Old 04-21-2012, 06:49 AM   #961
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Originally Posted by KA-Life86 View Post
I have a zenki w all adjustable arms and coils, I'm looking at a set of 18x10 +15 wheels, I would love to run 10 inch wide wheels on all 4 corners w the same size tires (245/35 maybe?) front and rear so I can keep them rotated as well. I know I can fit these under stock metal w a roll and probably a pull in the rear, my question is, besides tucking the harness and a good bit of BFHing on the inner wheel wells, is this really logical? I do intend on running it zilvia low, car is not a dd or a super duper drift car, just prefer to drive it around town and maybe some quick blasts around the parkway. Spacer in the front? I will go 9.5s if I have to but they only come in +20 which means bigger spacer which in my mind is no bueno
Its doable...17x10 +18 on 255/40-17 NT01s, no spacers but then my coilovers are pretty skinny (Aragostas)
CLICK HERE!!!
Old 04-21-2012, 06:52 AM   #962
fliprayzin240sx
Originally Posted by I'm Redline View Post
I have been through this thread and all I see are 18's and over 8" wide. Cool, but not what I want since I am going with an OEM 'sleeper' look.
What size in a 17x7-8 wheel will fit, turn, and work with shocks and springs and a 225-17-45 tire? I want to run tsuraichi, tucked, no poke, no oni kwon camber, just a basic fit a 225 on a 17 and make it work without doing anything more than maybe a little bat work between the fender and tire.
Am I on crack? The OEM 5 lugs sit an inch deep with 16x 205, so that means a 225 should be able to work with a little +/-(no clue, not expereinced with this stuff...motors, yeah, wheel/tire fit, not so much)
Then why dont you run similar sizings to GTR wheels? 9j with 30mm offsets? Actually, run +25 so itll clear the front suspension. You'd barely have to touch the fenders with those sizing on 225/45-17s.
CLICK HERE!!!
Old 04-21-2012, 07:00 AM   #963
KA-Life86
KA-Life86 is an unknown quantity at this point
Just found out they don't have the 10s in stock. Looks like I'm goin 9.5s +20. Will I be able to keep pretty minimal rear camber on these and stay close to flush
KA-Life86 is offline   Reply With Quote
Old 04-21-2012, 07:29 AM   #964
fliprayzin240sx
How much camber will depend on how much you pull the fenders. IIRC, on those pictures, I'm running almost 2* in the back and about the same up front.
CLICK HERE!!!
Old 04-21-2012, 07:51 AM   #965
I'm Redline
I'm Redline's Avatar
sent you a pm flip, thanks for the starting point
My work in progress...
Old 04-21-2012, 07:10 PM   #966
Xyle
Xyle is an unknown quantity at this point
I want to get rims for my s14 zenki in 18x9.5 front and 18x10.5 rears. I currently have stock suspension (everything stock) I plan on getting coilovers and was wanting to know if I get +0 offset or +12Fronts and +15Rears which would require less work? I don't want to be HELLAFLUSH just lowered to about a finger gap between fender and tire.
As for tire sizes I was told 225/40 to keep MPH somewhat accurate. Also if I eventually get wider fenders would it be best to go with +0? I really don't like the thought of adding spacers to the hub.
"Thanks in advance for any ones input!"
Forgot to mention I have Z32 brakes all around.
Xyle is offline   Reply With Quote
Old 04-21-2012, 08:13 PM   #967
25BajaOutlaw
25BajaOutlaw is an unknown quantity at this point
total nuby question but this looks like the place to ask it.
i recently purchsed a 1998 s14 SE. Stance GR + coilovers, 300zx brakes all the way around.
if anyone has some advice with the following wheels and tires combo let me know.
18" XXR 527 staggered
19" Stance SC-5ive stagered
20" Rohana RC10 (pipe dream haha)
25BajaOutlaw is offline   Reply With Quote
Old 04-22-2012, 06:15 AM   #968
fliprayzin240sx
They all require work body wise, less work means more camber. More camber for the rear means more aftermarket arms than just a coilover. All those setups will stick out pass the fenders under stock height, stock camber, stock fenders.
