Old 07-17-2016, 09:29 AM   #91
Nismoboy1992
Nismoboy1992 is an unknown quantity at this point
Hey guys, wondering if you have some insight on this. I am currently doing this 350z trans swap on my ka-t. I literally got everything in and then the starter doesnt fit... I am using the autotech motoring ka to 350z trans adapter plate. The starter hits up against the 350z bellhousing... I took apart a ka starter and used the starter gear as reference and it looked like a whole section of the bellhousing needed to be cut out! idk if the other adapter plates have this problem. The autotech motoring website didn't say anything about it.
Nismoboy1992 is offline   Reply With Quote
Old 07-17-2016, 10:26 AM   #92
roninwon
roninwon's Avatar
roninwon is an unknown quantity at this point
Send a message via MSN to roninwon Send a message via Yahoo to roninwon
From what I heard you're suppose to notch the starter with a grinder or dremel
roninwon is offline   Reply With Quote
Old 07-17-2016, 10:39 AM   #93
Nismoboy1992
Do you know which part of the starter to notch? If I can notch the starter, I'd much much much rather do that. I sure as hell do not want to pull this transmission back out lol.
Old 07-17-2016, 11:19 AM   #94
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
Pretty awesome thread, great amount of information here. Thanks to everyone that contributed!
Old 07-18-2016, 11:54 AM   #95
S-Verteen
S-Verteen is an unknown quantity at this point
Nismoboy92 for my kat cd swap with the Collins adapter I've found clearance on the starter itself isn't sufficient. This lead to me opening the housing where the cone hits 3/4 to 1".
S-Verteen is offline   Reply With Quote
Old 07-18-2016, 12:40 PM   #96
TheRealSy90
TheRealSy90's Avatar
Originally Posted by Joobie View Post
I'm personally using a CD001 transmission out of a v35 Skyline that has been upgraded with the CD009 synchros and throwout fork/pivot. Managed to get it cheap because of the number written on the side. The donor car had 60,000kms (40,000miles) when it was written off, and the internals look brand new (I was informed that the gearbox was rebuilt with the update kit not long before the car was crashed).
You cannot install a CD009 synchro set into a non CD009 transmission. It does not fit. I don't know what this "update kit" is that you're talking about but that trans was most likely rebuilt with the regular synchro set it came with. I asked the owner at Extreme Auto Concepts in Phoenix about this and they specialize in 350z's, he said he tried it before and the parts just won't work.
Such a good signature.
Old 07-21-2016, 10:07 AM   #97
roninwon
roninwon's Avatar
Alright guys. Talked to Jason over at cbfperformance today and there is still 44 rear mount shifters available for $185. Let's help out a small business and buy quality American parts!
Currently on sale for a group buy at $185
http://www.cbfperformance.net/store#...egory=19722030
Old 07-21-2016, 10:11 AM   #98
TheRealSy90
So anybody have a working speedo yet with the cd009 swap? I'm debating over which route to take on this.
I should be able to run a front abs knuckle sensor to get a speed signal from it.
Also LOJ offers a speed sensor kit that goes on the front yoke of the driveshaft, however at $300 it's a bit pricey.
This brings the question, better to pull speed from the rear/driven wheels or from the front wheels?
In the grand scheme it's best to have BOTH so that you can take advantage of traction control if your ecu supports it...
I'm leaning towards the driven wheels since that's how a regular s13 speed signal is pulled... But that's the most expensive route too.
Old 07-21-2016, 10:17 AM   #99
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
/\/\/\/\ I plan on using this, but I have a stack cluster, may or may not work with oem
http://www.autometer.com/gps-ground-...se-output.html
Old 07-21-2016, 10:43 AM   #100
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
I'm attempting to use what I posted in the last page, hopefully wiring it up this weekend. Otherwise if I don't have time, at some point after SSC I'll get it figured out.
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 07-21-2016, 02:16 PM   #101
Joobie610
Joobie610's Avatar
Joobie610 is making a name for him/her selfJoobie610 is making a name for him/her self
Like I said, I was informed that it was rebuilt this way, i didn't do the work or have it done. I would imagine that was the explanation given to the previous owner by whoever rebuilt it.
If someone else has tried it and it doesn't work, educated guess would be the cd001 rebuild kit has revised parts that mimic the Cd009 kit, strengthening it to withstand the same/similar punishment.
Sent from my E6653 using Tapatalk
Joobie610 is offline   Reply With Quote
Old 07-21-2016, 04:24 PM   #102
TheRealSy90
Haha anyways good luck with that 001.
Looking forward to seeing who gets their speedo's working.
Supposedly the AEM Infinity ecu might be able to convert a speed signal thus eliminating the need for the Dakotah converter, but I haven't figured this out yet for sure as I'm waiting for mine to come in.
