Old 04-15-2009, 03:17 AM   #961
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
they're either OE brand, or knock off, not both. sorry, just nitpicking.
cdlong is offline   Reply With Quote
Old 04-15-2009, 03:58 PM   #962
A&M Boy
A&M Boy will become famous soon enoughA&M Boy will become famous soon enoughA&M Boy will become famous soon enoughA&M Boy will become famous soon enoughA&M Boy will become famous soon enough
Send a message via AIM to A&M Boy
Not in this case; OE Wheels is the company that makes knock off wheels for mustangs, vettes, etc. (not to be confused with Original Equipment)
tamscc.org
A&M Boy is offline   Reply With Quote
Old 04-15-2009, 08:24 PM   #963
cdlong
ha! i stand corrected.
Old 04-18-2009, 02:07 PM   #964
Grimace
Grimace is an unknown quantity at this point
Send a message via AIM to Grimace
WOO, I can finally join this thread. Prepped the car for the new wheels. 275/40/17 up front . Wheel specs are 17x9 +26, The car is on KYB AGX struts, With Eibach pro springs.
Grimace is offline   Reply With Quote
Old 04-29-2009, 08:54 PM   #965
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
Nice how did you clear the 275's? Fenders?
Mine in the rear currently-
Before Stance Coils-
After (This is way lower than I thought it was going to be and didnt have time to adjust it higher but still dope)
18 x 9 +24 Rear +9 Fronts (15mm spacer)
245/40 fronts and 275/35 rears
SuicidnS13 is offline   Reply With Quote
Old 04-30-2009, 11:38 AM   #966
brunswick240
brunswick240 is making a name for him/her selfbrunswick240 is making a name for him/her self
Send a message via AIM to brunswick240
Those 275s look awesome on the hotwheels. rear pic?
brunswick240 is offline   Reply With Quote
Old 04-30-2009, 08:21 PM   #967
SuicidnS13
SuicidnS13's Avatar
Once I get the suspension dialed in ill push the car outside for more pics. That was just my teasar. The rb isnt in the car yet.
Old 04-30-2009, 08:39 PM   #968
PyroTecK
PyroTecK is an unknown quantity at this point
i think i finally have something worth posting on here.
specs are:
F - 17x9+24 effective (3mm spacer)
R - 17x9+27
245/40/17s all four corners
stock metal rolled slight pull
alignment specs = all fked up (getting it sorted out next week)
i could deff go wider in the back so once these are done ill step it up a bit, i was concerned w/ the front since alot of people told me i wouldnt be able to fit 245's in the front. clearances are pretty tight... maybe 1mm between the wheel and the spring perch.
PyroTecK is offline   Reply With Quote
Old 05-01-2009, 08:05 AM   #969
xs240
xs240 is an unknown quantity at this point
ooh the new kumho tire
xs240 is offline   Reply With Quote
Old 05-01-2009, 09:38 AM   #970
McCoy
McCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of lightMcCoy is a glorious beacon of light
New track setup for 09...
Enkei NT03 17x9.5 +38 wheel
255/40/17 RA-1's.
Richards V3 housings with Koni 86XX inserts F/R
10mm spacer up front to clear coilovers.
Alignment:
Camber -2.5F/-1.6R
Caster 8.3
Toe 1/16" toe-in F/0 toe R
McCoy is offline   Reply With Quote
Old 05-01-2009, 10:02 AM   #971
xs240
Camber settings?
Old 05-01-2009, 10:46 AM   #972
McCoy
Originally Posted by xs240 View Post
Camber settings?
Getting the alignment on Monday... but I should be close to -2.5F/-1.5R currently.
Old 05-02-2009, 11:53 AM   #973
Grimace
I haven't yet, The deal for the rear wheels fell threw so im stuck with only 2 wheels right now . After I sort out a couple of other things ill be buying another 2 from the dealer.
The rears clear easy, As you know. Just a little roll. The Kouki front is a little wider then the Zenki's. If you roll them right, You're golden.
Old 05-02-2009, 12:37 PM   #974
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
You probably couldn't get away with this much offset with coilovers though. Do you agree?
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 05-02-2009, 02:32 PM   #975
Grimace
Yeah, Coilovers would have problems. But nothing that couldn't be over come. Slap on a spacer and roll the fender a little more. No big deal.
Old 05-03-2009, 12:48 PM   #976
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
Originally Posted by Deftec View Post
Here's what I found I'll be running(getting these super cheap from a friend)
255/50/16 MT D/R on stock z32 rims. Think I'll have to do any roll/spacers?
Just for reference, these fit w/o any spacers. I did have to roll the top of the fender though due to the car squatting enough when in full boost to make the tire rub.
http://i98.photobucket.com/albums/l258/Deftec/signew-1.jpg
Deftec is offline   Reply With Quote
Old 05-05-2009, 02:07 PM   #977
McCoy
Camber settings?
Alignment:
Camber -2.5F/-1.6R
Caster 8.3
Old 05-17-2009, 06:04 PM   #978
G240
G240's Avatar
G240 is on a distinguished road
Here are a few test fitment pics. 18x9.5 +23 MB Battles wrapped with 255/35/18 Nankang tires. Hopefully I can get the suspension adjusted, fenders rolled and aligned in the next two weeks.
Cheers!!
G240 is offline   Reply With Quote
Old 05-25-2009, 12:44 AM   #979
gottdeskrieges
gottdeskrieges will become famous soon enoughgottdeskrieges will become famous soon enoughgottdeskrieges will become famous soon enoughgottdeskrieges will become famous soon enough
Send a message via AIM to gottdeskrieges
Been reading this thread and was wondering if you guys could give me your advice. Tire fitment on rims on a s13 hatch w/ 2jz approx hp around should be 600 on pump.
