#1171 |
also looking on other opions on where to go with the car from here? as far as motor work. what are good upgrades to start with? i want to get a good strong running motor before i go and try to drift the car. if that is what i decided to do with it
#1172 | |
![]() Join Date: Dec 2007
![]() ![]() Feedback Score: 1 reviews
WARNING: User has a low tolerance for stupidity. Post at your own risk. |
#1174 |
550cc injectors a fpr and z32 fuel filter and dont forget to have your car to have your car professionally tuned and you will be ok.
#1175 |
rb20det stock
I want to replace the top intake manifold with side intake manifold and to put fmic with short piping runs just like rb26 setup. Can you guys tell me who makes quality intake and fmic? |
#1183 |
alright guys im going for 400hp ( yes ive read up) i just bought a holset hx35w turbo, question is does it bolt up to the stock manifold? also what type of 750 cc injectors should i run? and i am getting a z32 maf and a safc tuning setup. anything else i would need?
#1184 | |
Zilvia.net GB Vendor
![]() Join Date: Apr 2006
Trader Rating: (65)
![]() ![]() ![]() ![]() ![]() Feedback Score: 65 reviews
What motor? Food for thought Im doing borg Warner EFR 7064 IWG, stock mani, 555cc RC, FPR, modded jun syle mani, aeromotive pump 340. z32 maf and rare PFC for the rb20. NEVER use a safc go PFC, rom tune or Haltech if you can get it to work for the rb20 |
#1186 |
alright my man yes its a rb20 , this is what i bought today! hx35 ( rebuild for 300 bucks 0 miles) 850cc injectors, walbro 255. next things i need is a pfc, rom tune or haltech. any recommendations on any of these and which ones i should go with? ALSO i want to get some ls truck coils would they work with the stock ecu even though the dwell time is much higher than stock? buddy of mine wants to sell his set pre wired for 200.
#1187 |
#1188 |
![]() Join Date: Nov 2011
OK, HX35 on a RB20 will spool fairly slow. What exhaust side is on it currently?
Check out here for another example. http://zilvia.net/f/showthread.php?t=543836 Also, thought I said the turbo will bolt to the manifold (both T3) there is a clearance issue with the valve cover. A spacer and longer studs will give the needed .5 to 1 inch.
S14 RB25 |
#1190 | |
Rb faq
Meant to quote you but it's stock exhaust Sent from my iPhone using Tapatalk |
#1192 | |
There are a lot of reasons to upgrade to the RB25: They are newer They provide more torque You can make some serious power RB25 transmissions are almost bomb proof. But, having a holset HX35 should not be your primary reason. Here is another good thread here on Holset use. Even shows an RB25, Holset HX35, and spacer, with stock exhaust manifold http://zilvia.net/f/showthread.php?t=429571
S14 RB25 |
#1193 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Alright I'm in need of a Rb guru. The machine shop I brought my Rb25 block to , punched out these plugs in the block to fully clean it. Now it's not any welsh plug, it's an iron plug either for oil or coolant. It goes straight through the block and there is 2 plugs, the front port is by the bottom large bolt on the water pump and between the oil pump, the back port is right above the rear main plate on the intake side.
If anyone knows where they can be sourced it would be very helpful! My last option is to have a machine shop lathe me up two plugs but if they sell them it would make it easier. Thanks!
#1194 |
Found an old post that might help. Otherwise wait for those more experienced than me.
http://zilvia.net/f/showthread.php?t=259011
S14 RB25 |
#1195 |
Anyone have any experience with hx35 and r.s. Enthalpy tune? I have his tune for my stock setup plus no maf and it runs good, but anyone with major upgrades and his rom tune?
#1196 |
Hey guys I'm going with an RB20 swap soon, and I have a couple of questions.
Is there a difference between using an R32 crossmember vs aftermarket mounts like the mckinney mounts? I've heard with the mckinney mounts I need to make room for the starter. Secondly, with a wiring specialties harness I'll be using the RB20DET ECU or the Stock automatic ECU my s13 came with? |
#1197 |
RB25DET
I have strange idle surge problem that comes and goes. I have noticed that it will start to surge when i turn on the wipers. It was worse before but after cleaning the Idle control valve it has gotten better. It is totally random, also in order to stop the surging i would have to rev the motor a little until it no longer surges. Really annoying. Any guesses? |
