Old 08-01-2012, 12:59 PM   #841
OutlawLui
OutlawLui's Avatar
OutlawLui is a well-known jackass
My semi tuck
Still have a long way to go
OutlawLui is offline   Reply With Quote
Old 08-01-2012, 08:42 PM   #842
s13beast
s13beast is an unknown quantity at this point
I can haz in?
s13beast is offline   Reply With Quote
Old 12-12-2012, 11:44 PM   #843
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Didn't really know where to post this question other than here.
When you guys are relocating your fusebox to the glovebox (s13) or where the airbag was (s14), what are you doing with your fuse box power wires that plug into the lower tranny harness and the EFI plugs?
Originally Posted by KoukiMonsta
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
StryfeS13 is offline   Reply With Quote
Old 12-13-2012, 02:21 AM   #844
GSXRJJordan
GSXRJJordan's Avatar
The fusebox will still need battery power, no matter where it is. As far as "EFI Plugs", do you mean the S13's plugs to the engine harness? For S13 just turn them around and run them back into the passenger footwell area. For S14, that stuff all changes, but you're still passing all the power/triggers through the M63/F3 plug anyway.
Old 12-13-2012, 12:01 PM   #845
C-unit
C-unit's Avatar
C-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to all
chassis harness is tucked
C-unit is offline   Reply With Quote
Old 12-13-2012, 05:40 PM   #846
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Yeah I know it needs battery power. I'm talking about the 3 connectors that usually plug into the fuse box on S13's that are part of the lower transmission harness. Just cut and extend or what?
And yeah I meant the plugs that go to the engine harness. The brown one and gray one.
Thanks
Gotta love Zilvia.
Old 12-13-2012, 08:33 PM   #847
GSXRJJordan
You still need to connect to the trans harness, although you can change the alternator and starter solenoid wiring if you want to get fancy and lose those two useless connectors.
Old 12-25-2012, 11:23 AM   #848
lalo167
lalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the rough
What wire do you guys recommend to extend the injector wires? I'm trying to run the harness through the manifold. Will I have to extend anything else?
lalo167 is offline   Reply With Quote
Old 12-25-2012, 11:27 AM   #849
benarovi
benarovi is an unknown quantity at this point
same gauge as stock wire. I forgot size I recently did mine. I also extended the CAS and MAF at the same time, ran the maf behind the motor. you might have to extend the cas
benarovi is offline   Reply With Quote
Old 12-25-2012, 11:40 AM   #850
lalo167
I'm having trouble finding the size, and any idea on how long to extend the wires?
Old 12-25-2012, 02:59 PM   #851
GSXRJJordan
Depends on the engine, KA is different than S13 SR, which is different than S14/S15 SR. RB's it depends on which manifold you're using.
20ga wire is fine, stock is 18ga for injectors.
Old 12-25-2012, 05:10 PM   #852
lalo167
Stock KA24DE
Old 12-25-2012, 07:24 PM   #853
drft-s12
drft-s12's Avatar
drft-s12 is making a name for him/her selfdrft-s12 is making a name for him/her selfdrft-s12 is making a name for him/her self
drft-s12 is offline   Reply With Quote
Old 12-26-2012, 11:19 AM   #854
EvoVIII808
EvoVIII808 is an unknown quantity at this point
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
im not the best at reading wire schematics but looking at the FSM (EL-21) can i remove the 4 Retract Relays and get rid of all that wiring that runs to them. I have a Silvia front and really want to clean up the main harness going across the front end.
I have already removed the plugs/wire for the headlight motors.
Check Out My S13 Build
EvoVIII808 is offline   Reply With Quote
Old 12-26-2012, 02:14 PM   #855
GSXRJJordan
Stock KA24DE
I think the overall length from under the manifold to the injector is about 7" on my KA stuff. Easy enough to measure...
Yup, can def lose the headlight/retract relays when you go Silvia front.
