#61 | |
![]() Join Date: Oct 2013
A lot of good points and conversation in this thread. And nobody is mad...at eachother....yet (afterall, its zilvia.) That being said. In my opinion for my application and how I street my car, I think apples to apples, if my car was a "blank" canvas again, I'd likely go with the k-swap over my KA. I love my KA and have no plans to switch power plants, but it's hard to say I don't have an expensive KA, and i think spending X amount on my KA set up, to spend a little more on a functional K24 set up with more potential in areas I like, wouldn't bother me. For someone who wants a 300whp car, I don't think this is the swap for them unless they want to have something slightly less popular than an SR or a KA-T. However, with these kits coming out, you know other manufacturers will jump on the band wagon (lets take bets on how long it takes for ISR to develop a swap kit) within the next 5 years, I almost imagine these will be the next super common swap. 5 years ago there wasn't that many JZ powered S-chassis, now EVERYONE is doing it. |
#62 | |
![]() Join Date: Sep 2012
![]() Sent from my SM-G960U using Tapatalk Last edited by foreverdeath; 03-30-2020 at 04:51 PM.. |
#64 |
The Kseries engines are a great engine. theyre very cheap and there are so many aftermarket parts avaliable for them, and most importantly they put out great power in stock form. the best part about these engines is the vtec. You can have very wild cams and still be able to idle like a stock motor.
My two concerns with this swap are: 1. everyone lowers theyre car and it effects roll center. now add that spacer (which is thin but still effecting roll center) you just made it worse. 2. After you add everything up its the same cost as installing a ls1 swap. You have a stock motor with twice the displacement and twice the torque. I spent $2500 in parts to put my $5000 stock 2004 gto swap. this was many years ago, so i am pretty sure the cost of a ls1 motor/ trans setup is much cheaper.. Last edited by thegr8one013; 01-08-2020 at 12:49 PM.. |
#65 |
You don't have to space down the subframe, or atleast I didnt with mine. They added the spacer to help with two things. First old pan to rack bracket clearance. To get the motor low enough to have the crank at the same level as a KA or SR the oil plan flange must nearly sit on the passenger rack bracket. I modded my subframe and passenger rack bracket to make the bracket as low profile as possable without moving my rack. Secondly the K24 is it tall to fit under the hood without notching the vavle cover or lowering the subframe. Even modding my subframe and a custom oil pan I only got the front of the vavle cover to be a few mm above the hood skin.
![]() ![]() Sent from my SM-G960U using Tapatalk Last edited by foreverdeath; 03-30-2020 at 04:52 PM.. |
#66 |
![]() Join Date: Jul 2005
I like the engine
as someone said above, the cost in dollars is only fraction of true cost. Average turbo 'swaps' are 10 to 20k regardless of what drivetrain chosen. The devil is in the details. Every swap has nit-pick bullshit to deal with that, if you don't know or don't care or can't tell (not a great mechanic/tuner) it will constantly be down, blowing engines, leaking, whatever, just from stupid things happening. In other words, I think am saying that it doesn't matter what engine you choose, as long as you are good mechanically and capable tuning, your expectations will be accurate and the vehicle will maintain it's inherent value and be fun to drive. happy swapping |
#67 | ||
![]() Join Date: Nov 2005
https://www.tf-works.com/faq-kswap/
#68 | |
2. LS1 dropouts still cost about the same, popularity has kept costs high. There are pros and cons to everything, and we all know that LS's have issues. For some people/applications a turbo K-series presents a better powerband or package.
#70 | |
I cant find the pic right now but I belive it's in my build thread on here. I belive it was only on pump and 10psi It seems like they got theres alil further back from reading. I got mine in the OE la postion. Using a cd009 the KA cd009 shift fit. And I only had to trim a little bit if the back side of the shifter hole. I wonder how that affects k24 upper coolant housings and the lower/tstat. As each runs into either the driver mount or gets close to the firewall. Sent from my SM-G960U using Tapatalk |
#71 |
#72 |
I was looking at TFs turbo manifold to bad its only vband so I can't run my borg on it but, but I noticed something very interesting. To get the more so far back with cutting the subframe, where I opted to cut of the seam and TIG it shut, they put the pick up front of the oil pump. So the pan actully protudes infront of the motor.
