09-21-2009, 11:01 AM | #1111 |
^ i have the same problem as you. Probably has something to do with the alignment or the body panels line up different from one side to the other. Just get a slip on 5mm spacer for the passenger's side and call it a day
09-21-2009, 11:44 AM | #1112 | ||
Trader Rating: (22)
Feedback Score: 22 reviews
You both probably need alignments and its always a good idea to have it checked when in doubt. No spacer
1997 Nissan 240sx SE(Rb25det+GT35r= 486whp on 93pump):http://zilvia.net/f/premium-member-b...oject-2-a.html Quote:
09-21-2009, 12:21 PM | #1113 |
Philosopher King
Camber wouldn't cause the entire wheel to stick out further. It actually seems to be a common problem on S chassis.
G O L D E N B E A R R E P U B L I C |
09-21-2009, 01:18 PM | #1114 | |
ive seenthis car in person it has ASS lol |
09-21-2009, 02:00 PM | #1115 |
In time-out for misbehaving.
09-21-2009, 03:29 PM | #1116 | ||
Trader Rating: (22)
What is the actual physical/mechanical problem that causes this phenomenon??
09-21-2009, 04:43 PM | #1117 |
switching from stretching/flush to big rubbers( want to do time attack)
gonna be running te's 18x9.5+12/18x10.5+5 running 40mm overf front and 70mm rears , tires are hankook ventus rs-3 245/40/19 and 285/35/18 . to bad hankook doesnt offer that tire wider . looks like a very good one. 140 treadwear
TRUE thing: True ////OFFSET\\\\ is acheived without spacers Running on E85 570whp Precision 5862....laggy as fuck. hate it |
09-22-2009, 07:50 AM | #1119 | |
I run 255-40's up front on my stock fender S14, so if you have super wide fenders why not put them to good use since you want to track the car. You should really be able to run 275's up front with some work. Last edited by longfellow; 09-22-2009 at 09:04 AM.. |
09-24-2009, 04:26 PM | #1120 |
they r on my way now.....265/35/18 and 315/30/18 khumo ecsta XS
09-24-2009, 07:41 PM | #1121 | |
09-24-2009, 09:14 PM | #1122 | |
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
09-24-2009, 11:37 PM | #1123 |
i mean +15i wanted rs-3 but they DONT go over 285 and if im switching back to max rubber i want BIG
09-25-2009, 12:43 AM | #1124 |
Are you going overfenders, or just a real healthy r+p in the rear?
09-25-2009, 09:55 AM | #1125 | |
tires arriving today. tirerack FAST
09-25-2009, 09:55 AM | #1126 |
he stated 70mm rears a few post ago...
09-26-2009, 12:20 PM | #1127 |
set up is up and running. khumos ecsta xs are just amazing. car grips like a bitch now. i can finally enjoy the 520 whp my sr push... 265\35\18 fronts. no problems. i could it fit a 275 easy... 315\30\18 with a 10mm spacers rears. and still have plenty of room ... pics coming soon
09-27-2009, 09:48 AM | #1129 |
fuck lips..... TE's forever ..
09-27-2009, 12:07 PM | #1131 |
10mm spacers all around. 265/35/18 and 315/30/18 no problem. no rubbing no nothing.. feel like im driving a 4x4 after the ssr setup . but car feels much better. wanted to do stretch/flush did it and done with it. to much of a pain
need some camber adjustment i would do it this coming week
09-28-2009, 01:00 PM | #1135 |
I've got a question for those running 275 or greater up front:
Do you need mini tubs in the engine bay? Or does that only come into play with increased steering angle from drifting style spindles with increased angle?
09-29-2009, 09:45 AM | #1137 |
Picking up tires today, i wanted to know if i will be rubbing at all? or if i would i possibly need a fender pull or roll at all.
YOUR CHASSIS: s13 93 coupe. WHEELS: F: Sportmax 006 17x9 +20 R: Sportmax 006 17x9 +20 (+12 with 8mm spacer) TIRES: Hankook H105 215/40/17 all around MISC DETAILS: KYB GR2 Struts all around, Eibach sportlines all around, Ichiba 45m extended studs all around, Muteki SR48 extended lug nuts all around PURPOSE OF CAR: street/ daily driver any info would help thanks
I drift, I drive, I jerk |
09-29-2009, 10:30 AM | #1138 |
iLOVEmyS13: 215/40/17 all around
Is this a joke? Did you happen to read any of the previous 1136 posts?
09-29-2009, 10:32 AM | #1140 | |
