09-13-2012, 11:58 PM | #92 | |
Trader Rating: (79)
Feedback Score: 79 reviews
Thanks man!
My Build: The "Coupe De Ville" 1JZ Build!! |
09-17-2012, 01:40 PM | #93 |
Trader Rating: (79)
Found a Poster girl while I was on Instagram HAHA
09-23-2012, 09:28 PM | #95 |
unless my eyes are playing tricks on me, it looks like you're going to need to shim that diff. I bought a used tomei 2way diff with 4.36 gears, and it whined real bad when I installed it. I pulled it out, and without even using paint I could see the terrible contact points on the ring, right on the outside. whoever had put the diff together used factory shims and didn't check it.
regardless, build is looking awesome man! just finished my holset 1j swap into my 180sx. Absolutely nuts. you're going to love yours when its done |
09-24-2012, 04:29 PM | #97 | ||
Trader Rating: (79)
Thanks, but I got a Diagram from a Guy & he seems real legit so im going to see how things work out
09-27-2012, 06:04 PM | #99 |
Trader Rating: (79)
Well I guess I'll find out I pretty much have it done, just need to make sure it works lol
09-28-2012, 09:16 PM | #101 |
Trader Rating: (79)
10-07-2012, 11:49 PM | #104 | |
Trader Rating: (79)
Thanks will do!
10-12-2012, 02:12 PM | #105 |
Trader Rating: (79)
UPDATE TIME
Got some cool thing that i've gathered, some for the 1J some are Aero parts My Xcessive Manu. Mounts came & man these things are nice! Love the quality of the mounts & im sure they'll do the job of hold the 1J Down Also recieved my Order of XRP Fuel Lines/Push AN Fittings from Mr. Broadfield & there Top Notch! Haven't got around to installing all of them but I did install one on my Fuel Rail as well as Deleting my Fuel Dampener The only thing I couldn't get from XRP was a Adapter Fitting to my Stock Fuel Rail So I went & picked one up at DriftMotion its a 12x 1.25 to 6an Fitting Since I was at DriftMotion I also bought a Sump Pan Service Plug since I was missing one The little stuff count to so I went down to the Local Ace Hardware & Picked up 2 4mm for my TPS & 4 8mm Nuts for my Water Pump Pulley since Iwas missing them Also way back when when I pulled out my KA I crimped my Steering Rack Hardlines so a Buddy of mine 89_240jdm hooked me up with some for FREE! Besides doing 1J stuff I picked up some Aero Goodies & bought a Legit D-MAX Roof Wang! A Set of Real SuperMade Hood Vents & a set of Power East Bears Mirrors Got some more stuff on the way & almost have my Wheel tubs finish so I'll be back with a update once their finished!
My Build: The "Coupe De Ville" 1JZ Build!! Last edited by jdm2191; 10-15-2012 at 10:05 AM.. |
10-15-2012, 10:00 AM | #107 |
Trader Rating: (79)
Yup sure am, they will be extended with the XRP push fitting hose & ran across the firewall but there's a couple of other ways of doing it but I felt this was good to me
10-17-2012, 12:57 AM | #109 |
Trader Rating: (79)
Nice cant wait to try mine
10-19-2012, 02:31 PM | #110 |
Trader Rating: (55)
Feedback Score: 55 reviews
good shit man, nice mirrors i was planning on getting those myself :P ill stick to the ganadors though, and btw change the steering rack bushings while your there.
10-22-2012, 07:40 PM | #111 |
Trader Rating: (79)
Thanks, & yeah that is on my to do list
12-08-2012, 03:19 PM | #115 | ||
Trader Rating: (79)
12-14-2012, 12:59 AM | #116 |
Trader Rating: (79)
U P D A T E ! !
Ok so since I am damn near done with my Engine Bay & got my computer back in order its time for a F**CKIN UPDATE! The Tubs were a HEADACHE! Alot of Ups & Downs, Thinking, Cutting, Welding, Time, Money, Food, More Time, Bondo, Sanding & alot of other Shit! I have to give all the WELDING Credit to my buddy Kadeem (AYE MAN THIS IS KADEEM!!!) from HOOD WORKS for Welding my Tubs! & BTW WE DID USE A FLUX CORE HARBOR FREIGHT WELDER! IT DID THE JOB BUT WAS HARD IN SOME AREAS & WOULD RECOMMEND TIG WELDING FOR SUREEEE! & PLAN ON GRINDING ALOT OF POPCORN WELDS! WE WORKED WITH WHAT WE HAD WHAT I USED FOR MY TUBS WAS A TRAILER FENDER I ONLY PURCHASED 1 & CUT IT IN HALF I BELIEVE THE DIMENSIONS WERE 9X32X16 & ALSO USED A 4X4 18GA SHEET OF SHEET METAL SOME INSTANT MOCK UPS STARTING TACKING/WELDING THE DRIVERSIDE FIRST HOOD WORKS APPROVED! I APPROVED! THEN ON TO THE PASSENGER SIDE DONE WELDING!
My Build: The "Coupe De Ville" 1JZ Build!! Last edited by jdm2191; 12-19-2012 at 05:22 PM.. |
12-14-2012, 01:00 AM | #117 |
Trader Rating: (79)
THEN IT WAS ONTO THE SHITTEST PART OF GRINDING DOWN THE WELDS & FILLING THEM WITH BONDO
FIRST TIME USING BONDO SO IT WAS A LERANING EXPERIENCE THEN SANDED IT DOWN, THE DIE GRINDER SAVED ME A SHIT TON OF TIME! THEN PREPPED IT FOR PRIMER (sorry for the blurry pics) AFTER I SPRAYED IT I USED DUPLI-COLOR GRAY PRIMER, SORRY FOR THE DARK PICS SECONLDY CAME THE BASE COAT I WENT WITH A OEM TOYOTA SILVER 1E7 FROM A 07 TACOMA I REALLY LIKE HOW THAT SILVER LOOKS SO I DECIDED TO PAINT MY ENGINE BAY THAT AS WELL AS THE REST OF MY CAR ONCE I GET A CHANCE. I PURCHASED THE PAINT FROM AUTOMOTIVE TOUCH-UP I ONLY BOUGHT A PINT & IT WAS PLENTY I SPRAYED 2 THICK COATS... I STILL NEED TO CLEARCOAT/WETSAND/BUFF, BUT IM CURRENTLY HAPPY WITH THE OUTCOME FOR MY FIRST TIME DOING ANY OF THIS ESPECIALLY SPRAYING BUT IVE SEEN MUCH WORSE FROM STARTERS ALSO HAVNT REALLY GOT ANY PARTS FOR THE 1J SINCE ITS 95% COMPLETE BUT I DID FINALLY PURCHASE MY SARD LOW TEMP THERMOSTAT FROM RHD JAPAN, PRETTY AWESOME QUALITY ITEM IF YOU ASK ME Thats pretty much it for right now still need a handful of things for start up but can finally say im pretty close!
12-14-2012, 03:06 AM | #118 |
Subscribed and I've seen hoodworks e30 he works at the home depot by my house lol but things looking tits man loving the build think i know what i'm gonna do in my hatch now hopefully i'm deciding on things still but great job brah
12-14-2012, 01:16 PM | #119 |
Trader Rating: (79)
Yeah that's where he be at & yeah man it's a long process but love the turn out!
