#871 | |
![]() Join Date: Oct 2009
![]() Feedback Score: 11 reviews
#872 | |
![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
I'll let you guys know how it goes.
![]() ![]() Friends help you move. Real friends help you move bodies. |
#875 | ||
I'm using a grade 8 bolt there, which is quite near the type of shank he is providing in his current version of the tie rod ends in terms of tensile strength (IIRC his shanks are rated at 160ksi and the grade 8 bolt is rated at 150ksi), and also the bolt is a bit bigger around where it goes through the knuckle, as there is no taper. So really... the only way to find out is just to go on track and beat the shit out of these to see how they hold up. Quote:
Have you seen some of the stuff for the Mustangs and Corvettes? Talk about expensive... |
#877 | ||
The maximum stress occurs when the tie rod end hits the lower arm, that amount of torque about the pivot can be enormous when the car slams into full lock (when drifting), or when the car hits a bump/dip at full lock. |
#878 | |
![]() Join Date: Oct 2006
Unfortunately having a full time job, as well as doing chassis work on the side doesn't leave me with as much time as I'd like. I'm hoping to have everything ready by winter. As, everything will be getting track tested this year. I won't be doing the testing. Some with MUCh more experience then me will be doing the testing, lol |
#879 | |
![]() Join Date: Jul 2005
I know it will not do you any good with the spindles you have now, but switching to a 5/8" bolt...or the tapered shank I am using...you can run 3/4 to 5/8 misalignment spacers, which will give you more room before it binds. I have to put my misalignment spacers in before I can see if they'll bind (it doesn't look like it will), but aside from building some flat control arms I don't see how you could avoid the binding you're experiencing with your set up.
![]() Instagram - SJKnoop |
#880 | |
![]() Join Date: Nov 2005
Has anyone thought of chopping up some Z32 rears and moving the center hub part up? I know it would involve making a jig and adding some extra aluminum here and there, but it seems possible to me. You could make everything smooth afterwards and probably be just as strong as stock. I mean, have you seen all the stress raising edges and casting lines on those things?
#881 | |
![]() Join Date: Apr 2004
Honestly, the rear roll center isn't a huge deal unless you're really low. I think some RLCA are the most that need to be used to help move that up some beyond some bushings which bring the subframe up to the chassis of the car like SPL v2's.
#882 | |
#883 | |
Since I've used the Moonface roll center adjusters, the GP Sports hyper spindles, and now the DW front spindles without the rear spindles at the time, I would foresee the rears being needed. Having only the front modification vastly improves stability by eliminating much roll, which ultimately enhances driver confidence, but at a price. I noticed how quickly the fronts were loaded. At the limit the fronts would wash out, but upon corner exit the rear would slide out. Now following with the rear roll center adjustment, I felt the car held higher cornering G's and upon corner exit the car held very well as I was able to power out of the corner much harder. Having the fronts is great, but also having that important balance is priceless. If not now, I figure someone (DEF) will make one in the future. Just my thoughts.
.25 till 3 |
#884 | |
If you're going to go another inch lower or so(don't see how you can realistically go much lower and still have your car handle worth a crap), then some RLCA can help correct the roll center some. Maybe rear uprights have some benefit, but the problem isn't NEAR as big as the front, as the roll center probably drops at about half the rate when lowering the car(rear vs. front). The rear is a bit more complex as well, as I don't buy just making things "stock but raised up some" is the right way to do it. It'd probably be more extensive machining, so more expensive than a set of fronts as well... I do think some RLCA might be an option in the future. Just not thinking it's a big deal for our cars.
#885 | |
#886 | |
#888 |
What does it matter what everybody else is.
What are your credentials if you're going to come in here and start shit? ![]() I'm guessing you're just another hard parker based on your tone, but I'd love to be proven wrong. So what can you bring to the discussion?
#889 |
Oh yeah, I haven't seen him post around here in forever. Someone who knows where he is should link him in.
#890 |
My crystal ball says waiting is a good idea if you want to correct your front geometry to any large extent.
#891 | |
The problem with is you've likely just created additional stress points. And should the weld not be clean or there is a fault in the weld. It would almost split right down the centre. It would probably be a better idea to use a set of iron knuckles if you wanted to do that. |
#892 | ||
And honestly, if I had known all this to begin with, I probably would have just bought your tie rod ends to begin with and not worried about making my own for the extra spacing, since my goal of 2" could have been done without spending the extra money I did spend on making these and now am going through the headaches of making it all work. Quote:
At the top, it's just the 1.25" DOM tubing on top of the bearing, then the machined down GS spacer, which is machined down to .75" or so, for a total of 2" of spacing. When the spacer binds onto the bearing cup, the shims on the bottom also bottom out on the C-Clip, so basically, it binds top and bottom. Now, again, I haven't tightened everything down, so for all I know, there might be a chance that the bearing would rotate within the cup itself when everything is tightened down, giving me that extra little bit of rotation, although it is unlikely. Last night was a bit busy so I didn't get to work on the car (had a BBQ w/ the wife instead, after modifying my grill for more airflow so the charcoal don't die out after like 5 minutes of lighting it initially lol), but tonight should be a little better for me, time wise. Just got the shims from McMaster yesterday, so I'll be able to play with the spacing some more on these arms. |
#893 |
![]() Join Date: Jan 2005
Trader Rating: (29)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 29 reviews
I am sure somthing awesome will be comming our way! Ok I am not sure this has been covered, so forgive my question if it has.
Why are the spindle and the ball joint mount not perpendicular to one another like they are in the MSI upright? I know we are comparing Nissan to Subaru, but it seems that when we start lowering the cars the angle becomes more apparent. I guess it is the kingpin inclination angle (KIA) that I am refering to. I do understand that we need some for high speed stability, but I have never seen it addressed by any aftermarket companies with either arms, knuckles or both. Maybe it is way too complex to start monkeying around with. |
#894 |
Which upright/ball joint mount are you referring to Jonnie?
#895 |
Trader Rating: (29)
If you look at the pics of the Subaru /MSI upright the lower ball joint seems to be perpendicular to spindle. On the other hand the S chassis uprights the spindle is not perpendicular to ball joint or am I mistaken?
#896 |
On the S-Chassis, at least with the stock lower arm and stock knuckles (spindles, uprights, etc., whatever you wanna call it
![]() It's just that on the S-chassis knuckles, the section where the ball joint mounts to the knuckle is on an angle to accommodate for the ball joint, which is mounted on the angled part of the lower arm. Did I answer your question or did I still miss something? |
#898 |
You're gonna have to ask Nissan that.
But I'm guessing it has to do with the huge KPI angle that Nissan was going for, which really hampers things when you start lowering the car and the such. |
#899 |
Trader Rating: (29)
Exactly! I am wondering first why the massive KIA? What is the benifit? and Why if we are inclined to lower our cars that the aftermarket has not gone with a lower KIA through adjusted knuckles and lower control arms?
#900 |
I think the high KPI angle and the caster help to give the negative camber when the wheel is turned in, and positive camber when the wheel is turned out.
Other than that, I can't really think of a reason why there would be such a high KPI angle. |
