Old 12-02-2016, 11:28 AM   #61
travon47
travon47 is an unknown quantity at this point
Here is another pic showing where it sits. Its right at the tall section on the side before the shifter extension
http://www.soarerworld.com/forum/att...8&d=1358163820
travon47 is offline   Reply With Quote
Old 12-05-2016, 12:02 AM   #62
insa
insa is an unknown quantity at this point
Originally Posted by travon47 View Post
Makes sense because its an add on to the trans. I am not sure if they would fit with a custom trans mount in a s chassis( I took mine off before installing into car) but if I can find mine I could send them to whom ever if they pay shipping
Thanks for the input! Never heard of or seen these either
Originally Posted by gaz_moose View Post
if your going to pull the thing to pieces then maybe have a look at your spigot bearing in the back of the crankshaft as if the adapter plate sits the box out of line ever so slightly it can wear the spigot causing the input shaft to wiggle around.
Thanks, will be replacing this.
insa is offline   Reply With Quote
Old 12-07-2016, 11:06 AM   #63
canadians14sr20det
canadians14sr20det is just really nicecanadians14sr20det is just really nicecanadians14sr20det is just really nicecanadians14sr20det is just really nicecanadians14sr20det is just really nicecanadians14sr20det is just really nicecanadians14sr20det is just really nicecanadians14sr20det is just really nicecanadians14sr20det is just really nice
I totally took off that dynamic dampener (as nissan calls it) and built my own cross member. I'm going to track down an OEM crossmember, mount, damper bolt and dynamic dampener and see if this calms down the vibration.
On top of this, I'm doing a Mazworx bellhousing as well as an ATI super damper. This motor better be smooth as all hell after all of this... If it isn't, something internal is broken or way out of balance.
canadians14sr20det is offline   Reply With Quote
Old 04-13-2017, 10:55 AM   #64
canadians14sr20det
So I've been tackling this issue in a more scientific manner lately lol. One thing at a time so I can rule out causes. Hopefully it helps someone else on here. I get a surprising number of PM's about this.
Anyways, I built a mount using the OEM 350z transmission mount. It made the vibration WORSE. So far using the 240sx transmission mount seems to be better. I didn't check if the 350z mount is harder or softer than the 240sx mount. I'll test that out tonight.
After this the next thing to try is the damper on the side of the transmission.
Old 04-13-2017, 02:07 PM   #65
fatduece
fatduece is an unknown quantity at this point
Weird! Keep updating this. Makes me nervous about mine.
fatduece is offline   Reply With Quote
Old 04-14-2017, 12:05 PM   #66
Kingtal0n
Kingtal0n's Avatar
make sure the engine exhaust system does not contact the chassis in any point. If you use a hanger for the exhaust to drivetrain, tie it to the trans crossmember like a factory mount (use the same sort of bushing the OEM uses).
I think you are having two issues. One is the mounting/vibration/noise related to the way the trans and exhaust system is mounted.
The other, resonance/vibration at specific RPM under load sounds like a pinion angle issue. The trans tail shaft and differential input flange need to be at identical angles (equal and opposite), with the trans higher than the differential so the driveshaft has a downward slope.
Old 04-14-2017, 07:09 PM   #67
TheRealSy90
TheRealSy90's Avatar
With the pbm max downpipe and s13 trans mount you can retain the factory hanger between the downpipe and trans mount with cd009.
Such a good signature.
Old 04-15-2017, 10:48 AM   #68
canadians14sr20det
So I have run the car without exhaust, ensuring nothing is touching in any way. Vibration is still present.
Also the vibration is present with the car in gear and clutch in. The pinion angle was measured and set correctly. Its also not speed sensitive. I'm positive it's not driveshaft related.
There is another thread about this on here where the op mentioned it may be caused by worn input shaft bearings allowing some slop. Thats gonna get replaced when/if I do a mazworx vq->Sr bell housing. Next up is the damper on the side of the tranny and then the ATI super damper. Transmission rebuild and new bellhousing is the last resort.
Old 04-15-2017, 08:30 PM   #69
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
I'm not of any help to your current issue, but when it comes time to buy that adapter shoot me an email and I'll cut you a deal on it!
[email protected]
hanzbrady is offline   Reply With Quote
Old 06-07-2017, 10:59 PM   #70
canadians14sr20det
Update: Did an ATI super damper, hoping to smooth things out a bit more. Motor is smooth as butter at idle now, still horrific under load.
There's a thread on here where someone else had a similar issue, and came to the conclusion the input shaft bearings on these trans are shit. I think that can be agreed on now.
