05-24-2012, 10:29 PM | #1117 |
new to wheel fitment and 240sx, i dont have to much knowledge on this stuff so your help is appreciated! anyways, i was just wondering if
1) i will need spacers, and if so roughly what size 2) if i will need to roll/pull fenders 3)will i need to buy camber kit i have a stock s14 zenki,it is my dd. i am putting on kw v3 coilovers. rest of suspension is stock thus far. i will be running rota p45rs, 18x9.5 +30 all around. front tires will be 225/40/18 rears will be 225/45/18 everything is in peices right now, nothing is put on the car, im waiting for my wheels to get powdercoated to start slapping this stuff on... i would really like to know, ahead of time, if i will maybe need spacers or start looking into fender rolling. thanks |
05-25-2012, 04:00 AM | #1119 | |
Man w/ CTSV & a Car Seat
As far as your tire sizing, I'd recommend just running 225/40-18s all around. No point of running a taller tire in the back and it'll throw off your speedo by a couple miles. Camber, it will all depend on how low you want the car to be. The lower it is, more camber it will have. If you plan on lowering it atleast 3" from stock height, go buy camber arms and toe arms for the rear. Fronts should clear anything and everything, but you might wanna throw some spacers in the front so it wont look sunk. Fronts, I'm always partial to 225/40-18s. Rear, its gonna be up to you. Do you want a stretch or wide? You can fit 245/35 or 255/35-18s with those sizing without fucking with the fenders too much. |
05-25-2012, 04:04 AM | #1120 |
suppp guys kinda new to fitment just wondering whats the maximum amount of lip possible int he back without having to go wide body with over fender?
for example 5 inch lip -3 camber?? no more than -3 camber please thats seems a bit excessive |
05-26-2012, 10:36 PM | #1121 |
I've got an 89 S13 with 50mm rear fenders and not sure what size to get in the front.
The wheels I want to get are REAR: 18X10 +22 FRONT: 18X9 +24 How can I make them fit flush on the rear, and what size fenders should I get in the front? Any ideas would help! |
05-26-2012, 10:51 PM | #1122 | |
The rears will probably require some kind of spacers, size would depend on the camber you run, and the fronts would fit on a stock fender with a roll. |
05-26-2012, 11:36 PM | #1123 |
Alright, I have a question regarding which lip size I should go with. Please loo kat the two sets of pics and tell me your opinion. i now have an opportunity to use either 5 or 6 inch lips. I have until tuesday to decide.
The 5 inch lips make the wheel an 18x10.5 +16 The 6 inch lips make the wheel an 18x11.5 +4 I am running 30mm fenders that are pushed to about 40mm Heres the 6 inch lip Here are the 5 inch lips Which one should I go with?
Ls460, 240sx, Super Avenger, Chronofighter, Navitimer |
05-27-2012, 08:00 AM | #1129 |
So if those wheels were a 4" lip, they would barely tuck and clear the inner fender with a slight roll, right?
05-27-2012, 08:37 AM | #1130 | |
reference this... 6 inch lip, no overfender. 4 inches would be way sunken
05-31-2012, 02:05 AM | #1131 |
Would like to know how much camber i can run on Stance GR+ coils without modifying it. Looking to run -5 in front and -3 in rear. Ive seen people slot the hole but before i do so i want to know if i can achieve that without doing it.
05-31-2012, 07:54 AM | #1134 |
Wheel's
Hey im looking to run the widest wheels possible on a stock body with that inner lip flattened. What Size/Offset will i need to run? Ill most likely will be running Fortune 500 Coilovers if that helps with anything thank You!
1990 240sx Hatchback |
05-31-2012, 12:46 PM | #1140 |
How would this fit on a 240sx stock body with inner lip rolled
18 x 9 4 x 114.3 +30? and if it fits good what tires should i run. I want to run as minimal stretch and possible a very little camber seeing as dad thinks ill burn through tires like nuts. |
