Old 01-15-2007, 11:42 AM   #61
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
OK... for some odd reason I have actually had people asking if the SR20Down pipe will fit the NA KA24DE!! I guess because its similar in design!!
The answer is NO... unless you have a KA-T w/ custom Turbo Ellbow.
I actuall went out and installed an RS*R DP, SARD Tourqu Control Valve, and Full Kakimoto Exhaust on my S14... the 3 bolts off the Main will line up and bolt corectly... the issue was with the slight angle difference, and the mounting plate from the DP to the Trany. The mount can be cut off but it doesn't change the angle.
After you install the cat or test pie you will see its sitting much closer to the ground... if you get as far back as the Rear subframe you will be about a foot lower and never make it to the mounts.
This was actually fun to play with the idea... car looked so dumb sitting with the rear end about 2 feet off the ground and a full exhaust sitting on the ground. I couldn't force myself to shame my car with pictures.
SR Down Pipes are for SR20s or CA18s only... maybe a KA-T!!
Peace
Drew
Follow on IG - KoukiTheToolBox
MadScientist is offline   Reply With Quote
Old 01-15-2007, 08:03 PM   #62
nissandr1ft
nissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura about
Send a message via AIM to nissandr1ft
Im running an 3" SR downpipe on my S13 KA... just have to use an S14 exhaust mani.
www.carolinanissans.com
nissandr1ft is offline   Reply With Quote
Old 01-26-2007, 01:14 PM   #63
sil80forme
sil80forme's Avatar
sil80forme can only hope to improve
Send a message via AIM to sil80forme
i will have to second that!!!! u can use a s14 exhaust mani on a s13 and will bolt to a sr downpipe. ftw
sil80forme is offline   Reply With Quote
Old 01-26-2007, 01:40 PM   #64
MadScientist
OK so that is confirmed as possable... But It dosn't work on the S14, seems odd!?!
Peace
Drew
Old 01-26-2007, 02:16 PM   #65
ms!3
so question about stand alones. do you need one for itbs or could you get away with a piggy back? my guess would be no cuz i dont think you can get rid of the maf with just a piggy back but just askin to make sure. might make things eaiser down the road.
ms!3 is offline   Reply With Quote
Old 01-26-2007, 02:24 PM   #66
sil80forme
sil80forme's Avatar
Peace
Drew
huh!!! are u positve it doesnt work on an s14? cause i would say if it worked on a s13 that it would also work on the s14.. wow thas wierd
Old 01-26-2007, 02:27 PM   #67
sil80forme
sil80forme's Avatar
u are correct, in order to use a piggyback the maf has to be present.. but u also dont have to have a standalone for itbs. u can have a plenum made and still use the stock maf but if u want open itb's then be willin to pay out the big bucks for a standalone
Old 01-26-2007, 05:04 PM   #68
ms!3
meh alright, i figured id ask, megasquirt here i come.
Old 02-06-2007, 12:55 PM   #69
Blackhat
Blackhat is an unknown quantity at this point
You don't have to use a VR sensor with the MSEFI like the install I saw posted earlier. Just use the stock Opto CAS and use the falling side of the signal. Of course, if you're really paranoid about timing and plan on going with a MS2 I hear you can run both a 12-1 wheel off the crank and the opto off the Cam. Again, that's if you're paranoid about chain slack or maybe want to attempt Sequential Injection. Or if you don't want to play with the Opto you can do VR, nothing wrong with either install.
MSEFI ftw!
Blackhat is offline   Reply With Quote
Old 02-12-2007, 01:26 PM   #70
Iceman00
Iceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymoreIceman00 is not welcome here anymore
I'm pretty Sure the title Reads N/A KA. Lets keep it on topic
Iceman00 is offline   Reply With Quote
Old 02-12-2007, 02:30 PM   #71
ms!3
how is talking about ms going off topic?
Old 02-12-2007, 04:20 PM   #72
Iceman00
48, 49, 52, and post 59.
Old 02-12-2007, 06:01 PM   #73
ms!3
merr.... i can see what your talking about with the supercharger thing. didnt see that , haha. but back on topic anybody have any info on the sohc piston swap. i heard about it alot but never seen anybody actually do it. id like to do it in the future, have grooves made for em so the valves dont hit with bigger cams. i dunno mabey have em polished to help reduce carbon buildup. werd is that they bump compression from 9.5:1 to 11:1 and with high comp rings that just might up the comp up a little. seems like a pretty cool thing to do to dohc's, just never seen it done. but then again you barely see "built" n/a ka's. lol
Old 02-12-2007, 10:52 PM   #74
Iceman00
Cam it. And don't do the bullshit 248/232 swap with factory cams. JWT or go home.
Old 02-13-2007, 10:35 AM   #75
Iceman00
Some one did this on Altimas.net, and the result could have been better if he used quality parts.
He has to run super retarded ignition timing, and in a foolish move, bought the pistons on ebay.
With out a tune, it ran rough, it pinged, and who knows what else. He says he might try it out again.
Old 02-13-2007, 02:12 PM   #76
ms!3
248/248 is a pretty cool setup starting off. ive never seen 248/232, all s14 guys ive seen swap the cams put 2 s13 exhuast cams in and not leave the stock exhaust 232. jwt are like 270 duration right? anything bigger? if seen a lot of corolla guys with like a 300 duration cam. i wonder how that would idle? lol
Old 02-13-2007, 03:37 PM   #77
Iceman00
using 248/248 is said to push the powerband too far up, are you sure you didn't mean 248/240?
PDM,and Crower make cams for the KA24DE as well, But I don't think anything (i've seen at least) tops JWT's 275/275. And there was no low end loss.
