Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
12-14-2011, 05:11 PM | #841 |
Trader Rating: (58)
Feedback Score: 58 reviews
I just realized that 2 of my events this year didn't have any pictures, (and one was in my parents Mustang) no wonder why my file seemed lacking haha.
Some from Pocono Back in September And one from my buddy who takes pics on the side...I liked his BW of it
12-14-2011, 05:46 PM | #842 | |
These are some great pictures though, how bad were you stomping on the American Muscle in the background? |
12-14-2011, 05:52 PM | #843 | |
You know how much it would cost for the material for splitter size?
Turn and Burn! |
12-16-2011, 04:03 PM | #844 | ||
Trader Rating: (58)
Oh and the 335i would be a fun car for sure Quote:
I'd truthfully look for local sign shops (or supply shops), and ask them/email them...I'd say it would be the cheaper way rather than paying for a big sheet. Total size wise I couldn't tell you as I've never actually made one. I've got two Nascar Splitters here (which are not very deep...they have the width but not nearly the depth, and I'd love to have one...at the same time though I'd almost require a wing then to keep it settled, and I really dont' want to put a wing on my car. With my car retaining the factory plastic under-tray I may just leave it as it is.
12-25-2011, 03:02 PM | #845 |
12-25-2011, 03:07 PM | #846 | |
12-26-2011, 04:16 AM | #847 |
think this might be some thing u guys might be interested in
very respectable build my type x rig ***circuit car with rego*** - Hardtuned.net |
01-10-2012, 09:42 PM | #849 |
Trader Rating: (58)
I never got a chance to ask you guys about the car when I was at NJMP and you guys were there with the WTAC stuff. Mods and the sort? I was busy troubleshooting my own CAS related issue early in the day, thank goodness I had a spare in the truck
01-11-2012, 12:14 AM | #850 |
Bandwagon.
this is my second s13 i made for grip, first one i had stretched tires to grip lol, never knew this thread existed, for GRIP, i want to drift later,
but my set up is now Motor : Stock KA24DE with cone filter Wheels : Federal Rs-R 255/40/17 on Rpf01 17x9+22 all around. Brakes : Q45 Fronts Z31 caliper bracket/Altima Rotor upgrade on poterfield R4S with Super Blue ATE Dot 4 Fluid Suspension : Zeal Function D 6 Way adjustable 9k front 7k rear swift springs, SPL Titanium Ruca and Toe Rod, Spl Tension Rod, Moog Z32 inner tie rods w/ SPL V5 outer tie rods, F/R Strut Tower bars, Custom J.Walta C Pillar Bar, Stock front swaybar, Hica's rear sway bar, Jonnie Fraz Fender brace and TC brace. Drivetrain : One piece drive shaft steel, J30 diff, SPL V2 Solid Subframe Bushings Alignment : F -2.5 camber, 1/32 toe in R -2.2 camber, 1/8 toe in and corner balanced @ West End. Exhaust : RSR EX MAG & 2.5 aspec blastpipes, ran both exhaust. Future upgrades : OS GIKEN/KAZZ 1.5 way, Tanabe F/R Sways. old s13 on stretched tires R.I.P. current car
- Hong Last edited by hOngsterr; 01-15-2013 at 09:57 PM.. |
03-06-2012, 08:44 AM | #853 | |
For now, more front camber could definitely increase your grip in corners; the RS-Rs have relatively soft sidewalls. I was running -3.5 degrees after my last alignment and still had minor shoulder wear with my XS. Check out the picture you posted; it shows both sidewall flex and camber gain before the car's at its cornering limit. The reasons why I recommend 245/40s for NA KAs with 9" wheels is twofold: the 245 is less square and has a shorter sidewall for increased response, and it has a smaller OD for clearance and gearing. The LSD provides a mild stabilizing effect under trail-braking allowing you to come in harder and later and make up some time you lose because you have little power. The increased corner exit bite is nice, too. |
03-06-2012, 01:31 PM | #854 | |
Bandwagon.