Solution (I think) is to replace the input shaft bearing and do the mazworx bellhousing. If this doesn't fix it I guess time for a hollinger
Old 06-08-2017, 06:02 AM   #71
hanzbrady
hanzbrady's Avatar
Well, if that the case, they're currently 10% off!
[email protected]
Old 12-07-2017, 02:16 PM   #72
konjiki7
konjiki7 is an unknown quantity at this point
Any updates? Did mounting harmonic bits on the trans help?
konjiki7 is offline   Reply With Quote
Old 12-08-2017, 01:42 PM   #73
canadians14sr20det
Not much of an update yet. I drove it the rest of the summer with the vibration present. It survived a bunch of track events and some street abuse just fine. So I'd say the vibrations this trans puts out are not detrimental to longevity.
However I haven't tried the OEM nissan vibration dampers. ATI super damper and different mounts all did absolutely nothing. If you have this vibration I'd say it's likely internal.
I have purchased the Mazworx bellhousing kit as well as new input shaft bearings. I will be doing this over the winter, then will report back here in the spring!
Old 12-08-2017, 02:53 PM   #74
Sailor
Sailor is a well-known jackass
Hate getting those underlying issues, you've done a swell job of sorting out the bs and doing some research +1 for that. Hope this is the final fix
Sailor is offline   Reply With Quote
Old 10-22-2018, 01:53 PM   #75
canadians14sr20det
Update: I installed the new bearings and mazworx bellhousing. Vibration still present.
However the vibration doesn't seem to be a "problem". I said fuck it, drove it all summer, hit a few drift events, and the transmission hasn't had any issues. Shifts nicely. Just sounds like the car is coming apart at 4000RPM plus.
I'll be buying a new OEM Z33 trans over the winter and installing that. If that doesn't fix it I guess I'll just live with it.
Old 10-25-2018, 02:37 AM   #76
gaz_moose
gaz_moose is an unknown quantity at this point
I cant be bothered to go back and read the whole thread, but could it be the propshaft out of balance?
jack the car up so its arse is right in the air and take the prop off and 'drive' it.
gaz_moose is offline   Reply With Quote
Old 11-07-2018, 01:06 PM   #77
Kintaro_Oe
Kintaro_Oe is an unknown quantity at this point
I had this same issue after installing my mazworx bellhousing with the driveshaft they provided. Ended up being the universal joint not being lubricated properly.
When I was holding the driveshaft (off the car), i grabbed the u-joint and would move it around and noticed a few dead spots where it wasn't smooth and sort of catching a bit. I had Drivelines NW replace the U-Joint and voila, vibration gone.
IG: Touge.Tough
Kintaro_Oe is offline   Reply With Quote
Old 04-20-2019, 11:15 PM   #78
canadians14sr20det
So to close up this thread. Ended up buying a brand new from Nissan cd00a trans. Vibration and noise is still present. These transmissions are just insanely noisey. The chassis vibration is just a factor of my motor and trans configuration. I'm going to live with it till something lets go.
Old 01-06-2021, 01:11 PM   #79
canadians14sr20det
Solved! (Mostly)
So I'm bringing this back from the dead. I never got over this vibration. With the latest Covid lockdown up here I've had some time on my hands so I went full science on this. This is gonna be a long one.
I went and setup a Raspberry Pi and hooked up two accelerometers to it via an ADCDAC expansion board. Parts I used were:
RaspberryPi: https://www.raspberrypi.org/products...-pi-4-model-b/
ADCDAC board: https://www.abelectronics.co.uk/p/74...xpansion-board
Accelerometers: https://www.digikey.ca/short/4c5fwj
I then wrote some code to record the vibrations from each sensor:
https://github.com/linds14sr20det/race_car_avc
For the setup to measure this vibration I attached one accelerometer to the transmission (unused bolt hole near the shifter bracket) and the other sensor to the transmission crossmember. My trans crossmember setup uses the 370z mount as it's fluid filled and _should_ dampen vibrations better than any of the other mount solutions, or at least that's what I thought.
Here's the first graph of engine vibration (blue) vs. chassis vibration (red). This is a recording of me revving the engine slowly from idle to 4500rpm. As you can see engine vibration increases as the rev's rise with not a lot of chassis vibration until you hit 4000rpm when chassis vibrations exponentially increase and are now stronger than the engine's vibration. This is a clear resonance in the chassis. The force the chassis is experiencing here is about 4g's. Considering the trans mount supports over 100 lbs, this is actually a pretty significant force. I wouldn't be surprised if over time this cracked the crossmember or the chassis spot welds.
If you zoom in on the graph you can also see that the vibration occurs at ~150Hz. This works out to the equivalent of 9000rpm (150 cycles/second * 60 seconds/minute), which actually makes sense. 4 cylinder engines are inherently unbalanced with a pronounced second order vibration (vibration at twice engine speed). So this supports a resonance at 4500rpm. Also explains why these trans don't have this problem behind a VQ35 or an inline 6.