Old 07-22-2016, 05:41 AM   #103
SidewayzAsFck
SidewayzAsFck can only hope to improve
So I am picking up a cd009 this week for my sr20det build. After doing some looking around I am between the CBF performance shifter bracket and the gktech unit + trans mount. Anyone able to give some feed back on the two units (from personal use)? I just want I make sure that both units actually place the shifter in the correct location for a s14 chassis as stated by the manifacturers. I also have the autotech adaptor plate and a s13 sr20det
SidewayzAsFck is offline   Reply With Quote
Old 07-22-2016, 08:16 AM   #104
roninwon
roninwon's Avatar
Several people have bought cbfperformance rear mount shifter and it fits perfectly in s chassis. The gktech one was built specifically for s chassis. I'm going with CBF cause it looks beefy compared to the gk one.
I also have the xcessive trans mount and i am very happy with the quality
Old 07-22-2016, 08:37 AM   #105
Kylepaschke
Kylepaschke is an unknown quantity at this point
I am using the CBF shifter and it works out really well. Its also 100% made in America so I personally value that. I also have had a great experience dealing with Jason, the owner of CBF; throughout the entire process
Kylepaschke is offline   Reply With Quote
Old 07-22-2016, 09:57 AM   #106
Yellow4g63
I got the gtech unit. It's at the post office tho need to go fetch it soon.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Old 08-01-2016, 10:40 AM   #107
Nissansota240
Got a perfectly working speedo, will do a lil write up later this week .
Sent from my SCH-I545 using Tapatalk
DLG - DIRTYLOVE
Old 08-01-2016, 11:22 AM   #108
TheRealSy90
Got the Gktech shifter myself. Really cool piece.
Old 08-01-2016, 12:01 PM   #109
EnvisionMore
EnvisionMore is an unknown quantity at this point
Any more info on shifter relocation kits using a 2J/1J engine? Not many people out there running the setup
EnvisionMore is offline   Reply With Quote
Old 08-01-2016, 12:06 PM   #110
RickS14
RickS14's Avatar
RickS14 is an unknown quantity at this point
The everything cd009 swap thread.
It's gonna be off. But I think it if you cut the shifter and bend it forward you could get it in stock location under the boot trim and centered. Check out the 2jz swap thread someone has posted pics already. As fas as the gktech one goes.
RickS14 is offline   Reply With Quote
Old 08-01-2016, 12:08 PM   #111
TheRealSy90
CBF has shifters that work for 1j/2j Cd setups that are further forward than the Sr/Cd shifter.
Old 08-01-2016, 12:09 PM   #112
Freddy
Freddy's Avatar
Freddy is an unknown quantity at this point
Check out Serial Nine pretty sure they once
How much do CD009 got for states side?
Freddy is offline   Reply With Quote
Old 08-01-2016, 01:41 PM   #113
Nissansota240
DLG - DIRTYLOVE
Old 08-01-2016, 01:57 PM   #114
RickS14
RickS14's Avatar
$450.00 for the shifter they offer.
Old 08-01-2016, 02:00 PM   #115
RickS14
RickS14's Avatar
Wonder if you can just modify and cut the shifter to make it sit forward.
Old 08-01-2016, 02:28 PM   #116
TheRealSy90
Better off with the CBF shifter for a Jz setup they have two different ones that are both further forward than the Gktech.
Old 08-01-2016, 03:03 PM   #117
RickS14
RickS14's Avatar
I would like the input on the cbf.wonder how the throws feel also from left to right. Seems like gktech took a while to release what they offer because they did a fair amount of real world use. Plus the unit looks pretty solid.cbf doesn't seem to have any lower support like serial nine and gktech shifters do. I'm a doing a 2j s14. I'm really thinking about keeping my gktech and just modify the shifter.
Old 08-01-2016, 03:26 PM   #118
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Serial N9ne has the most versatile shifter option out there. Multiple configurations in one unit.
https://instagram.com/e_lemonation/: @e_lemonation
Old 08-01-2016, 04:42 PM   #119
TheRealSy90
Yeah the Serial 9 shifter reminds me a lot of the K-Tuned D series shifter I had on my old ef civic. Adjustable in many positions. Was a rad piece.
Old 08-01-2016, 05:29 PM   #120
MattTenFour
MattTenFour is an unknown quantity at this point
I bolted my Collins adapter to the SR this weekend and I'm a little confused about something. Collins instructions say to grind down the starter to allow clearance for the transmission housing. I've seen pictures of other people's swaps and I'm familiar with what is required. I was able to bolt my starter up without any modifications and it appears that it will work just fine. I shared some pictures with a buddy that has an older Collins adapter and its clear that the new plate is designed differently. Has anyone else used one of the recently released Collins SR to CD009 adapters that can confirm if that is correct? Collins wont reply to my emails or texts.
MattTenFour is offline   Reply With Quote
