01-22-2011, 07:28 PM | #11341 |
You guys inspired me to drift in 18's so im going to use 2 of my old rims for the rear and the cr kais in the front. front tires shouldnt wear too fast on drift days right? I also realized stock se rims would probably just hit the coilovers in the rear. <-correct me if im wrong in that
So will 18x8.5+35 hit coilovers in the rear? and what tire size should i run with those to drift?
'95 240sx | '01 Mazda Miata | '18 Tesla Model 3 |
01-22-2011, 08:39 PM | #11342 |
You'll see the most wear up front on the outside. Stock SE's won't hit coils.
BRICKHOUSE PRODUCTS
IG @brickhouse_products |
01-22-2011, 10:31 PM | #11346 | |
Might be a little bit too big for the front. Stock body that is. I'm gonna run 17x9+2 effective up front. Perfect fitment imo. Mad-ass posted up a pic of his car with that size/offset a bunch of pages back. If I wasn't lazy, I'd go look for it and post it up again.. but alas I'm lazy.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
01-22-2011, 11:34 PM | #11347 | |
01-23-2011, 03:05 AM | #11351 | |
i bought an ebay itr lip and dont have that problem. so im not sure what anyone else was running to have that issue? |
01-23-2011, 04:49 AM | #11352 |
I need to redo the relay wiring for my Taurus fan. I burned up 4 relays and 2 sockets so far and found out that 30amp relay is not enough for taurus fans since they can spike up to 90+ amps on initial start up and require 33+amps when running. thank god I'm running a fuseable link fuse for them. Damn this.. time to swap over to 50 amp relays and maybe get rid of the sockets and switch it out to plugs only, since the sockets hold so much heat and just end up milting down.
Too many little things to fix and I don't wona!
01-23-2011, 10:41 AM | #11354 | |
01-23-2011, 11:22 AM | #11356 |
I wish the rear of the car was lower at the time. |
01-23-2011, 04:25 PM | #11369 | ||
P.s. S14FBS your car is Nice
MAddDsBRO LEHDABIHLOO |
01-23-2011, 04:47 PM | #11370 |
so florida has a version of my car but with a kit and its way cooler then mine
http://strictlycoolstuff.tumblr.com/ |
