04-02-2010, 07:18 PM | #991 |
Trader Rating: (92)
Feedback Score: 92 reviews
ecu gurus here is my question most ecu ive seen for s13 usually are marked with a number ie 13 .. mine has ep ?? is there a difference with a numbered ecu vs lettered ones ?
04-02-2010, 08:18 PM | #992 | |
you'd be lucky to get them off without one |
04-02-2010, 08:22 PM | #993 |
^ Even then if their really seized in there you'll just end up pulling the bearing apart. I've done it acouple times, ended up having to press them out.
-Trevor |
04-02-2010, 08:22 PM | #994 | |
but it is probably leaking from around your tail lights which you can purchase a tail light sealant from nissan (most kouki tails come with it) second question- yes. |
04-02-2010, 08:22 PM | #995 |
04-02-2010, 08:26 PM | #996 | |
and yeah the tension rods will help |
04-02-2010, 11:32 PM | #998 |
your best bet would be an s14 diff, pops in super easy just change the diff cover, and buy aluminum diff bushings (s14s use bushin g on the front of the diff but welded is the shit, before my car started acting up I drove with the welded no mater what, even in the rain, just have to be careful, its not as bad as people say Z32 requires a lot of modification
04-03-2010, 12:27 AM | #1000 |
K, so how in the hell do u get a drivers side window in a s13 with power window's? I had the slider thing out, and im lost at how to get it in with the window. lol.
04-03-2010, 10:31 AM | #1002 |
the j30 i had no probs with... u just need to grab the longer bolts in the front of the diff... and of course ur old pumpkin
SPEED KILLS!! Drive a Honda and live forever!! |
04-03-2010, 01:27 PM | #1003 | |
04-03-2010, 05:48 PM | #1005 |
Does the front s13 coilovers fit the s14 front?? To be more specific it will be the megan racing s13 coilovers, will it fit on a s14? I know the back doesn't fit so, no comment on the back plz..need a yes or no answers..thanks..
04-04-2010, 08:48 AM | #1006 |
its not worth it at all it requires alot of modification, and there is no reason for it the r200 is a very strong differential it has been in 800hp cars without fail, you will have to completely modify your rear subframe,
04-04-2010, 12:44 PM | #1007 | |
drill the lower bracket holes 1/16" bigger the main thing is s13 coils are a lot shorter than s14 so you can go super low 8) |
04-04-2010, 02:27 PM | #1008 |
Got a quick question...my S14 is auto, and for some reason the reverse doesn't engage anymore. Now before it completely stopped engaging, I put it in reverse and rev it a couple rpms(acting like it was manual) then it engage and reverse. Now I guess it completely died and doesn't reverse. Goes fine in drive and the other 2 gears. Any ideas?
HI HATERS! from the left to the right |
04-04-2010, 05:30 PM | #1009 | |
Bandwagon.
or if you dont know measurements thats 14mm |
04-04-2010, 06:48 PM | #1011 |
Ok in response to some of the previous posts, I'm the friend with the hub. IMHO, hub puller is the only way to go. Not so much that it pulls the hub, but it pushes out the axle which makes pounding off the old hub less strenuous. Made my life way easier. Hub done with puller took about half the time. As far as filling hatch holes on the cheap, the GT spec trunk bar bolts into four holes in the trunk, those four holes have rubber stoppers from the dealer/factory. These stoppers happen to fit perfectly in the rear wiper hole when it is removed. And as far as the antenna hole: rubber differential plugs from a newer dodge diff is the perfect size for a tight seal. Have not had any leaks from either on my car.
@MMyriad Last edited by MidwestMyriad; 04-04-2010 at 10:22 PM.. |
04-04-2010, 07:09 PM | #1013 |
When I attempt to tighten my clutch pedal in my s14, the rod that the nut sits on starts to twist, is that normal? It seems like I'm going to twist it and break something.
04-04-2010, 09:37 PM | #1015 |
JDM 94 95 Nissan Silvia S14 Zenki Navan Grill Grille - Cross Cultural Connections - Has anybody gotten anything from this site? i'm wondering if its legit, if not can you point me in the right direction?
1995 s14 Zenki - R.I.P 1992 s13 Zenki Coupe - KA-T |
04-04-2010, 10:14 PM | #1016 |
Shiftin: Transmission should work, I think the only difference may be the bell housing, but not sure they could be the same too. All 240sx manual transmissions are the same though.
@MMyriad |
04-04-2010, 10:34 PM | #1019 |
HHAAA it's tight enough, no wait, i mean i don't have a vagina. Besides the 10mm nut on the lever, anything else?
@MMyriad |
04-04-2010, 11:08 PM | #1020 |
So s13 Coils dont work in the rear of a s14?