18x8.5 +35 F and 18x10.5 +35 R
widest tires i can put on front/rear with roll/shave.
Spacers needed? I have z32 f/r calipers, tanabe coils as well.
Thanks in advance and im still looking over this thread as well as others.
Jay
gottdeskrieges is offline   Reply With Quote
Old 05-25-2009, 01:58 AM   #980
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
S14
A-Tech Final Speed 17x8 +35
Front - Dunlop Direzza Star Spec Z1 215/45-17
Rear - Federal 595SS 235/45-17, upgrading to star specs soon.
Major Mods
-SR20DE
-Ebay KA24 intake, heavily modified
-RSR 4-1 Header
-Lightweight flywheel
-ISIS short throw shifter
-R33 master cylinder
-Front, rebuilt Z32 calipers with turbo 180sx stock rotors
-Rear, C33 caliper/rotor/drum ebrake assembly with R33 cables
-Agency Power braided stainless brake lines front and back
-Cusco brake stopper
-Front strut tower bar
-Rear strut tower bar
-Front tension rod bar
-Energy Suspension steering rack bushings
-Cusco adjustable tension rods
-Ohlins adjustable struts
-Megan Racing drop springs
-Aluminum subframe bushings
-1 1/8" rear sway bar
-Megan Racing rear sway bar endlinks
-K's rear subframe
-Delrin SOLID motor mounts
-Peak Performance Pro transmission mount
-Cusco adjustable camber arms
-Wicked Tuning adjustable toe arms
-Balltec 1.5 way LSD
HPDE, Gymkhana, Touge
HYPNOTIK is offline   Reply With Quote
Old 05-26-2009, 02:30 PM   #981
mehsilvia
mehsilvia's Avatar
Trader Rating: (39)
mehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfection
Feedback Score: 39 reviews
YOUR CHASSIS: s13
WHEELS: XXR 507's, 18x8.5 +35 18x9.5 +35
TIRES: Toyo Proxes R888 245/40ZR18 275/35ZR18
MISC DETAILS: 96 KADE, Tein SS Coilovers, Q45 Front Brakes
PURPOSE OF CAR: Both, this is my track set
PICTURES: So, i cant say that these actually "fit", but they are what i would consider "maximum" LOL
I will need to raise the rear suspension, and most likely will require a slight fender pull to clear these 275's.
mehsilvia is offline   Reply With Quote
Old 05-26-2009, 05:13 PM   #982
DeadlyZ33
DeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really niceDeadlyZ33 is just really nice
^^ nice tires, shame about those rims tho, hopefully gonna grab some R888's soon too for my z.
DeadlyZ33 is offline   Reply With Quote
Old 05-27-2009, 12:41 PM   #983
Zacho
Zacho is an unknown quantity at this point
I know its not S-chassis but oh well. R32 GTR
18x10.5 with effective 15 offset. 295 Hoosier A6's all around.
The fenders are rolled completely flat but not pulled. Looks absolutely un fucking real from behind if you are driving behind it. The green wheels just don't look good in photos. If you saw them in person they look 10x better.
Zacho is offline   Reply With Quote
Old 05-27-2009, 01:08 PM   #984
xs240
Then take some rear pix hehe
Old 05-27-2009, 09:21 PM   #985
bblack_91240
bblack_91240's Avatar
bblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nicebblack_91240 is just really nice
^^^ I second that!! Lets see that backside
DD: '05 Saabaru with full JDM STi 6spd swap
Project: '91 S13 Hatch SR20
bblack_91240 is offline   Reply With Quote
Old 05-27-2009, 10:17 PM   #986
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
mehsilvia: WOW, thats looks like MAX fitment on an S13 w/ Stock fenders, I dont think I've seen that lol
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 05-28-2009, 02:32 PM   #987
bardabe
bardabe's Avatar
1991 300ZX Z32 Twin Turbo 5 Speed
Purpose of Car, Daily Driver, Wangan Monster, Weekend Drifter and Grip monster
Set up
17X9 +35 up Front
17X10 +12 in Rear
255/40 ZR17 up Front
275/40 ZR17 Rears
Roll + Slight Pull No Rubbing no complaints. could go lower but then I'd polish my frame rails driving just on the freeway
Review Thread
bardabe is offline   Reply With Quote
Old 06-01-2009, 09:45 AM   #988
moonshinekouki
moonshinekouki's Avatar
moonshinekouki is an unknown quantity at this point
guys whats an ideal tire size for a s14 running
F: 19x10 -6 (High Disk)
R: 19x12 -12 (Low Disk)
5x114.3 for daily driving?
with fender flares of 30mm in the front and about 50 mm in the rears they are bings.ca fenderflares.
thanks
mikey
moonshinekouki is offline   Reply With Quote
Old 06-01-2009, 10:20 AM   #989
xs240
Uhm.. 'daily driving'... well... i dont know about inner clearance someone will help but ideally a 10" wide tire should fit a 275 wide tire or 285 wide tire...
A 12" wide tire should be able to fit a 335 wide tire...
If you want to know how to stretch such wild wheels, wrong thread
Old 06-01-2009, 03:13 PM   #990
240sxScores
240sxScores's Avatar
240sxScores is making a name for him/her self240sxScores is making a name for him/her self
Send a message via AIM to 240sxScores
thanks
mikey
I dont think this thread (maximum tire) and your wheels specs, dont exactly go together. With trying to fit/clear wide tires.
Usually wide tires for our cars are gonna be on wide wheels like yours but not with such negative offsets, that would be sticking out wayyyy past the fender, more then necessary.
240sxScores is offline   Reply With Quote
