04-19-2012, 07:54 PM | #10443 |
Does anyone make a body kit like the DMAX type III one for the kouki s14? Is the version select version IV the same? Does anyone have like a list of what body kits are the same as the version select ones? lol
04-19-2012, 07:56 PM | #10444 |
Im stuck between getting an rb20 zenki or a stock ka24 zenki. Would it be better to go with the rb20 zenki? Not sure how much more power the rb20 has over the ka24.
04-19-2012, 08:32 PM | #10445 | |
Stock RB20 has around 218hp according to wikipedia Stock KA has around 155hp. If it was me id try and find an unmolested zenki (if thats what you want), and do the swap yourself or take it to a legit shop so you know it was done correctly and wont take a shit on you because of wiring hackjobs, shortcuts, etc. |
04-19-2012, 09:50 PM | #10446 |
hey guys quick question. wonderin if i could get a lil help.
everytime i have my parking lights and/or headlights on, if i tap the dash with my fist or go over a bump hard enough all the cluster lights turn off and sometimes dont turn back on until i hit another bump hard enough. the headlights and taillights stay lit though. also my digital speedo reads 199 kph when im sittin in neutral and it freezes at that. its hard to explain ish. oh. should probably add im running megasquirt v3. any help/insite or tips would be greatly appreciated! Thx! |
04-20-2012, 03:23 PM | #10447 | ||
I am talking about the other two grey hard lines. One goes down along the drivers side frame rail under the car and the other goes up past the master cylinders and then down with the fuel feed and return lines then back to the gas tank? |
04-21-2012, 12:52 AM | #10454 |
is there a 30mm rear over fender for a s14 that covers the whole quarter panel? i know origin has a 50mm.. are they the only one that has it cover it completely not molded?
04-21-2012, 03:19 AM | #10455 | |
Still throwing codes 12 and 13, but I've checked all of the connections according to the FSM as well as the components themselves. I bought a new (to me) MAF and a new CTS, yet the behavior remains. Motor idles, touch the throttle and it dies. TPS? Not throwing a code, and it seems to be okay, but at this point I'm open to suggestions. |
04-22-2012, 07:28 AM | #10459 |
Trader Rating: (32)
Feedback Score: 32 reviews
Can I remove the stock braces on the underside of the ka intake manifold? Will I damage the flange or head by running it this way? also, is there a way to run an sr20 fuel rail on a ka.....
04-22-2012, 07:59 AM | #10460 | |
LOOK HARD at the ALTERNATOR charging output. My '96(new to me three weeks ago) was throwing random codes, even when hooked up to the black box's. I checked the alternator on a hunch, and found that the alternator wasn't outputting enough, but two days later it manifested as an entire lack of charge. Had it rebuilt for $80 and bang, no codes. Codes were: Battery disconected, Check engine(orange)Emmissions knock sensor and 02 sensors, air bag sensor, and intake(MAF) gripe, however, my car's little KA was running like a champ. You may want to look at your battery, charging system, and only your intake sensors if the idle is off. Also, you may have a slight ignition gripe. Isolate the wires and check for breaks or grounds or shorts. The wire should read '0' ohms. If it has a break or is internally worn it will show resistance numbers. Just a thought or two...I really need to get a Hayn'es manual for all the computer stuff
04-22-2012, 03:49 PM | #10461 |
They are MRR HR2 wheels
HR2 Wheel - MRR Design
.com |
04-22-2012, 04:15 PM | #10462 |
HELP!!!!
So I just tried to install my Godspeed rear camber kit into my 1998 S14 and the little gold connections that lead to the bushings seem to be to wide, i.e. they wont fit into where I pulled the stock ones out. I could fit one in easily but to have them on both sides It looks like I need at least another 1/4 inch. Has anyone had these camber arms and had this issue? As you can see the stock one seems to be quite a bit narrower... |
04-22-2012, 07:55 PM | #10463 |
Trader Rating: (32)
most aftermarket camber arms (cheaper ones) come with 2 sets of spacers, one set is wider than the other...if yours only came with the one set and do not fit, either bend the mounts tabs on your car out a little, return the arms, or grind down the spacer...
04-22-2012, 08:06 PM | #10464 |
c'mon really? guessing thread pitch is the worst you can do. Buy a fucking thread pitch gauge they are at the VERY most $50 but usually less than $10. Hell the ones from Snap-On are only fucking $13.
If you don't want to spend money on a very important tool you will love for the rest of your life, take that other fitting out and take it to a hardware store and match it up. Hell, take the whole thing to a hardware store.
Drives a BRZ and is building a V6 S12 coupe. |
04-22-2012, 08:55 PM | #10465 |
Trader Rating: (58)
Feedback Score: 58 reviews
Hard to say what they may use on the knockoff sandwhich plates.
Alas I'd not even bother with the right thing...I'd just weld the fitting onto the block and call it a day. If you want, bring it up one night and we'll burn it on. You show me a snap on pipe thread gauge for 13 bucks and I'll buy one extra for ya...as if it exists I've never been able to find it. No reason to flame someone especially if you're going to give him wrong information atop of it all.
04-22-2012, 09:34 PM | #10466 | |
AFC #1
04-23-2012, 07:26 AM | #10468 | |
Any one else dealt with Godspeed rear camber arms?? |
04-23-2012, 08:21 AM | #10469 | |
Trader Rating: (58)
He needs to determine pipe thread. That particular thread gauge doesn't have any pipe on it I wasn't so much concerned with the pricing on it, just that it didn't have pipe thread on it (unless mine is old and didn't have it). I have a real pipe thread set and it's a bunch of plugs and dies.
04-23-2012, 08:27 AM | #10470 | |
Trader Rating: (58)
