Old 04-12-2012, 06:22 PM   #91
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Originally Posted by buentellomma View Post
Yeah i paint others before mine, im not taking on another project til i get time to get my hatch going again.
I'll definitely hit you up when and if I ever get to repainting the car. I'm down to help prep the car and buy supplies. Just dont have the tools or space to do something like this. I still gotta figure out how I'm gonna get my damn engine swap started.
CLICK HERE!!!
Old 05-13-2012, 07:03 PM   #92
dpritchard4
dpritchard4's Avatar
dpritchard4 is an unknown quantity at this point
this thread really helped me touch up my engine bay, but i wish i woulda learned how to blend better from new to old paint (faded paint plus new paint means hard line) but now im spraying my bumper and i have wrinkled paint in one spot.....what did i do wrong???
dpritchard4 is offline   Reply With Quote
Old 05-14-2012, 03:56 PM   #93
buentellomma
buentellomma's Avatar
buentellomma is an unknown quantity at this point
Surface prep more than likely caused it. The new base coat reacted with something underneath. Did you spray over old paint?
buentellomma is offline   Reply With Quote
Old 05-15-2012, 09:44 PM   #94
GUS13
GUS13 is an unknown quantity at this point
finally a good diy paint write up. ive been looking to do this. the guy who gave me my car had filled some spots with body filler and im tired of looking at random white spots. getting the entire car sprayed in az but this will do for now.
GUS13 is offline   Reply With Quote
Old 05-15-2012, 09:51 PM   #95
SaNTi
SaNTi's Avatar
SaNTi is an unknown quantity at this point
Definitely lots of good info here.
SaNTi is offline   Reply With Quote
Old 05-20-2012, 01:52 PM   #96
dpritchard4
this is what has happened 2x...ive sanded with 600 grit and used primer first
Old 05-20-2012, 11:45 PM   #97
buentellomma
well if it did that with primer under it you have two causes: 1) your reducer to base coat ratio is off meaning too much reducer. 2) your spraying too much on there and the solvents are causing that. The Fix= sand with 320grit or finer to remove the wrinkled paint, lightly spray primer over the area one coat will do, allow it to dry and lightly scuff sand the primer do not sand it off or sand through it, lightly spray your base coat over the area ( it might take 4 or 5 coats to cover it) <- by lightly spraying this over a problem area the chances are less likely to happen again, be sure to allow a few mins between each coat.
Old 05-21-2012, 12:07 AM   #98
df3kt760
df3kt760 is an unknown quantity at this point
Great job very informative
df3kt760 is offline   Reply With Quote
Old 05-21-2012, 12:16 AM   #99
Nickys13
Nickys13's Avatar
Nickys13 is an unknown quantity at this point
Doesn't paint wrinkle when the surface is dirty?
Nickys13 is offline   Reply With Quote
Old 05-21-2012, 12:38 AM   #100
c72c
c72c's Avatar
Trader Rating: (25)
c72c is an unknown quantity at this point
Feedback Score: 25 reviews
Nice work. I'll help out with the thread as I make progress on my truck.
I would like to suggest giving a few tips on masking. I would, but I have no pics. An example (since this bothers me the most) when people do a spot repair and just spray primer after the work... not to hardline the area being primed. Fine line tape is one option, but you can also use the 3/4" tape and fold it over... and tape back from the body work, not right next to it.
Sorry, I just see so many people have primer puzzle pieces, it really bothers me.
Two important tips for anyone doing any of this;
-Body work takes time and patience.
-A paint job is only as good as it's prep job.
It's possible, but usually it will fish eye if there are any oils on it.
c72c is offline   Reply With Quote
Old 05-21-2012, 01:34 AM   #101
xh3nry
xh3nry's Avatar
xh3nry is an unknown quantity at this point
Awesome paint job, i wish i had a garage or a booth to paint my car in.
xh3nry is offline   Reply With Quote
Old 05-21-2012, 07:02 AM   #102
buentellomma
Fish eyes happen when the surface isnt clean most of the time, wrinkles are caused by solvents. The most common wrinkle happens when the new paint reacts with older paint underneath. Also if you spray too much on one area you risk runs or wrinkling. Mixing too much reducer in the base coat will also cause wrinkles.
