#91 |
![]() Join Date: Nov 2005
Please stop trying to prove yourself. You're trying much too hard. 400whp is easily doable on a stock, good condition bottom end.
Blown up engines are not necessary if you tune it from rich to lean while staying in safe territory.
#92 | |
cody and i have stock bottom ends, stock heads...well we have cp pistons but that is to help with detonation...cody ran his old motor fully stock including the pistons...the only reason why it blew up was because an injector lifted and went lean in cyl 3....you think we like blowing up motors? if so you are a fool |
#93 | |
![]() Join Date: Mar 2006
I feel I have a really good grasp of PFC and how it works, and all of the bells and whistles (I have Datalogit).... But I have NEVER seen any option or anything where you can setup it up to pull timing due to knock readings.... Where did you hear/see that?
Daily driven |
#94 | |
This essentially means that you want the most possible acceleration at any point in time possible. I have done the calculations based upon my dyno chart (and other peoples' will be similar)... For example..... Let's say my "dyno" shows that I make 300 ft-lbs at 6000 RPM and 250 ft-lbs at 8000 RPM. If you do the caluclations, you would find the following "theoretical" accelerations in each gear (in ft/sec^2)...with stock SR/KA tranny and stock USDM 240 4.083 final drive: 6000 RPM (peak torque) 1 - 42.39 2 - 24.27 3 - 16.58 4 - 12.68 5 - 9.68 8000 RPM 1 - 35.81 2 - 20.51 3 - 14.10 4 - 10.78 5 - 8.18 Notice that the acceleration at redline in any gear is ALWAYS higher than the acceleration in the lower gear at the lower RPM (even at peak torque in that lower gear...). This means that the OPTIMAL way to get from point A to point B fastest is to redline EVERY gear. Now, in some cars, the torque drops off MUCH faster before redline....in CERTAIN scenarios, it MAY be beneficial to shift before redline. This would require that the torque made at the NEW RPM (upon upshifting) multiplied by the ratio of the NEW GEAR RATIO/OLD GEAR RATIO is higher than the torque being made if you had just stayed in the lower gear. Example: 2nd gear is 1.902 3rd gear is 1.308 Ratio of 2nd/3rd is 1.45!!!! This means if you are in 2nd, and your torque starts dropping off....for it to be beneficial for you to upshift, the NEW torque you would make in 3rd upon upshifting would need to be 45% higher than the current torque you are making in 2nd. So even if your torque drops off quickly and you are only making 200 ft-lbs in 2nd, you would need to make 290 ft-lbs at whatever RPM you WOULD be in 3rd if you upshifting in order for it to be beneficial to shift. Summary Like I said....with GT2871R setups and the shapes of the torque curves they produce out to, say, 8000 RPM or maybe even 8500 RPM, it is ALWAYS beneficial to just keep revving out in the lower gear.... As you can see, even at redline, the lower gear always has better acceleration then the next highest gear at it's PEAK acceleration point (6000 RPM)
Daily driven |
#95 |
What you're saying is theoretically all good and true, but in the real world both on and off track you have to deal with different speeds and loadings. You can't always come in and go out of a corner while redlining in a certain gear.
This is where the broad powerband comes into play. This way, when you can't come into a corner in an optimal gear and/or rpm, the broad torque curve will get you out faster than if you've sacrificed that for peak power. That is the reason I'm sticking with a .63 2871R until I can upgrade to a twin-scroll setup.
#96 | |
If he is so concerned with "midrange", he should NOT have the Greddy IM....just ask SteveShadows his opinion on that. If you are going to go with the Greddy IM, which already slows your spoolup, you might as well add cams, which aren't really going to further hurt spoolup but WILL dramatically help topend and allow you to safely rev out much higher than OEM cams.
Daily driven |
#97 | |
#98 |
![]() Join Date: Jan 2008
The point is that you have blown up motors and had to redo things to get to where you are. I elected to not go that route since I make enough power to kill Mustang GTs, Maros and Challengers. Where I live, a Mustang is like a Civic, everyone has one and loves to modify them. The new coyote 5.0 could be a different story. They are bringing the big power back to the Mustang.
