different pages, but many of the pages, although numbered differently have the same information with the exception of OBD I, and OBD II information. If you have a 96 that was manufactured pre run(before April 95) you will have OBD I and the same diagrams for a 95 will apply. If you have a 96 made after April 95, you will require the OBD II wire diagrams. NICO has all of them
#12083 |
My friend has a SR20DE of a S14 but he for a everything for it but not the wiring harness, what kind of harness would I need to us this motor on my 93 S13. Also would it handle boost if I decide to run boost on the motor?
#12085 | |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
#12086 |
i know there are two types of crown vic meshies. and im gonna go 5lug soon and will be getting these. can anyone tell me the sizes. i searched and only found the 16x7 +6 is there another size thats bigger with better offset? thanks zilvia. oh and pics will be nice too.
#12087 |
hey guys im wondering how i can connect my EXTERNAL wastegate .. okay i understand that wastegate has a nipple to boost controller, and a vaccum/vent nipple.. my turbo doesnt have a nipple to connect the "pressure hose.. can i jus connect or split a t on my hose that goes to my gauge or BOV? my pipingdoesnt have a nipple either.. please help me outt !!
#12088 |
Can any1 tell me the size and length of the adjusting bolt for the AC compressor?
For S14. Thanks in advance.
Rock wha U jock and don't talk if U ain't got!! ![]() ![]() |
#12090 |
![]() Join Date: Jan 2012
could anybody please tell me what front bumper this is? I will be getting a front bumper for my s13.5 over winter and I like this one alot. I have origin stylish sides and rear so I feel it will flow fine with the origin aero... thanks for the help, I appreciate it!