#73 | |
#74 |
I couldnt find one for the s200 series but do for the similar sized EFR. I'm not tryn to move to the manifold persay. But am looking at redesigning mine so a s300 or larger frame EFR wont leave the hood. Also being my the first manifold I've made I dont give it a long life expectancy, it really was only intended to get the same going anyways.
I dont wana loss twin scroll and my manifold runners are equal length within ~2% when I designed it in inventor. Sent from my SM-G960U using Tapatalk |
#75 |
Ahhhh makes sense why yours sounds good!
#76 |
I really need to remove the 1st resonator so it actully make it sing more then just turbo spool and dual 44mm wastegate dump. Once that cat back vband fell off and it was musical but way too loud dumping under the passenger seat to be on the street. The gaurds at the ECP for my ship could hear me start it up and RIP on it from about 1/2mi away.
#77 |
Please continue this thread, very knowledgeable material!!!
On that note, has anyone done a full swap meaning all the bells and whistles ( AC/PS, etc). I am highly interested in this swap since currently I am driving around a bare bones 240. I would love to see if you can turbo this motor plus have all the fancy amenities while still having a dependable daily. |
#78 |
I have PS on mine using the honda pump. AC will be a challenge ether mount it on the exhaust side in a NA setup. Or leave the AC in the factory location, which might cut into the oil pan designs of TF or mine and run electric PS.
#79 | |
#81 | |
#82 | |
![]() Have you considered going all motor? Check these guys motor build out. http://blog.wiseco.com/the-500-horse...ine-by-4piston I know, I know those dudes used methanol and lots of custom parts but still sick none the less. Gives hope to a possible all motor build. |
#83 |
![]() Join Date: Apr 2004
It's not a question of volume, but one of dimensions and oil control. A shallow pan that's wide has poor oil control, and you need a really good baffle setup to keep that around a submerged pickup.
Ideally we'd all have small diameter, really deep oil pans. You'd get good oil aeration (lots of head pressure to bottom of pan), and you could take ridiculous lateral/longitudinal G's before uncovering the pickup. But that's impossible to package, so we compromise on smaller factory sumps and try to add baffles to control the oil a little. Obviously with how many people have smoked K motors in a RWD longitudinal layout, they've got some real problems with oil control in the space provided.
#84 | |
Not really. I think NA for a drift car unless you got a big wallet asks for an LS and I'm against them cause of weight and balance. Yes, with porting, cams, a good head, 3 inch exhaust, and 9-10,000rpm capable block 400s is achievable on e85. Also to note their 500hp motor is a 2.7l with aluminum rods which would require deep pockets to build an rebuild every season. It makes good power 5k but I doubt it would be street able like a turbo car. ![]() Sent from my SM-G960U using Tapatalk |
#85 |
Also Im almost 100% certain thier 500hp 4 banger is on a fairly exotic fuel
Jamie Marsh.made.similar power and I recall he was on a nitro methane mix or something along those lines |
#86 | ||
You could definitely have around 300whp with a built NA K24, and you could run it on E85. I think would be a really fun setup if you really wanted the simplicity of an NA build. Anything past that and I think it makes a lot more sense to just use a turbocharger or supercharger. Keep in mind that things like this could be developed for this application as well! I think this is really rad. ![]() ![]()
#87 | |
![]() Join Date: Mar 2009
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
Now if they're still testing the oil pan on their car, they shouldn't be selling these pans to customers already without verifying they're going to work. |
#88 | |
#89 | |
#90 |
![]() Join Date: Oct 2006
I think it's awesome that Touge Factory is offering this kit! Way to go on the wiring PoorMans180sx!! I love seeing quality parts and quality work bro
Facebook or Instagram:@tightfitfab Email: [email protected] Check Us Out At: www.tightfitfab.com |