Old 05-24-2012, 07:57 PM   #103
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
Can someone chime in on guns.(good guns, basic set up, tip size, cleaning, pressure....) thank you.
g2ic02 is offline   Reply With Quote
Old 05-24-2012, 11:17 PM   #104
buentellomma
Well what it really comes down to is are you a paint gun owner or a painter? You can have the best equipment but without the skill you still wont acheive what a skilled painter with a cheap gun can produce. I can spray with whatever you put in my hands, i like to use iwata brand guns ($400 +) with a 1.4 tip for base and 1.8 tip for clear. Devilbliss makes reasonable priced setups that work great. Hvlp guns should spray at 10psi at the cap, around 50psi on the line. Cleaning i break mine down and clean with laquer thinner
Old 05-25-2012, 05:47 PM   #105
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
If you have a lifting problem like that (wrinkling) you can sand it down and try primer sealer on the primer also. It will help block the solvents in the paint to the primer.
Dirty surface does not cause lifting. Like buentellomma said, it is usually the new base coat reacting with the primer or factory paint. Most times I have problems with lifting on factory basecoats for Hondas when I'm using Nason.
C. Anderson is offline   Reply With Quote
Old 05-25-2012, 06:55 PM   #106
dpritchard4
it was deff an issue of reacting with the old paint, i finally kept sanding and sanding back the org paint till i got it to stop...thanks for all the advice...but i still need more.
i was trying to remove the orange peel, so i took 1500 grit and smoothed it down, then followed with 2000, rubbing compound and polishing compound(applied by hand) and i cant get that high luster back, i know i didnt sand through the clear coat, and i layed down 3 wet coats of clear....any ideas???
Old 05-25-2012, 06:59 PM   #107
silviaks2nr
silviaks2nr's Avatar
You need to machine polish it with a wool pad then foam pad. It wouldn't be a bad idea to go over the whole car with 3000grit first too. I've had the same wrinkle issue when i didn't have a thick enough coat of sealer over 2k after bodywork. It's easy to touch up those spot before you clear if you ever run in to that though. As others have said fisheye is usually due to contaminated surfaces. If you try to shoot something like an engine bay that's not clean with single stage without priming/sealing you will get fish eye for sure. You can mix fish eye eliminator into clear and single stage but it's best not to.
Old 05-25-2012, 09:09 PM   #108
buentellomma
You need somekind of high speed buffer to polish out the clear. They make a 2" buffer that chucks into a drill if your low on cash. Ask the paint supplier about it, if not harbor freight has a decent one pretty cheap
Old 05-25-2012, 09:20 PM   #109
SuperBlackS14
SuperBlackS14's Avatar
SuperBlackS14 is an unknown quantity at this point
I just wanted to say how awesome a thread this is, and to the OP and any posting guides: thanks You so much!
"Power Is Nothing Without Control"
SuperBlackS14 is offline   Reply With Quote
Old 05-28-2012, 06:55 PM   #110
g2ic02
thanks for the response. i know alot of the final product comes down to experience and skill. what i a guess i was wondering is do i need to go out and spend $300-500 or can i get by with a $200 gun. Is the final product going to be noticably different, assuming you have the skill to paint.
Old 05-28-2012, 07:47 PM   #111
Breitling
Breitling is an unknown quantity at this point
very nice thread. Builds confidence
Ls460, 240sx, Super Avenger, Chronofighter, Navitimer
Breitling is offline   Reply With Quote
Old 05-29-2012, 05:51 AM   #112
buentellomma
If your only going to use it a few times the cheaper gun would be the way to go. Cheaper setup vs high dollar setup : the cheaper gun is not going to last as long and the atomization of the paint some times isn't that great meaning you will use more paint. Honestly if you don't have much exp with spraying save the cash and go with a gun you can afford. You won't be able to tell a difference when you spray.
