Old 04-19-2011, 10:01 PM   #61
'97 S14 SE Turbo
'97 S14 SE Turbo is an unknown quantity at this point
Send a message via AIM to '97 S14 SE Turbo
sparkplug gap? Make sure your ignition system is strong enough.
'97 S14 SE Turbo is offline   Reply With Quote
Old 04-20-2011, 11:08 PM   #62
ship2236
ship2236's Avatar
Trader Rating: (18)
ship2236 is making a name for him/her selfship2236 is making a name for him/her self
Feedback Score: 18 reviews
Send a message via AIM to ship2236
Gap is @ 28. Thought it could be the cps( crank pos sensor) but seeing as i have a s13 trans there's no sensor or place for it on the bellhousing.
ship2236 is offline   Reply With Quote
Old 04-21-2011, 02:20 AM   #63
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
Didn't only obd2 use that sensor?
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 04-21-2011, 09:19 PM   #64
ship2236
ship2236's Avatar
Trader Rating: (18)
Yea i didn't even think of that at the time lol. Anyways i just pulled the knock sensor...
It's cracked all the way through. It's a pain I'n the ass so ima have to install the new one tomorrow when i have better light and can make more room to get In there. Hopefully this fixes my issue......
Old 04-21-2011, 11:04 PM   #65
Redmonkey
Redmonkey is an unknown quantity at this point
Have fun digging through the manifold lol. It's easy taking it out but a PITA to get it back in.
Redmonkey is offline   Reply With Quote
Old 04-21-2011, 11:25 PM   #66
Pro ViZIon
Pro ViZIon's Avatar
If your manifold is stripped down like mine then it shouldn't be too bad. I can get my arm under it from the back side.
Old 04-21-2011, 11:59 PM   #67
ship2236
ship2236's Avatar
Trader Rating: (18)
My mani is semi bare, but my arms are to big to fit through the bckside all the way lol. I am a good 3" away from the hole and tried to use a hanger to position it and a lOng skinny extension to get it it but i just couldn't get it. Gotta get one of my asian friends to come over n ninja that shit for me
Old 04-22-2011, 01:02 AM   #68
Pro ViZIon
Pro ViZIon's Avatar
Haha. Ninjas.....oh but there's a write up somehwere for this. Just google it. I know that he used as wobble extension to get the socket on it.
Old 04-23-2011, 02:48 PM   #69
ship2236
ship2236's Avatar
Trader Rating: (18)
Knock sensor changed nothing so I'm going to have to hit up a junkyard n let them take me for all it's worth on a whole new harness, distributor and ecu and if that doesn't fix the problem I'll send out the invites to the Bon fire hosted by my 240
Old 04-25-2011, 01:25 AM   #70
Pro ViZIon
Pro ViZIon's Avatar
Good luck man. I really hope that it works for you.
Old 04-25-2011, 01:01 PM   #71
Corey121
Corey121 is an unknown quantity at this point
Mine ran great when i first started my ka-t then it started running like crap, i ripped the lower orings on the injecters i replaced them three times, and finally i got them in right, i wasnt pushing the injecters in i was setting them in and tightening them up, then i had a massive boost leak so the car would die, i ran my intercooler pipping and fixed my problem, then when i was getting into boost it was breaking up and spitting and spuddering i gapped the plugs to .30.
I see your gap should be fine, if your smelling alot of fuel then maybe the orings are toast. (I skimmed through the post so i might have missed something) Did you check your timing? I didnt have to adjust mine i got an enthaply tune.
Corey121 is offline   Reply With Quote
Old 04-27-2011, 04:33 AM   #72
boosted KA24DE
boosted KA24DE's Avatar
Trader Rating: (22)
boosted KA24DE is an unknown quantity at this point
Feedback Score: 22 reviews
I had problems like you are mentioning through out your thread and yes I too had boost leaks but what made my setup even better was upgrading the ignition to a new 6A digital by MSD. It purrs like a kitten now running 1000cc injectors.
JDM Fashion isn't always good!
boosted KA24DE is offline   Reply With Quote
Old 04-28-2011, 12:34 AM   #73
ship2236
ship2236's Avatar
Trader Rating: (18)
^^^ yea i think bigger injectors and a 6a will be next if it gets up n running. Sorry to not post for a few days. So i ripped out the s14 ecu and harness. Got a great deal from a friend on a s13 man ecu and full harness. Waiting on another guy to come through with a s13 dizzy n coil wich i have a new cap n rotor n wires waiting. I trew I'n another set of plugs. Gonna run them at 28 still. And lastly i gotta take this ecu to a comp or tv repair place n see if they can solder this emance daughterboard I'n for me. Then I'm gonna trash that damn safcII!