20"s? Are you trying to donk this out?!?! Sell the 240 and get an accord and donk that one out.
CLICK HERE!!!
Old 04-22-2012, 06:38 AM   #969
Xyle
Would you know by how much they will stick out so I know how much rolling and pulling I will need. Also whats the minimal amount of offset will be needed to fit coils and brakes?
Old 04-22-2012, 07:13 AM   #970
fliprayzin240sx
Again, all depends on how much camber you're willing to run. More camber you run, the less you'd have to massage the fenders. Also depends on how wide of tires you want to run. Honestly, if you're not planning on slamming the car, I'd go with a more conservative setup. 9j +15 or +18 and 10j +20 or no lower than +15. Also, offset has absolutely nothing to do with brake clearance. It all depends on the wheel design.
CLICK HERE!!!
Old 04-22-2012, 08:13 AM   #971
I'm Redline
Flip, I am liking those RPF1's. Looking at that pic I can see that what we have been discussing will totally work for me and keep just a small amount of tuck with the 17 or 18 -9j's +30. I think maybe just a light bit of lower with a slight rise to the rear will give me that slightly racy stance I like with shocks and springs, but if I save longer for the coil overs it's a done deal either way. Volk TE37's, Enkie RPF1's, or Ray's Gram Lights are definately in the future, but no body kits of wings for my ride...oem looks, a little drop, and just the right amount of tuning on brakes, suspension, and motor to give some really fun all around performance
Old 04-22-2012, 08:26 AM   #972
fliprayzin240sx
Like I said, if you decide to go with the OE sized 9js, kick the offset down to +25 to give yourself some wiggle room. Depending on the coilver you get, it may or may not clear the front coilovers with +30s. If you decide to go wider, then you'd also have to go lower on the offset to compensate for the coilover clearance. Like I said, dont hesitate to PM me if you got more question.
RaY
CLICK HERE!!!
Old 04-22-2012, 11:45 AM   #973
SharkBite
SharkBite is an unknown quantity at this point
New to the forum, recently went to a xdc hin event and saw a bunch of cars that run wheel spacers. Besides the obvious fact that they push your wheels farther out, why do so many run them? Nobody is worried about wheel bearing issues?
Sent from my HTC Sensation 4G using Tapatalk 2
SharkBite is offline   Reply With Quote
Old 04-22-2012, 12:15 PM   #974
shalezzz
shalezzz's Avatar
shalezzz is an unknown quantity at this point
They run them because they want a specific type of fitment or brake clearance they don't make every wheel in everyoffset. they are hubcentric spacers and I would imagine they put just as much stress on the studs/wheel bearings as the same wheel in the lower offset so 17x9.5 +0 = 17x9.5+o wether a spacer is used
shalezzz is offline   Reply With Quote
Old 04-22-2012, 12:32 PM   #975
Turbo Nismo
Turbo Nismo's Avatar
Trader Rating: (18)
Turbo Nismo is an unknown quantity at this point
Feedback Score: 18 reviews
I bought for my S14 some Gramlights 18x9.5"F & 10.5"R with +12offset and I'm using Function & Form FII, which tire size do you recommend me? I don't want to be too stretch in rears, but I don't wanna pull or camber too much. Just roll and minimal pull.
IG: chris___s14
Turbo Nismo is offline   Reply With Quote
Old 04-22-2012, 12:44 PM   #976
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
I'd run 225/40 in the front and 235/40 back. I also prefer 40 series tires over 35. Nice mild stretch not too aggressive.