Old 05-29-2012, 02:45 PM   #113
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
I found this video to be the most helpful (to me at least) on the topic:
http://www.youtube.com/watch?v=3s4APWNqRGc
the guy's YT channel has a great deal of good information on the subject aswell:
mcqueenpaint - YouTube
The boss has a collection of guns at work and allows us to play with them.
I'm using a cheap HB 1/8 bottom feed gun to shoot primer and it has worked ok for me.
For the base and clear I'm going to use a Finnex 3000 with a 1/4 tip.
There's a DevilBiss StartingLine gun on hand but the reviews I read are mixed.
The Finnex gun seems to be a good choice and value (if you're buying one). All the reviews I read were positive.
And if I'm not happy, there's also an Iwata gun I could try.
Anyhow, I'm undergoing my first DIY job. Still at the primer stage.
(you can see the run on the fender where I sprayed too much primer)
Old 05-31-2012, 10:00 AM   #114
buentellomma
Originally Posted by ManoNegra View Post
i would love to do a pvc pipe paint booth if i had the room to leave it up, but for someone on a small budget its easier to just hang plastic. The booth looks good where are you planning on placing your intake and exhaust fans?
Old 05-31-2012, 10:08 AM   #115
silviaks2nr
A few years ago I painted my car outside in ~90 degree temps. Can't say it was an easy first paint job but it turned out well for what it was, after sanding. I've painted a few cars and many other things since then. It does get fun once you're good at it.
Recent photo- car is very dirty but you get the idea.
Old 05-31-2012, 06:24 PM   #116
S14TEENZ
S14TEENZ's Avatar
S14TEENZ is an unknown quantity at this point
Great stuff in here....very good tips but always remember prep is key. There are things you cant see when primer is applied. When basecoat is appled it all jumps out.
One thing I don't agree with OP is using single stage paint. Maybe for a car yo may not care that much about yes. But not cars for attention. I know you can use single stage urethane paint and then go over with urethane clear. But still single stage is for taxis and shit.
S14TEENZ is offline   Reply With Quote
Old 05-31-2012, 06:38 PM   #117
buentellomma
Who is using single stage on here? I never use or promoted single stage paint. In the 9 years I have been doing this I have only sprayed single stage garbage twice......
Old 05-31-2012, 07:06 PM   #118
S14TEENZ
S14TEENZ's Avatar
supplies alone was around $500 but im sure it would be cheaper if you purchased single stage paint. I bought a gallon of atomic orange and half a gallon of black, gallon of clear coat, quart of sealer, and then all the other supplies tapes plastic etc.....
I would not say promoting but it was mentioned.
Old 06-04-2012, 01:51 PM   #119
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
I'm not all that happy with it actually
it's flimsy as f**k and difficult to get the drop clothes to stay
I think that screwing pieces of 1x2 wood along the top of the wall and stapling drop clothes to that would be a better way to go
or if I were to build another structure, make it out of 2x4s or something more rigid
the two boxes on the corners you see are 20x20"
the fans/filters fit in there perfectly
masked the car during the weekend
(that was a royal pain in the ass)
and sprayed a coat of build up primer that I need to clean up in a few places before spraying a second coat
contemplating buying aerosol cans of primer to get the under side of the wing. thoughts?
Old 06-04-2012, 03:45 PM   #120
buentellomma
Rattle can primer is garbage most of the time it will react with the urethane paint. Also to save you from a mess when you spray base coat, place paper on the edge of your masking..... By spraying onto plastic it will flake off when the air pressure hits it and go all over the place. I would take that wing off and spray it that way, it will turn out a lot better.....
