03-24-2010, 12:07 PM | #901 | |
please people don't guess...there is a million things I could edumacate-ly guess, but I don't. |
03-24-2010, 07:38 PM | #902 |
im in the middle of assembling my sr, and im running Manley connecting rods...
heres the problem, manleys sheet specifies that the rod bolts be torqued down to 95lbs... while the factory rod bolts FSM is 33lbs... seems like an extreme difference so i checked ARP's site because the bolt is a ARP2000, and arp says not to torque their bolts past 50 pounds or so for the size i have. so we got some plasitgage to check the clearances at different torques, and from 40lb's to 50lb's im staying right at .015 despite the change in torque which is in spec but a little on the loose side. so sorry for the novel, but curious if anyone has either run these rods or has experience with them thanks
03-24-2010, 07:44 PM | #903 |
don't have an answer for you
but when dealing with serious things like internals i would make sure i have the 100% correct numbers and not just what some guy says off the internet if it were me i would call them up and clarify the correct specs and explain the situation |
03-24-2010, 08:44 PM | #904 | |
and trust me, motors been out 3 months now, as bad as i want it in, not willing to short cut to make it happen, thanks though bud appreciate the response, keep em coming guys
03-24-2010, 08:55 PM | #905 |
does anyone know if 17x9 +19 or +17 will clear coilovers on the front of a s13 with a 235/40/17 tire im running 17x9 +15 now and went 5 lug and need spacers for my weapons
03-25-2010, 06:37 PM | #914 |
Brake line Clips
I'm installing all my engine bay components again and I've hit a snag.
I need all new brake line clips (the white ones that go on the fire wall) as they are brittle and have broken. Where can I order these? "brake line clips" turns up nothing on AA/AZ, eGay et al. |
03-25-2010, 06:39 PM | #915 | |
Don't buy the crap Advanced Auto / AutoZone as they paint on them cracks right off the first time you torque them and they rust to shit. |
03-25-2010, 06:48 PM | #917 |
03-25-2010, 08:20 PM | #919 | |
Good luck, Courtesy doesn't stock them....they'll be almost impossible to find. I went to conceptZperformance.com and ordered a handful of the black two-tube ones and drilled extra holes...I can get pics tomorrow if you want. I may even have some spares...
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please. |
03-26-2010, 12:08 PM | #922 |
i think this is a stupid question but im still curious since i haven't read a definite answer...
my analog climate control is damaged, gonna change it soon i was thinking about going DCC, can i use it without all the sensors and whatnot that it uses... i mean i only turn the AC ON or OFF i don't touch anything else ever so i was thinking if it was functional without all the auto sensors and all that... |
03-26-2010, 04:05 PM | #924 | |
03-26-2010, 05:11 PM | #925 | |
Trader Rating: (26)
Feedback Score: 26 reviews
what is 4x114.3 PCD converted into inches?
ie. will this wheel spacer work with 4x114.3? description of above wheel spacer: Quote:
03-26-2010, 05:34 PM | #926 | |
4x108 is 4X4.25 |
03-26-2010, 08:06 PM | #928 | |
do any other nissan cars have pop-up sunroofs that can fit on an s13 hatch?
old 90s pathfinders have popups that look similar...
03-26-2010, 08:14 PM | #929 | |
another q
would removing the heatshielding off a ka24e downpipe cause a whole mess of problems or is it there mainly to keep the egt up for the cat? after re-gasketing the whole exhaust the heatshielding is rattling and id rather not drop it all again to weld up the tabs
03-26-2010, 08:27 PM | #930 |
this blows.. but when i rev my car, it hits red line and then revs down to about 4 grand, y does that happen? s13 ka24e hatch
SPEED KILLS!! Drive a Honda and live forever!! |