Thanks for chiming in! Also, would a hica's steering rack really make a difference or would the stock rack be ok? |
03-07-2012, 08:31 AM | #855 |
Don't stagger, it makes the car understeer on turn-in and rotate poorly if you don't trail-brake harder than your current brake setup can handle on a summer day at Willow Springs or Buttonwillow. Also, there's little to be gained in traction since you're probably droop-limited (I'm severely droop-limited) and are unloading the inside tire.
The stock non-HICAS rack works well but given the local SoCal tracks' tightness, I'm switching to a HICAS rack when funds permit. Yes, I meant the Kumhos, sorry. |
03-07-2012, 09:02 AM | #856 | |
Trader Rating: (58)
03-07-2012, 10:01 AM | #857 |
Same here I run 235 255 on the track with Starspecs front and RE11R's on the rear. Never had a problem....
But I think running same size tires in the front would help braking stability and distance more... Going to try that soon.... But truthfully comes down to alignment don't you think?
Turn and Burn! |
03-07-2012, 11:07 AM | #858 | ||
Bandwagon.
03-07-2012, 11:24 AM | #859 | |
Trader Rating: (58)
03-07-2012, 03:54 PM | #860 | |
And Paul, I was diggin and laughin at the domo on your windshield that day haha. I have 4 similar ones on mine.
97 240sx se |
03-09-2012, 07:34 AM | #861 | |
I suppose the stagger is more of a driver preference thing, and I prefer my cars to rotate very, very well given the nature of Horsethief Mile and my local mountain roads. At Horsethief, front grip is hugely important. |
03-09-2012, 10:13 AM | #862 | |
I toe in a rear .20" and with 7.5 stoke castor in the front, I think it handles and rotates well around the apex.... But a lot of time attackers are using non staggered like Scorch Racing or Exceed Moat... I think AceInTheHole also does non-staggered for his autox stuff.... Already running 300zx iron calipers with Carbotech XP12 and XP8 rears.... I think probably too much front end weight has a lot to do with it.... Fiberglass the front end, should help a little... but oh wellz....
Turn and Burn! |
03-09-2012, 10:14 AM | #863 | |
Turn and Burn! |
03-09-2012, 11:32 AM | #864 | |
Trader Rating: (58)
I can't remember the weather, but the World Time Attack cars were there too. I had a CAS issue earlier in the day, and then the wastegate vibrated the back bolt off, and I was running around at 7-8 or so PSI due to the leak (slow car that day)...big change being down 100hp in the thing, it's a entirely different car. I was there with a Red NX2000 (Modded VVL)
03-09-2012, 03:19 PM | #865 | |
97 240sx se |
03-09-2012, 04:15 PM | #866 |
Trader Rating: (58)
Yeap, had to be me then for sure. I always run s14 or 14 on the car, and that's it.
Oh...yea those 'scions'...I caught all sorts of flack on SpeedHunters for asking how on earth they came up with their lap times, when I was in timing/scoring on that day at different points and never saw times that fast. I know DentSport was running well, as was that Hankook Suby (with 800whp I hope it does)...but tht Scion ran like poop.
03-09-2012, 04:19 PM | #867 | |||
Trader Rating: (58)
The Z calipers served me well, and going with the larger 13" Cobra rotor helped them, but the WilWood DefSport/Skullworks setup was a night and day difference (not to mention better modulation). I didn't think it would be that drastic but it was huge...I'm 12/12 too, man is it fun stopping
03-09-2012, 09:14 PM | #869 |
I saw that deal on NRR... how does it make a huge difference? is it because of the bigger rotor diameter? or thicker? I know for sure they are lighter....
Turn and Burn! |
03-10-2012, 10:06 AM | #870 |
Rotors are lighter, so the car has better turn-in and the front dampers work a little better. The pad is huge and the calipers, brackets and hats are nice and stiff so it's easy to modulate.
I run XP10s and XP8s and had trouble keeping heat in the XP10s this last track day, even on a short track, but I'm also at 2425lbs or so with driver. |