Also you all have said that a board usable power band is better so you are in agreement. However, why not extrude hone the intake manifold like codyace and I have done to the exhaust manifold? The exhaust manifold came out supreme and will last a lot longer than the Tomei, I use to run. It would be interesting to see the gains. Cody was I thought suppose to have a dyno sheet comparing the two but I do not know if that ever got done? I am older than most of the scene and drive a modified S14 -- also I do not subscribe to ImportTuner but the Nissan Sport Quarter Mag. |
#99 | |||
Nissan Sport sucks.
#100 |
Until a ROM tune gets a neat little commander that eliminates 4-5 analog gauges and monitors things like Knock, A/F, RPM, Speed, temperature etc etc. then the POWER FC still reigns supreme.
How could not make the same amount of power or better with a standalone than what you make with a ROM. You all make it sound like a ROM > Standalone which any tuner knows is not true. If you have to go ROM tunes -- I am guessing almost everyone is happy with the JWT better than the other ROM options out there. How do you ever know that you are getting spark knock or not once you get into high boost with it? The damage would be done before you ever knew what happened? |
#101 | |
I agree with what you are saying. At the same time, the guys that do these tunes are legit EXPERTS. Like they have tested out X cams, X manifold, etc etc etc and know how everything effects everything. That beings said, I would imagine that the ONLY way they could guarantee they aren't gonng blow anything would be to always err (how much, I dunno) on the side of safeness in terms of spark advance and AFRs.... I'm wondering if someone blows their motor, what are the legal scenarios? I mean, if you do a schlock job of putting your shit together and your CAS is off a bit, then you put in a JWT ROM and blow your motor, that's your fault. But at the same time, there are natural variances to IDENTICALLY setup motors. The only way around this (I assume) is for the tune to be pretty darn safe.
Daily driven |
#102 | |
#103 | |
Base fuel and timing maps would be cake. The issue may be with the additional correction factors, and also, with PFC, you don't have any control over certain idle stuff related to the IACV. They definitely would know HOW to do it, but they probably wouldn't be able to send you a "complete" tune, bc the correction stuff in the PFC is probably not (?) the same as the ROM tune. Just my "guess"
Daily driven |
#104 | |
![]() Join Date: Jun 2008
![]() Feedback Score: 13 reviews
#105 |
![]() Join Date: Nov 2008
^^ at those boost ranges Im guessing your not going to see any much more peak hp. I would really be interested in going with an rpm independent boost controller to run higher boost down low and taper it off up high if I were you instead of just setting it at 28psi.
This thread is great. I want to apologize to the op because it has been derailed mostly due to one of my posts but the conversations have been great (aside from a few that are not on par). I would like to add that the greddy IM came with my engine. I bought the car around 5 years ago and it was put together really poorly but the parts it came with was double what I paid for it so all I had to do was rip it apart and do it right, and then upgrade certain things to my liking (such as the suspension and build the motor ect). Another thing about blowing engines. NO ENGINE I HAVE EVER TUNED HAS POPPED. I have popped this sr though, when it was on a JWT tune. Detenation was very apparent but that was a few years ago and it seems as if he is doing a much better job now. I do plan on doing some more tuning on my setup either monday or tuesday and the low end should look much better. I pulled 80whp out of the base tune I set up for the dyno and my only focus was up top. Now im going to be focusing on the midrange and results should be similar. There is also a trick to helping spool e85 turbo setups, and I will implement that in this tune. As for the the guy saying that standalones are always better than a rom tune, show me ANY dyno graph where someone has a 2871r on a sr with more hp than me and we will just assume its tuned on a PFC for your sake and then you win. Otherwise Ill just stick to my analog gauges. |
#106 | |
1) Electronic boost controller is always better, manual sucks. How can you know in advance what the boost vs. RPM profile will be? You can't, AND you have no control over it. With a good EBC (I love the AVC-R), you can explicitly dial in the duties at different RPMs to give whatever the hell boost vs. RPM you want. 2) That is a completely unfair/misleading statement. Show me someone with an extrude-honed turbine housing AND exhaust manifold AND JWT S3 cams AND greddy IM AND upgraded pistons and/or rods....... AND a PowerFC? There isn't anyone on here that I know of with that setup and a PFC. (I am considering in the near future going with the EWG-44 special turbine housing with external gate, and may due the extrude honing, but building the bottom end won't happen for a long time.....and GOD do I need a better tune). That being said, anything that the ROM tune can do, can be done as well or better with a standalone. The key to your setup making so much power (E85) and Cody's and the like lie NOT in the type of tune (ROM vs. Standalone) but the quality of the tune and the specific setup/parts. Cody's setup or yours with a lot of dyno time and a Standalone could make as much or more power than they are now. I am not knocking the ROM tune, man, I am just staying stop making it like the ROM tune is the REASON for your numbers.....that is so misleading.