Old 12-26-2012, 02:35 PM   #856
EvoVIII808
Alright. Thanks a bunch. This is going to git rid of a lot of useless wires.
Old 12-29-2012, 02:18 PM   #857
EvoVIII808
Started my full tuck.
Old 12-29-2012, 02:39 PM   #858
shaggy sr
shaggy sr's Avatar
shaggy sr is an unknown quantity at this point
Originally Posted by s13beast View Post
I can haz in?
i like the way it looks simple. what parts should i remove and tuck something around the bay? semi wire tuck.
shaggy sr is offline   Reply With Quote
Old 12-29-2012, 08:04 PM   #859
GSXRJJordan
Besides the engine harness, the chassis harness/fusebox/relay box and battery are the big ones.
Old 12-29-2012, 09:34 PM   #860
tricky_ab
tricky_ab's Avatar
You're going to wrap these...right?
Old 12-30-2012, 12:59 AM   #861
EvoVIII808
Yup, they are wrapped. Been doing bit by bit and placing things where I want them as I go. Tomorrow it will be complete. Only thing on the sides now are headlight wires. Harness ran across the dash and over to glove box. Lower engine harness comes through the tranny tunnel. Not as clean as the others I have seen, but it gets the job done.
Old 12-30-2012, 06:49 AM   #862
Super_OK_S13
Super_OK_S13's Avatar
Super_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud ofSuper_OK_S13 has much to be proud of
Excuse the not painted-ness... this is my engine harness. the chassis comes out on the sides just like EVOVIII808 did. this is also before i built the new core support and lower rad support..
Super_OK_S13 is offline   Reply With Quote
Old 12-30-2012, 03:06 PM   #863
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Would this hidden under the radiator support be sufficient for cooling an SR?
Griffin Aluminum Drag Race Radiators 2-55185-XC - SummitRacing.com
I would go with the radiator option that uses an in-line filler neck, but other than that it would be identical to the kit above.
Another shroud option is this one made by Flex-a-lite.
Old 12-30-2012, 03:32 PM   #864
Matej
Trader Rating: (39)
Saved these pictures from members on here, but I do not recall who they are.
Old 12-30-2012, 03:43 PM   #865
Matt.
Matt. is an unknown quantity at this point
some cool stuff here getting ideas
Matt. is offline   Reply With Quote
Old 12-30-2012, 04:12 PM   #866
GSXRJJordan
Yeah that'll do fine, especially if it's ducted from the bumper inlet to the radiator.
Tek18b_Jimmy, your engine harness looks solid, but is that white heat shrink at the ends of your FR braided loom just normal polyolefin stuff, or adhesive-lined? That loom will pull out of the heat shrink over time with vibration if you didn't use adhesive heat shrink.
Old 12-30-2012, 09:27 PM   #867
Super_OK_S13
Thanks GSXRJJORDAN- unfortunatly i didnt know about the sticky shrink tube in white when i did it. so i electrical taped the ends of the loom to the wire clusters, then used heat shrink on it. if need be, i will find the sticky kind of white heat shrink and de-pin at the connectors and try again.
i did pull on the loom and it didn't really want to pull through the heat shrink.
Old 12-30-2012, 10:58 PM   #868
the.SHOP
the.SHOP is an unknown quantity at this point
the.SHOP is offline   Reply With Quote
Old 01-01-2013, 03:58 PM   #869
sr20detconv
sr20detconv is making a name for him/her selfsr20detconv is making a name for him/her selfsr20detconv is making a name for him/her self
Mine
From this:
to this:
To finaly this:
sr20detconv is offline   Reply With Quote
Old 01-01-2013, 04:24 PM   #870
sil14zenki
sil14zenki's Avatar
Trader Rating: (25)
sil14zenki is an unknown quantity at this point
Feedback Score: 25 reviews
^looks good
when i first did my swap
how it looked last year
now tubs and going to change engine bay color for 2013
sil14zenki is offline   Reply With Quote
