05-04-2012, 10:38 PM | #10591 |
The SOHC cluster did the same exact thing. I get what you mean though. Thanks, but i found this video in youtube that makes sense why my cluster isn't working. Now i need to try it out.
240sx KA SOHC TO DOHC SWAP WIRING PART 1 KA24DE KA24E S13 S14 1080 HD.mp4 - YouTube
05-05-2012, 10:41 AM | #10592 |
After looking at my replacement front fenders and the ones currently on the car, it looks like I'll need more of the bolts and clips that fasten everything together.
Anybody know where I can get more of those?
05-05-2012, 02:02 PM | #10597 |
Trader Rating: (32)
Feedback Score: 32 reviews
Being a hicas 240 didn't effect my car when I had 17x9+15 on front and rear...I don't see why it would, the rear tie rods are smaller than the factory rear toe arms non-hicas 240s come with.
05-05-2012, 03:22 PM | #10599 |
like white with a little blue sometimes just white or some times black i looked at the emission paper and it fail'd HC GPM and CO GPM
the limit for HC GPM is 1.5000 (my car had a reading of 5.9348 ) and for CO GPM is 15.000 ( my car had a reading of 54.2024) what could be wrong with my car how can i check whats wrong with it and how can i fix it so it will pass emissions . note that i have a full exhaust sytem on it headers and exhaust , bigger cams and pistons and a new ecu for the cams and pistons . |
05-05-2012, 09:18 PM | #10600 |
some one help me i took my 240 to emissions and it fail'd because it smoked what can it be it was like white with a little blue sometimes just white or some times black i looked at the emission paper and it fail'd HC GPM and CO GPM
05-06-2012, 10:45 AM | #10601 |
An S13, stock at the moment.
05-06-2012, 12:40 PM | #10602 |
gti-r intake manifold on s13 engine worth it?
Look at this.. JDM S13 SR20 Quad Throttle Turbo SR20DET Engine Nissan Silvia 180SX Motor ITB | eBay |
05-06-2012, 02:19 PM | #10603 |
well, I have a s13 sr and it smells like its running hot/burning something. but if i turn my fan on for like 15-30 seconds or whatever, the smell dies down. i can't see my temp (i cut the sensor wire to extend it and it doesn't work now for some reason) but before that, it never went above 170. I have no front bumper on, so its getting plenty of air and i have dual electric fans. I don't think there's any smoke. and I was down to about half way with my oil so i'm thinking it may be burning oil?
05-06-2012, 10:19 PM | #10605 |
on the z32 ebrake set up
does the cable feed into th ebacking plate from the front of the back (of the car) reason i ask is cause previous owner kindly labeled everything but its confusing the shit out of me. Passenger side backing plate says (L) on it, along with all of its corresponding parts so i'm confused as to if it should be on the LEFT side of car (drivers)
street dancer. GLEAM |
05-06-2012, 11:25 PM | #10608 |
If using the S14 water neck on an S13 SR, can I just get the whole S14 turbo line kit, or will I need to mix & match any of the lines?
And if indeed I do attempt to run it without the water lines, can the water feed on the block be plugged, or does it need to be looped into the water neck still? |
05-06-2012, 11:34 PM | #10609 |
For those of you who did the kouki conversion to their zenki using the kouki retainer on the zenki bumper support, I have a question. Did y'all modify the retainer to fit the zenki bumper support?
05-07-2012, 12:17 AM | #10610 | |
05-07-2012, 11:23 AM | #10612 |
I've posted this question in here before but I'd like to get some new eyes on the problem.
I have s14 KAT enthalpy, 740cc, z32 maf, tial 38 .5bar, ssqv. On anything past 75% throttle after it reaches 7psi, the motor (boost included) "fluctuates" (see videos). There is a happy median with the throttle where it doesnt fluctuate but its around 3/4 throttle. You can hear the fluctuation of the motor in the videos though it's only of my boost guage. I've removed all the emissions from the intake and just installed a new CXracing intercooler. I thought it was a vacuum/boost leak but none of that has helped. Any ideas on what it could be? Perhaps a tear in my diahpgragm? boost fluctuating - YouTube My Edited Video - YouTube Last edited by theriver43; 05-07-2012 at 12:00 PM.. |
05-07-2012, 12:18 PM | #10613 | |
05-07-2012, 03:05 PM | #10614 |
Does anyone know if the q45 rear hubs are the type that act as a spacer for the ebrake guide pin or if they are s14 style. I currently have z32 rear brakes and hubs. ( the style that don't act as a spacer) but would like to swap to q45 hubs and diff. I don't want to change my ebrake set up though.
05-07-2012, 03:14 PM | #10615 |
05-07-2012, 08:48 PM | #10620 | |
Trader Rating: (38)
Feedback Score: 38 reviews
I said realistically meaning "of the real world" meaning a person with the slightest hint of intelligence wouldn't pay more than 3,500 for a convertible. Stay flossy, Florida. |