Daily driven |
#107 |
im not sure you understand what I was saying, or im not sure if I understand what your saying with the last 2 posts.
I was talking to the hemi guy I believe with what you bolded. Im also not trying to make it seem like the rom tune was the reason for my power, I would like to pat myself on the back for that and not the ecu. I use a greddy profec ebc, not a manual. I hate mbc's. The boost controller comment I made was directed at s13curtis as a suggestions to use a boost controller like your avc-r instead of just setting the boost at 28psi because up top that would surely not be effecient. I have been awake too long and maybe should have refrained from posting since it has caused some confusion. Ill be sure to post my next sheet when I get to doing some more tuning on this setup, hopefully a vid too. |
#108 | |
I really think a lot of people don't understand this tho. If your wastegate spring is let's say 15 psi.... The wastegate does not ALL OF A SUDDEN open when boost hits 15 psi. it is FULLY open at 15 psi. That means that while you are spooling the turbo up, the wastegate slowly begins opening, and is then fully open at 15 psi. This HURTS spool up. Ideally, you want the wastegate COMPLETELY shut just until that very last second when it hits your target boost. You can only do this with an electronic boost controller. If you set your MAX boost with a manual boost controller, then the transient behavior (spool up) will be way sub-optimal. If you try to tighten it to make it spool faster, you will overboost your target. Again, you can't decouple transient boost behavior from steady state boost value when using an MBC....
Daily driven |
#109 |
I have tried to tell people this but they ususally come back with "but I can make a mbc for a few bucks"
I hate that. If your a cheapo then you dont need a turbo anything. Having this conversation does have me wanting to check something though...... I want to make sure my adjustable actuator is tight.... |
#110 |
another reason why 4x4le makes such good power is because of the E85...it allows him to run more boost and timing safely
cody and i run pump gas (93 octane) and the tunes are set for 91 octane (in case there is not 93 if we are out driving) ROM tune is def better than PFC because i can spend 600 bucks on the tune and another 150 on guages...so not only is my car tuned very well (with launch control/meth injection maps), but i also have the basic gauges that i will need (boost/vac, oil press, and water temp, afr) dont the knock sensors get turned off on the sr's after a certain rpm? |
#111 | |
That is the kind of statement that is creating arguments in this thread Cody was just trying to reiterate that ROM tunes are a great option. But sayung that it is BETTER than a standalone is just downright idioitic, and again, misleading. Rip the ROM ECU out of your car and put an AEM or PFC in and let an equally qualified person tune it (i.e. JW or RSE) and they can do just as well. Saying it is "better" is just assinine.
Daily driven |
#112 | ||||||||
![]() Join Date: Dec 2004
Trader Rating: (58)
I love watching my friends tune the big power drag cars and say 'man I could make that power at 15 psi at 10psi if you ran some race gas hehe'. Quote:
![]() Quote:
I was just curious that over a given distance if a car that ran out of gear (ised all the rpm), would be quicker from A-B than a car that stayed below the threshold. Quote:
PS: LOL at your lawsuit -- that would have never held up. Heck should I sue Nissan for a bad o ring because my stock engine ripped one out of the intake manifold? Or should I sue greddy becuase of it? it's the name of the game with modified stuff. PLEASE STOP POSTING -- Sometimes members like you really turn me off from forums (and many others that are in this thread agree with me. This has been my goal since day one. For people that don't live near a good tuner, or don't' have the 1000-1500 bucks for a standalone and tune, the ROM setup is really a great setup for a true street car. Im' glad some of the technical discussion came up, as it's been a while since we've had such conversion on here (better than the typical topics we see time and time again). Now if we could only convince HemiCharger to quit posting in here, as it's obvious his tuners words (I mean his knowledge) is a bit lacking -- this would be a great thread to learn in.