Okay so the next step was to confirm the crossmember is the vibration transfer path. This is easy to do, support the trans on a floor jack, remove the transmission mount, and bolt everything back up. Since the transmission is no longer connected to the crossmember, we would expect to see little chassis vibration if the trans mount is the culprit. If it isn't the source of the vibration we should see no change.
Pretty dramatic decrease. So we know it's the trans mount causing the problem.
There are 3 ways to reduce vibration transfer from all the reading I've now done.
1. Stiffen the receiver (ie. thicker floorpans and a roll cage. This is a street car so nope. Also explains why s-chassis with cages aren't as bad for this vibration)
2. Reduce vibration at the source (Increase the mass of the transmission, add a dual mass flywheel, change the gear mesh patterns, swap to an inline 6, etc. Not gonna do those either.)
3. Soften the engine mount. Vibration elimination has two parts, isolation and damping. Damping increases vibration transmission to the receiver but reduces the peak amplitude. We want to isolate the vibration and to do this we need to soften the engine mount.
To test this theory, I went and grabbed two valve springs from a vq35de. Since a 4 cylinder second order vibration is only in the vertical direction a spring is a perfect candidate for the mount isolation. This is also how jaguar used to mount it's transmission back in the 70's and 80's so this isn't as hair brained as it seems. Anyways, the VQ35 springs were soft enough they support the weight of the cd009 but compress about an inch each. So I'd ballpark them at a spring rate of 75 lbs/inch. Here's the graph:
We have a winner. Chassis vibration is way reduced and you actually can't feel the buzz or hear the floor resonating anymore. So I'm going to build out a more permanent version of the spring trans mount and report back on it.
Old 01-06-2021, 11:22 PM   #80
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
Wow. What an incredible journey
Your diag process and documentation should be applauded
lok is offline   Reply With Quote
Old 01-07-2021, 02:55 AM   #81
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
You seriously scienced the shit out of this. Huge kudos to you, good sir.
Sent from my Note 20 Ultra using Tapatalk
mr.nismo. is offline   Reply With Quote
Old 01-07-2021, 03:47 PM   #82
mrmephistopheles
mrmephistopheles's Avatar
Thread stickied. Excellent work OP.
Originally Posted by PHLIP
Old 01-07-2021, 04:15 PM   #83
slider2828
slider2828's Avatar
Dude this is legit AF..... I knew CD009s were noisey but this is insane. But this leads to think its something internal to the tranny?
Is the vibration the same if you remove the driveshaft? I've read about driveshaft pinion angles and stuff?
What are your thoughts?
Maybe change fluids I know this helped for me moving from shockproof to amsoil. But not sure how significant is your vibrations.
Turn and Burn!
Old 01-08-2021, 08:04 AM   #84
TheRealSy90
With a sprung transmission mount isn't the driveshaft angle going to be variable while driving the car and over bumps etc? That seems like it might introduce some weird vibrations.
Kudos to you for actually finding the source though. Interesting that the characteristics of the I4 engine introduce this vibration to the transmission that doesn't happen with the V6.
Old 01-08-2021, 08:35 AM   #85
Antihero983
Antihero983's Avatar
This is absolutely fantastic. Well done OP!!
Old 01-08-2021, 09:48 AM   #86
canadians14sr20det
So I tested this with the driveshaft disconnected, no change at all. It is entirely related to the mass of the transmission and the way the trans case carries the vibration to the chassis. Weight of oil will help gear chatter related to switching to a single mass flywheel, but won't change the fact this trans does this in neutral as well. Resonance is a function of the natural frequency and mass of the object, in this case there isn't much you can do to the trans to change it.
Old 01-08-2021, 09:51 AM   #87
canadians14sr20det
You're totally right, springs alone would do some wacky things for driveline angle. When I finish designing my trans mount I'll be posting it here. I think the key is to have the springs "hover" the transmission just above and below bump stops. So any large bump has the trans hit a rubber bump stop that limits the change in angle. That being said if you were to watch how much a stock mount moves it's easily half an inch if not a full inch.
Old 01-08-2021, 05:13 PM   #88
97kouki1J
97kouki1J is an unknown quantity at this point
Thank you so much for your commitment.
You are a hero
97kouki1J is offline   Reply With Quote
Old 01-08-2021, 07:43 PM   #89
TheRealSy90
I may be interested in buying one of these mounts from you.
Old 01-08-2021, 08:09 PM   #90
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Same if I have issues with my setup as well. I'm using the gk mount so we'll see
