#991 |
You're welcome.
You can see one fitting is on the end of the master going left with a 90 degree fitting and one is on top with a 90 degree fitting. "The top port on the hand brake goes to the OEM master cylinder's rear brake output, the end port of handbrake goes to the hard line that used to screw into the OEM master." The bleed is the same process as if you replaced your brake lines only there is more air because of the cavity inside the handbrake's master. You'll need two cans of fluid and you'll probably bleed everything twice to get all the air out.
#995 | |
When I do pull the handbrake, I let the foot brake go to the floor and then I pull the handle. The combo moves an awful lot of fluid.
#996 |
Youre not the first to express that opinion, I'll see what I can do.
#997 |
![]() Join Date: Apr 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
I saw a seat on your site and I think it looks pretty cool with that MAX logo. But, whatever you guys decide is best. Any clue when they'll come out? Just to know how long I have to be excited for
#998 |
I dont know when yet. I do know there is progress being made.
#1000 |
coolers are in stock, lines and adaptors are not.
2 coolers at $60 ea is $120. shipped to you is ... Zero... you live in San Diego, come in and pick them up. Or $15 extra if you still need them shipped.
#1001 |
![]() Join Date: Dec 2006
price of hicas delete bars shipped to 45805
are they any other suspension parts that will work on super hicas other than the coilovers
#1002 |
$80 shipped.
All of the other parts work besides toe rods.
#1003 |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() Feedback Score: 6 reviews
does this s15 have the PBM coilovers? if so, for how long? what other suspension PBM suspension pieces are on this car??
http://essencegarage.wordpress.com/ |
#1004 |
![]() Join Date: Apr 2006
Hey dan, Is there any way you can measure a Ruca completely shortened without nuts on it.
Im trying to find something shorter then my Dmax ones.
2015 Subaru Outback Overlander - Wagonofdoom |
#1006 |
Ya my car gets all of the parts shop MAX goodies, many of them in prototype form, I always volunteer to be the USA lab rat for new items. I've been running the coilovers longer then anyone here in the USA almost 2 years.
#1007 |
looks like about 282mm on hole centers as you described.
#1008 | |
Theres a removable CNC hub ring because some wheels can do it some wheels cant: ![]()
#1009 |
![]() Join Date: Jul 2005
So 40 bucks for shipping then or do the rings cost extra? Also could you tell me the outer diameter bore for the rings. Since the inside of it should be 66.7 or something like that. I can compare it to the size of the inner bore of the wheels. I apologize for all the questions, I just want to get it all right the first time.
#1010 |
$10 each set for shipping to you.
The current pricing on the new spacers (weather 4 or 5 lug) with removable rings are: 15mm $70 20mm $80 25mm $90 30mm $100 They used to be 10 bucks less per pair when they were 1pc. The ring is about 66mm on the outside and 56mm on the inside sits about 8mm above the surface.
#1011 |
and is that without locking nuts?
#1012 |
yes its 300mm wit deez nutz
#1013 |
kk
ill measure my shit this weekend
#1015 |
Tracking numbers have been sent to your email address. Thanks!
#1016 |
WOOOO HOOOOO subframe spacers are back in stock at parts shop MAX USA!! A quick cheap and effective mod that eliminates common wheel hop problems on Nissans and provides a more direct rear suspension feel with direct power transfer between drive train and rear wheels. Installs with factory rear sub frame bushings sandwiched between the rigid spacers. C shaped upper collars make installation quick and easy eliminating the need to completely remove the rear sub frame. 100% CNC Billet Aluminum with gold annodizing. only $50
#1017 |
![]() Join Date: Aug 2005
![]() Feedback Score: 11 reviews
the pullys you have for the s13 sr they are stock size? if so how much shipped to 91765? and colors adv?
and what needs to be mod to fit the intercooler? prob the same for all large front mounts but had to ask. Last edited by joe3180; 01-07-2008 at 04:31 PM.. Reason: didnt wanna multi post |
#1018 |
The pullys are stock size, and come in colors but were out of them right now.
Intercooler requires you to move the battery, and cut the metal there for the pipe routing, it comes with everything but the upper hot pipe and the coupler for the throttle body. Best thing about it is that it is tube fin, not bar plate.
#1019 | |
![]() Join Date: Nov 2006
Can I get a price for S13 ruca's and subframe spacers shipped to 94558?!
Thanks Dan!
![]() $pending dead pre$ident$ J@CK@TT@CK! |
#1020 |
Its $240 for both items shipped but we ran out of ruca's today. If you just want the sub frame spacers now those are $60 shipped by themselves. We have more rucas coming in from Japan in a week.