#113 |
Doesn't the ConZult plug into your consult port, and then you can track what your ECU is seeing in real time with a single display?
I remember a Sentra owner that has had the SR20VE swapped into his Sentra, and he showed me the log of his engine revving past 10k rpm without load. He started his car, started the datalogging feature on the device (pretty sure it's the ConZult?), then he revved the engine, and then he went back and displayed the peak values that the device had recorded, and his rpm read 9999, because that's as high as it could read lol Anyway, just saying, there are datalogging capabilities for the folks running ROM tunes too, and stand alone EMS aren't the "be-all-end-all" solution to engine tuning. |
#114 | ||
Trader Rating: (58)
I personally use NissanDataScan: nissandatascan.com Program Purchased from: blaZt - Nissan Datascan version 1.54 software for reading engine sensors and trouble codes Cable Purchased from there as well: blaZt Nissan consult PC scan tool for Nissan OBD Single best tool I've ever bought for the car. At 120 bucks you simply can't go wrong ya know? Works as a scanner, does timing mode, logs the car..just a fantastic thing. Quote:
#115 |
![]() Join Date: Sep 2005
i was 2 HUGE pages behind and some of this shit i jsut read made me crossed eyed. lots of good info
also, i read some stuff i wish i could just punch people for saying. i have a Consult and i can never get it to work right. must be something i am doing because it never connects to the car. |
#116 | |
i run a ROM and i didnt buy any of those 3 items...my car came with a cluster that is capable of reading all 3. yes the knock and a/f i need a gauge for but my afc handles the knock and fine tuning(2 birds with one stone) and the a/f can be had for cheap with a simple gauge. autometer has one for $63. now, i do have an AEM ems but havent installed it yet. actually i have had it for nearly 3-4 years. i dont have the knowledge of tuning it my self yet so i havent installed it. theres a shop near me that will install and tune it for $1200...not something i can do. to much $ i will learn how to do it my self when im ready |
#117 | |
Trader Rating: (58)
Not connecting in the sense that the port isn't even picking up the ecu, or the gauges aren't working? Sometimes the 8pin to usb converters get finnicky for sure.
#119 |
a $63 gauge from autometer most likely is not a wideband and cannot handle air fuel ratio.....
codace, is your 4.6 gear out of a r51 front? And do you know what the wheel speeds are from gear to gear? I understand if you dont know what it tops out at in 4th or 5th but but mostly im consirned with top speed in 2nd through 4th (also what tire size are you running)? I would love a lower gear but Im afraid it could cause more shifting than I would want in a drift car. |
#120 | |
Tuning is not some secret freaking thing that only a few people are good at. I mean a lot of people own cars and tune then up especially for Nissan and I am happy codyace has such a great tuner. It does not matter to me other than you all are trying to say go ROM tune over standalone cause they make more power when that clearly would not be the case. It is also great that your ROM tune allows you to monitor those channels but you do not have the time to stop your car or look at your laptop while you are pushing out 6000+ rpm shifts. I know other people that read this and will go whoa I will go out and make 400whp with a JWT tune not specifically made for my car then blow their shit up and be like what went wrong? Again, My PFC has been tuned at what it runs now for over a year and a half. There was no guessing with it and not much to chance. Additionally, if you are given the choice of a ROM verses a Standalone then look over the options really well. The RISK is less with a Standalone and they can control all things. Oh yeah I also have working A/C in my car as well as cruise control, intermittent wipers --everything works like it was from the factory that way..... just saying...... Last edited by HemiCharger; 04-25-2010 at 05:00 PM.. Reason: change |
400 hp, enthalpy, gt2871r, gt2871r .64, jwt |