Old 04-22-2012, 12:44 PM   #977
Te37
Te37's Avatar
Te37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choicesTe37 has made poor choices
I have a 255/35 on my s14 rear with 18x10.5+15...looks good not a terrible stretch...normal run of the mill tire shops can do it. Just a roll with -1.5 camber
Best picture I have on me...Bead is alllllmost seated
Te37 is offline   Reply With Quote
Old 04-22-2012, 12:51 PM   #978
Turbo Nismo
Trader Rating: (18)
Thanks for quick response guys!
Could you post more pics please. Thanks again.
IG: chris___s14
Old 04-22-2012, 01:00 PM   #979
fliprayzin240sx
Because they're too cheap to buy wheels that fit...
CLICK HERE!!!
Old 04-22-2012, 01:52 PM   #980
Te37
Te37's Avatar
Old 04-22-2012, 10:51 PM   #981
ervin_r56
ervin_r56 is an unknown quantity at this point
does anybody have 245/35/18 on 11.5" wheel or is that too much?
ervin_r56 is offline   Reply With Quote
Old 04-23-2012, 12:15 AM   #982
zbarsuglia
zbarsuglia's Avatar
zbarsuglia is an unknown quantity at this point
OK so I have a question that is in need of answers lol.
I have a s14 rolled fenders in front an rolled/newspaper pull in rear and was wondering if this setup will work without any more of a pull.
18x9.0 +1f
18x10.0 -15r
with 225/40s I dont mind running camber, I actually prefer it.
Im looking into Leon Hardiritt orden, I also dont know if the low disk will clear z32 brakes..
zbarsuglia is offline   Reply With Quote
Old 04-23-2012, 10:06 AM   #983
fliprayzin240sx
Shit, 265s were stretched on my 11j. 255 is roughly 10 inches so your trying to stretch 10 inches over a bead thats atleast 11.5 inches. This is what 265/35-18s look like on 11js:
CLICK HERE!!!
Old 04-23-2012, 10:09 AM   #984
fliprayzin240sx
18x9.0 +1f
18x10.0 -15r
Rears will be another 10mm further out that these.
And no, low disk faces wont clear Z brakes up front. Rears should clear but fronts, you'll need atleast 13mm spacers if its a low disk. 3-5mm if its the regular face. Only thing that clears the fronts are hi disks designed to clear BBKs.
CLICK HERE!!!
Old 04-24-2012, 08:55 AM   #985
JFoxx
JFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choices
ok, i have 18x10 +10 in the front of my s13 it has full lock clearance(barely) but i intend to put some new knuckles on it soon... how can i maintain clearance? im trying to avoid having to do a spacer, because ill have to run fender flares on a wide fender.... the main part im worried about is on my drivers side tire hitting the frame rail, beacuse ive already had to hammer that lip down for clearance as is...
i know this may sound like a dumb question, but i know there are some creative people on this thread who like to run wide wheels....
a pic for the hell of it....
and yes i know i need to drop my car in the front...im need to ensure clearance first....
JFoxx is offline   Reply With Quote
Old 04-27-2012, 02:35 AM   #986
JasianBlazin
Trader Rating: (24)
JasianBlazin is an unknown quantity at this point
Feedback Score: 24 reviews
msglength.
JasianBlazin is offline   Reply With Quote
Old 04-27-2012, 08:20 PM   #987
fliprayzin240sx
More hammer...adding spacers will only make your clearance issue worst after running knuckles.
CLICK HERE!!!
Old 04-27-2012, 11:58 PM   #988
WERDdabuilder
WERDdabuilder's Avatar
not when you got stancenation/hellaflush fucks to impress.
When the power of love overcomes the love of power, the world will know peace
Old 04-28-2012, 08:40 PM   #989
fliprayzin240sx
Not when you get fresh OEM bearings...they'll fail around 70-80k anyway, whether or not you have low offset wheels.
CLICK HERE!!!
Old 04-30-2012, 12:35 AM   #990
scargo
scargo is an unknown quantity at this point
what size tires should I get for 18x9.5 +15/10.5 +14 on an s13 ? I'm looking for no pull, just a roll.
scargo is offline   Reply With Quote
