#10741 | |
![]() Join Date: Jun 2011
![]() Feedback Score: 11 reviews
no shit asshat. but the fsm is not always the best way. instead off following that shit i just took out the cv joint and slide the boot off. hop off my dick and go e-thug someone else |
#10742 | |
Until then, you can kindly go and fuck yourself.
#10743 |
I'm about to order a new carpet for my S13 hatch from stockinteriors however the only option they offer is the HICAS model. Is there any difference between HICAS carpet and non HICAS as far as the fitments goes? Thanks!
#10744 |
[img]So I'm trying to lower my new KTS coils and they are 'maxed' at a super high height.
![]() They are supposed to go REALLY low apparently and this is as low as I can get either of the rears. The body stops turning at all. Is it the pre-load thats messed up? I bought them like this, just trying to lower them.[/img] |
#10745 |
What are you rotating? Unbolt the bottom mount from the knuckle, and then screw it up onto the threaded section as far as you can go. That would be bottomed out.
#10748 |
Ok. I understand exactly what you are saying. What is the difference between doing that, and just turning the whole shock body into the bottom mount, without removing it from the knuckle? It won't turn any more, and there is a shitload of thread left. Both sides are like this.
#10749 |
#10750 |
Does anyone have the ecu pinout for the JDM S14 SR20DET NA ECU(97-98)? I'm trying to wire up my consult port. All the searches are broken links and I can only find the AUS version of the ecu pinout; which I'm not 100% sure I can use that diagram to wire up my consult port. Thanks.
#10751 |
I need some help on mounting a fmic on my s13 with an aero bumper. I know that i have to cut off the inner bottom part of the bumper but is it possible to keep the bumper support on so that the bumper can be kept aligned perfectly. Im open to any ideas lmk through pm so it'll be faster. Thanks
"Team Abunai 671" |
#10753 |
Hey guys, I've read a million times that Part Shop Max competetion coilovers are a little on the harsh side in terms of street duties. I was just wondering if I swap the springs to their new SLL range and get them in 8/6 rates will it be smooth(er) sailing?
#10754 |
![]() Join Date: Nov 2011
supp guys please pm me answer.
Im about to install pbm front lower control arms and tension rod in front cusco 8 piece set in rear. when i go to get alighnment. Do i tell the shop i want -2 camber all around? or how does that work? |
#10755 |
Pull it and re-solder one of the pins on the back. lower left hand corner i believe. Saw a write up for it somewhere.
lurk lurk lurk |
#10756 |
![]() Join Date: May 2008
Trader Rating: (26)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 26 reviews
Have a dumb question but here's a picture of the rubber mount that is for the bottom of the radiator... Its been almost 2 years since I took this out. I know the mount fits into there but the metal bracket..is that metal bracket suppose to fit between the grooves on the rubber grommet ??
![]() Thanks for any help! |
#10757 | |
When you rotate, does the distance between the bottom mount and the spring perch change?
#10758 |
sorry if this has been asked before but i'm doing the z32 conversion with a 5 lug swap on my 93 s13. What brake master cylinder works best or would any of them that come off the 300zx work? Sorry kinda new to this.
#10759 | |
![]() Join Date: Nov 2009
![]() Feedback Score: 35 reviews
The Definitive 300ZX Brake Swap Paqe |
#10760 | |
lurk lurk lurk |
#10762 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
Stupid simple question, but can I run HIDs in my high beams on a zenki S14? I want to run a stupid color, but don't want shit from cops. So I was gonna get Sylvania SilverStar Ultra bulbs for my low beams, and and HID kit for my high beams. And which one would I have to run? If I remember correctly, low beam is H4, is high beam the same?
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#10764 |
![]() Join Date: Jan 2008
Trader Rating: (92)
![]() ![]() ![]() ![]() Feedback Score: 92 reviews
lol one last question..does anyone know how to fix that black pad on the clutch pedal ( the one that presses the clutch interlock switch???? i found the black round pad in pieces on my foot board any tips ?
#10766 |
![]() Join Date: May 2011
I just installed SPL outers and 350z inners on my s13, i have stock knuckles and the instructions said to use just the one cone shaped spacer. but when i set it down on the ground the tie rod isn't level anymore. it's level in the air though (obviously because suspension isnt compressed) should i add the washer style spacers to correct the angle when its down?
#10767 |
![]() Join Date: Aug 2011
Ok, I hope I don't get too flamed for this, buuuuut I am a cheap ass right now.
I am looking at ordering an exhaust for my stock S14 off eBay. Has anyone bought one recently? What is a good brand to get from? I have been reading up on some exhausts and looked on YouTube and they sound nice for being eBay. I am just not sure which one to get from them. I know I want to get the 2.5" piping instead of all the 3" ones on there. This is mainly just a temporary fix but I still would like something that sounds nice and not raspy. I am also looking at just getting the N1 single tip style instead of the duals. Mainly the only brands i have seen are Top Street King, K2, KO Speed, DotCom Racing, and iPex Motoring. A few more but like I said, a lot of them are 3" piping. |
#10768 | |
Mighty Car Mods - How To Repair Scratched & Guttered Wheels - YouTube |
#10769 | |
#10770 | |
![]() Join Date: Sep 2010