Old 04-28-2011, 01:27 AM   #74
AZRB20
AZRB20's Avatar
AZRB20 is an unknown quantity at this point
This sounds like definitely a fuel issue.. how are you monitoring your AFR? My old SRT4 did this issue when my Greddy e manage would lose control of fuel. It pretty much run like shit from flooding the cylinders and cause the car to misfire. Also could be maybe TPS sensor..
AZRB20 is offline   Reply With Quote
Old 04-28-2011, 10:56 AM   #75
ship2236
ship2236's Avatar
Trader Rating: (18)
I re-clocked and tested tge old tps n it was fine but i had a new one i put on anyways n it made no difference. At the moment i can't monitor the afr's because i paid for an innovative wideband from a member on another forum I'm not gonna disclose, and never recieve it.
Old 04-28-2011, 11:31 AM   #76
Pro ViZIon
Pro ViZIon's Avatar
Dude you have bad luck like me lol. I bought a distributor from a member on here and he sent me one for an s14 when I was asking for an s13 one. He hasn't gotten back to me.
I'm not sure if this would do anything but does the iacv piping need to be routed pre-turbo. It just seems weird to place it in the intercoooler piping since it would be receiving pressurized air.
Old 05-03-2011, 12:21 PM   #77
ship2236
ship2236's Avatar
Trader Rating: (18)
So everything is I'n the car at this point. Got my emance daughterboard soldered I'n the ecu. Only issue right now keeping me from starting it is the guy i got tge s13 dizzy didn't give me the base that spaces tge cap so I'm off to a junkyard to dwell around. Wish me luck lol
Old 05-03-2011, 01:36 PM   #78
Pro ViZIon
Pro ViZIon's Avatar
I was wondering what was going on. good luck. You talking about the black plastic piece thats under the rotor? if you dont find one i have one.
Old 05-03-2011, 05:25 PM   #79
ship2236
ship2236's Avatar
Trader Rating: (18)
Yea i found one. Nowwwwwww..... Lol the problem is...... I have no spark haha. Everything is grounded, tried 2 diff dizzies from 2 diff running cars, 2 diff coils and nothin haha. Fml.
Old 05-04-2011, 12:26 AM   #80
Pro ViZIon
Pro ViZIon's Avatar
Well the good news is i got my car running. Im not sure how well though. didnt get to drive it. Turns out my front main seal is leaking hella bad. so now im in the middle of replacing that. Have you swapped ecu's? i dont remember. no spark could really only be from the dizzy not being hooked up or the coil not being hooked up correctly. ive never seen that.
Old 05-04-2011, 10:17 AM   #81
ship2236
ship2236's Avatar
Trader Rating: (18)
Yea swapped to the s13 ecu with the rom tune. All the connectors seem tp be I'n good shape on the dizzy and coil. Plus i tried other ones from my buddies running car. I have the day off so i need to figure this out
Old 05-05-2011, 06:52 PM   #82
ship2236
ship2236's Avatar
Trader Rating: (18)
So today for some reason the car wouldn't produce a spark or crank for that matter. Then the ecu started to smoke! The stereo wouldn't work and i got mad as hell. Seriously i walked away from tge car and left it for about to hours... Walked back out to the garage, stood I'n front of this mother fuc*** and said if u don't start I'm parting ur ass and burning tge shell I'n the desert! I sat I'n it n turned the key.... The bitch started right up, i took it for a ride down the street and... Tge same exact issue is present wich i started this thread about even with all the s13 components lol. FMFL!
Old 05-05-2011, 11:22 PM   #83
Pro ViZIon
Pro ViZIon's Avatar
At least your out of that sub-rut lol. I was going through troubles today too haha.
But i really dont know what to tell you about that shit. Have you asked on KA-T.org?
Old 05-06-2011, 01:49 AM   #84
rps13dn
rps13dn's Avatar
rps13dn is an unknown quantity at this point
i can fix it but ur to far dont know if u want to drive that far
rps13dn is offline   Reply With Quote
Old 05-06-2011, 08:27 AM   #85
ship2236
ship2236's Avatar
Trader Rating: (18)
How an u fix it?
Old 05-07-2011, 12:16 AM   #86
ship2236
ship2236's Avatar
Trader Rating: (18)
Is there something u see I'n this thread that i don't? Just asking because if ur serious, I've exhausted my efforts at this point n would work out a deal to get it back on the road. Only thing is if uve read, the car is obviously undriveable, especially to la lol.
