#8851 |
![]() Join Date: Feb 2011
![]() Feedback Score: 16 reviews
so i have a greddy e-01 boost controller that im looking to sell. i found out that they go for about 550 new. what would be a good price to sell it since its used? i havent even seen anyothers out there for sale so anyone know a ballpark price i should be able to get for it?
#8852 |
![]() Join Date: Dec 2009
![]() Feedback Score: 21 reviews
Do S14 Origin stylish sides hang lower than the stock zenki bumper with SE lip would hang?
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
#8854 |
![]() Join Date: May 2010
![]() Feedback Score: 17 reviews
got into an accident last year. front end got damaged, but its repairable. only the radiator support to damaged.
so the other day i bought a new radiator support to put on it. was just wondering if u guys know how hard it is to weld it on and if its hard to get it aligned straight. and what the price range is. i dont wanna get ripped off.
http://upsidedownsideway.tumblr.com/ |
#8856 |
I'll vouch for sonicelectronix.COM. Got my headunit and 4 speakers there. Pretty quick shipping, decent prices. They even included a free DIN pocket, and harness adapter thing. And the antenna adapter was like discounted to a dollar when I bought my stuff.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr Last edited by Irresistible; 12-15-2011 at 12:21 PM.. |
#8857 |
What is over the spare tire in the trunk of the s14? because i just have a piece of wood and want something more stable so was wondering what was factory for that.
#8859 | |||||
From just looking at pictures, yes it'll hang lower. |
#8860 |
Philosopher King
The non CA model S13(KADE) ECUs do not have emmisions related CELs. Correct?
EDIT Such as egr temp sensor.
G O L D E N B E A R R E P U B L I C |
#8861 |
![]() Join Date: Nov 2009
Ok, so i got new rims and i would like to know the best tire size for a 17x9.5 the offset is +12 and will be going on my s14, my previous tire size was a 225/45 on my 17x9 wheel and it was pretty comfortable, not too big not to thin. Should i use the same tire size just because its only .5 wider? and input would be nice
Also, i have extended studs in the front but not the rear, i was thinking about getting extended lug nuts would i be able to use them? Since the fronts are extended and the rear studs are not? Sent from my SGH-T959V using Tapatalk Last edited by Jonathong; 12-15-2011 at 05:53 PM.. |
#8862 | |
#8865 | |
#8866 |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
Tial MV-S 38MM
So I bought the Tial MV-S 38mm external gate and the company was kind enough to send me 4 different springs. I'm not sure the one in it now, but these are the 3 that are out of the WG.
Anyone have experience with these and happen to know the PSI for these springs? I just wanna see if I can figure it out without putting them in one at a time.
IG/TikTok-ThatS14_Z06guy |
#8867 | |
#8868 | |
AFC #1
![]() Join Date: Oct 2003
#8870 |
![]() Join Date: Feb 2004
So I bought some s14 flcas and gave them to a friend with a press to change out the bushings for some prothane ones. Well he pressed out the bushings, and the outer metal sleeve came off, too. Well he tried prying off the outer sleeve and apparently fucked them.
So now I need new metal outer sleeves, and can't find them for sale. Link, anyone? |
#8871 |
Trader Rating: (26)
NVM that link didnt really help. Each one of these springs looks like it could be 3 or 4 different color combos lol
![]() The largest one is the only one that really looks like a certain one. Gold/Grey-1.0 Bar.
#8873 |
![]() Join Date: Dec 2007
Trader Rating: (68)
![]() Feedback Score: 68 reviews
I'm having a speaker/wiring problem! I plugged in NEW speakers in my front driver panel to test it and it worked, then removed it and reconnected the speaker 30 minutes later and it doesn't work
anymore?! It's not the new speaker cause i tested it on the other side.. It has to be my wiring...? I know it's negative and positive and i honestly might of reversed the (+) and (-) once. do you think by reversing the polarity caused a short which no longer lets me get power from the wires? Please help! Listening to music sounds horrible cause it's off balanced!
Late Night Crew... #02 <3 Bought anything from me? Please leave me a review! ![]() http://zilvia.net/f/private-sellers/...meistah21.html |
#8874 |
Trader Rating: (26)
Shit nevermind my lighting just sucked ass. Now I see the separate colors. They should of used purple, yellow, lime green and pink lol
#8875 |
Just got my 3-piece ES tension rod bushings installed.
I found them like this when I got home. Pic is with front wheels of the ground. Is this right ? SOLVED. Last edited by J_Konnexion; 12-16-2011 at 10:10 PM.. |
#8876 | |||||
![]() Join Date: Dec 2004
Trader Rating: (58)
Looks fine to me.
#8877 | |
Trader Rating: (68)
Thank you sir!
#8878 |
![]() Join Date: May 2011
Still trying to repair my subframe bolt, and I've cut the floorboard out from the top and trying to cut the bolt out in a square from the bottom. Is there a ton of structural issues when I weld it all back up?
#8879 |
Trader Rating: (58)
Not really, just ensure it's welded decently and you'll be g2g
#8880 |
Thanks. My parents are freaking out telling me its going to cause an accident and ill die. They think i need to buy another 240 and im not allowed to swap my sr, coils, or any part. But if theres no risk if its welded properly then I'll be g2g. I'll definitely have someone inspect them or re do them if necessary