* > Drifting
JWT powered Altima
Old 02-13-2007, 05:57 PM   #78
ms!3
well ive got an s13 and suposedly the exhaust is 248 duration and the intake is 240, swaped another s13 exhaust cam inplace of the intake cam, retarded the timing 3 teeth. 248/248
Old 02-17-2007, 02:12 PM   #79
Iceman00
There is now a thread on this, check it out.
* > Drifting
JWT powered Altima
Old 02-27-2007, 05:48 PM   #80
shinrekka
shinrekka's Avatar
shinrekka is an unknown quantity at this point
Anyone running the nismo R4 cam on their SOHC?
shinrekka is offline   Reply With Quote
Old 03-14-2007, 02:49 AM   #81
SLEEPERracer
SLEEPERracer is an unknown quantity at this point
im thinking about picking up this 97 dohc motor just cause it has hella less miles then mine does now and build an N/A setup. my 93 motor is pretty much the same so the trans would be able to fit and wiring harness and such rite? the 97 motor isnt gonna come with a wiring harness thats why im asking. i can run the same ecu and everything??
would it even make sense to upgrade fuel pumps and such and to tune it for power??
for now i was just thinking about running i/h/e and jwt cams? think this would be a streetable setup??
SLEEPERracer is offline   Reply With Quote
Old 03-14-2007, 10:57 AM   #82
sav180
sav180's Avatar
sav180 has made poor choicessav180 has made poor choicessav180 has made poor choicessav180 has made poor choicessav180 has made poor choicessav180 has made poor choices
crower makes good cams
Engine/Model: KA24DE 16-VALVE DOHC 1991-99
Description Gross Lift Duration* Unit Needs Kit Part # Price
STAGE 1 - N/A PERFORMANCE STREET: Aggressive street use & n2o. RPM range: Idle-6250+. Needs spring kit w/ higher RPM. .363"/.363" .256°/.256° SET/2 STOCK CR-61351-2 $426.15
STAGE 2 - FORCED INDUCTION STREET/STRIP: Designed specifically for turbo/blower. Short duration, low overlap, & high lift. RPM range: 1000-6750+. Needs spring kit. .375"/.375" .264°/.264° SET/2 CR-84184 CR-61351T-2 $426.15
STAGE 3 - N/A 3/4 RACE: Designed for Street/Strip. Most popular profile. RPM range: 1500-7000+. Needs spring kit. .406"/.406" .272°/.272° SET/2 CR-84184 CR-61352-2 $426.15
STAGE 3 - FORCED INDUCTION RACE: Drag race & radical Street/Strip. RPM range: 1500-7000+. Needs ECU mods & spring kit. .401"/.401" .280°/.280° SET/2 CR-84184 CR-61353-2 $426.15
STAGE 3 - N/A FULL RACE: Drag race & radical Street/Strip. Rough idle. RPM range: 1500-7250+. Needs spring kit. ECU tuning manditory. .411"/.411" .288°/.288° SET/2 CR-84184 CR-61354-2 $426.15
sav180 is offline   Reply With Quote
Old 03-14-2007, 10:58 AM   #83
sav180
sav180's Avatar
KA
http://atomicspeedware.com/camcrownis.htm thats who sells them
Old 03-14-2007, 11:00 AM   #84
sav180
sav180's Avatar
im gettin my block done now .runnnin je 11.0.1 pistons,eagle rods..jus got to get head work,itb's and a standalone.gotta prove the haters wrong
Old 03-19-2007, 09:33 PM   #85
Ameer
Ameer is making a name for him/her selfAmeer is making a name for him/her self
Question is, will an N/A KA 240sx ever hit a 10 second quarter mile?
Ameer is offline   Reply With Quote
Old 03-19-2007, 09:36 PM   #86
Ameer
I believe that it might 11.9 if you try your hardest. But I highly doubt 10.9 or better.
Old 04-27-2007, 12:56 AM   #87
SpdElemts
SpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of light
Hey guys i have a very quick question and i know it has been asked before so im not gonna post a new thread to talk about it....Is there any difference between a 92 KA block to a 96 KA Block (sensors and what not as in obdI to obdII)? I know the 98s are different cuz i understand they changed something related to the timing chain. Reason i ask is because i have a spare 92 KA engine in the garage and i want to rebuild it for my 96 s14 and just use the s14 head and sensors.
-Jeff Wolfson
SpdElemts is offline   Reply With Quote
Old 05-18-2007, 10:33 PM   #88
Iceman00
Just Had My KA Dynoed
Intake
Header
Ecu
Pulley
Stock cams and Exhaust
138hp/155q
I'm going to put back in my Jwt cams, and run again.
I'm also looking at running advanced ignition timing up to 23 degrees, coolant bypass, Iridum plugs to keep the temps down from the increased timing. anything else you guys can recommend?
Oh yeah, its Auto.
* > Drifting
JWT powered Altima
Old 05-28-2007, 11:45 PM   #89
sideview_180sx
sideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to beholdsideview_180sx is a splendid one to behold
Send a message via AIM to sideview_180sx Send a message via Yahoo to sideview_180sx
since you have more drivetrain loss due to auto I would be wondering how much more you would put down with 3-inch exhaust, and crower drop-ins. I'm looking if anyone else offers a sohc cam beside the R4 and R5 offered through nissan motorsports and the ones thru PDM.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!!
formerly sideviewcivic
Save a Horse. Drift This Cowboy.
AirBag Club Member #0014
sideview_180sx is offline   Reply With Quote
Old 05-29-2007, 10:07 PM   #90
shinrekka
shinrekka's Avatar
wow all these people on this board and no one is running an R4 cam.
