#9031 |
![]() Join Date: Nov 2011
my friend is running my r34 wheels and they are 18x9 +30 front with 215/35 and rear 18x9 +30 235/35 and it is flush on all 4 on a s13 coupe with 2 deg camber.
#9032 | |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#9033 | ||
AFC #1
![]() Join Date: Oct 2003
#9034 |
ok, i have new plugs wires and i replaced a shot injector, it also has a new cat, i cant get past 1/3 throttle with my car bogging down and sputtering most the time. It is worse above 2800rpm, im thinking bad fuel pump what do you guys think?
#9035 | |
i just let him figure it out on his own
street dancer. GLEAM |
#9036 |
![]() Join Date: Oct 2006
i figured as much..but i have NO idea were to begin..like i said..ive checked all the wireing for the power system from the ecu to the ignitor, t to the coil pack, from the battery, from the alternator...im stuck.
#9037 |
![]() Join Date: Jan 2008
I'm getting ready to install my Z32 moog inner and SPL outer tierods here soon and was wondering if theres a problem with the moog inners.
they seem to be siezed or something because they're not pivoting on that ball at all, they're just... stiff/fixed in place. I've seen the Tiien ones with the blue lube 'n all and apparently they pivot freely.. can someone tell me wasup?? |
#9038 |
Tips on how to remove the inside rear view mirror? Trying to install my wink.
I shoved a flathead in the gap near the windshield and tried to wiggle it up and down but nothing came lose. |
#9039 | |
#9040 |
Pop the plastic cover on the headliner off and there should be 3 screws or so. Then there's a clip holding it or something along those lines from what I've read. Don't lose the clip in case you wanna put the mirror back on later because I guess it wont go back on without the clip.
#9041 | |
![]() Join Date: Jun 2011
LAME. Search will continue, for $200 I will buy a welder myself... |
#9042 | |
as well as, scrap the corbeau seat man, they dont sit low at all. driver position is usually wierd with bottom mounts
#9043 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
Didn't burn me, I extinguished that idiot pretty quickly. I thought I knew everything at 17 too, older guys kept me in check. He'll learn.
Timing? Vacuum Leaks? FSM procedure to check fault electronics?
#9044 | |
#9046 | ||
Everyone learns sooner or later.
#9049 | |
5' 10" you think i'll be brushing the roof on bumps? even if I decide to drop the $94 on the corbeau s13 bracket the fit is still bad? I'm just going to go start a thread for this |
#9050 |
Trader Rating: (58)
If you have a sunroof, it's going to be very close. If you ever wear a helmet it will certainly be in it.
#9052 |
![]() Join Date: Dec 2007
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
What can I do with the 5 transmissions in my storage that are no good. Can I get any $ for them anywhere?
I don't want to throw them away that's a lot of metal |
#9054 |
![]() Join Date: Feb 2006
Trader Rating: (22)
I'm trying to ID a disconnected plug in my engine bay. I have no access to an FSM (online or otherwise) at this time. It's an '89 coupe, originally automatic. There's a harness that runs past the ignition coil. It has three plugs on it. One goes to the AIV, one goes to the auto trans shift dampener thingy, but where does the third one go? I'm thinking it's for the IAT sensor that I ditched long ago, but I'm not certain. Any ideas?
MAF problem, perhaps?
-Kyle Last edited by soreballz; 01-01-2012 at 10:51 PM.. |
#9055 |
Trader Rating: (58)
Nope. The Profecs wiring simply controls the stepper motor, it has no clue what the boost really is in regard to an output
#9056 |
![]() Join Date: May 2006
![]() Feedback Score: 6 reviews
Curious about what kind of numbers i can expect tomorrow on the dyno from my new set up. I wanted a fun street car as its my DD here are my mods
built s13 sr20det cp pistons stock compression/bore manley rods BC valve springs/retainers stock cams for now gt2860rs .86 greddy intake manifold stock exhaust manifold z32 maf apexi power fc 740cc injectors i searched didnt find much on dyno sheets from the disco potato |
#9057 |
small question.
ok i got an oem cat. i took it off. now i have it back on but with a catback exhaust and it would only hookup one way. but to me the cat looks like its been reverse (not upsidedown) is it ok? i notice the EX on one end and forsure thats the exit. i hooked it up that way and the exhaust wont fit or hookup. so question is. is it ok if the cat is reverse? will it fuck up the flow. any input. |
#9058 |
![]() Join Date: Mar 2010
Location: Back IN FL, bring nice cars to the fail state!
![]() Feedback Score: 14 reviews
I can't find it anywhere....Is the s13 power steering reservoir steel or aluminum? Need to order some weld on fittings.
#9059 | |
#9060 |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
so i just bled my slave cylinder, 1st try it wouldnt go into any gears, then finally it disengaged, but when i step on the clutch pedal and put it in 1st then i feel something grinding, sometimes when i have the car running for a while it doesnt disengage. did i not bleed it right or is it something with my clutch and flywheel?
