Old 11-22-2011, 10:03 PM   #8641
delado
delado's Avatar
delado is an unknown quantity at this point
Hey guys!
I'm in the process of mounting my roof spoiler on my coupe, but I'm not sure on the best way to mount it. Do people really use double sided tape? Couldn't you see it through the glass since it rests on the glass sorta?
Thanks in advance!
delado is offline   Reply With Quote
Old 11-23-2011, 12:12 AM   #8642
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
Originally Posted by delado View Post
Hey guys!
Thanks in advance!
Double sided tape. The red 3M kind. I have the inch wide one. Holds crazy good. I set it down for one second and had to pull it back off cus it was on a little off center and it was a HUGE pain to get off within that second or two. Just stick it on, push down for a little bit, and let it sit in the sun maybe for a little to let the adhesive heat up. Mine holds amazing. And it doesn't really matter that you can kinda see the tape because it's barely visible. Unless you're just looking for the tape. Then obviously you can see it.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 11-23-2011, 08:58 AM   #8643
delado
delado's Avatar
Thanks a lot dude! I can't wait to install mine. Good info.
Old 11-23-2011, 01:03 PM   #8644
Otto347
Otto347's Avatar
Otto347 is an unknown quantity at this point
Anyone with an S14 have some 9 or 9.5 wide wheels on the back, if so could you get me a measurement of the outside to outside? Please?
Thanks!
Doesnt have to be exact, within an inch or so would be fine.
Originally Posted by atutt View Post
Or you could have stopped being a lazy asshat and done some research.
Otto347 is offline   Reply With Quote
Old 11-23-2011, 01:53 PM   #8645
eddieflo
eddieflo's Avatar
eddieflo is an unknown quantity at this point
Send a message via Yahoo to eddieflo
Did you try google?
this was my second result
s14 zenki to kouki conversion info - SFLDrifters.com
now according to that you dont have to drill your rad support but you do have to drill your headlight brackets. The easiest way to figure out where you want them is to mock everything up and then measure 50 times and drill once.
As soon as everything is on, save headlights for last. The add the lights and see where they need to be mounted.
Its really easy if you have a marker and a drill and drill bits.
Thanks dude! I tried google too, but it gave me a bunch of useless links
Wastelandfresh.tumblr.com & soundcloud.com/eddieflo
eddieflo is offline   Reply With Quote
Old 11-23-2011, 02:22 PM   #8646
Wake
Wake's Avatar
Thanks!
You realize this wont be accurate unless that have the exact same spec wheels and stock fenders right?
Besides what is being with in a inch going to tell you?
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 11-23-2011, 03:11 PM   #8647
GL Chrillz
GL Chrillz's Avatar
GL Chrillz is an unknown quantity at this point
I'm wondering what would be the best tool to cut out a part of my frame rail. My welder should be here on Tuesday, so I'll need to start getting this cut out. And is there any place that will rent such a tool, or do I have to buy one?
GL Chrillz is offline   Reply With Quote
Old 11-23-2011, 04:41 PM   #8648
Irresistible
Thanks!
17x9.5j+12 with around -4* camber and 235/40 or 225/45 in the rear on stock rolled metal will fit good. Especially if attempting to tuck. Possibly 5-10mm spacer depending on how you want it to look. (My Varrstoen track spares will be that size and offset. It's within 6mm of 10j+18) But nobody can tell you exactly because nobody really knows what look you want...
Old 11-23-2011, 05:19 PM   #8649
Otto347
Otto347's Avatar
This isnt for a 240, its for an S14 IRS thats going in something else. I am just trying to get a ballpark figure on what the face to face is going to be vs the stuff thats in it now.
Im shooting for 9/9.5 wide wheels but im not sure if im going to have to run a high offset to clear the bedside with the IRS in there.
Old 11-23-2011, 08:08 PM   #8650
TrueFreshness
TrueFreshness is an unknown quantity at this point
so i found out my car was converted from auto to 5 speed. The guy told me that he put a hydraulic clutch in so as soon as you start releasing the clutch it catches friction and the clutch pedal doesnt come all the way up unless i pull it up but its soft until its back to where it comes up on its own if that makes any sense. Is it supposed to be like this?
TrueFreshness is offline   Reply With Quote
Old 11-23-2011, 08:45 PM   #8651
doomviillain
doomviillain's Avatar
doomviillain is an unknown quantity at this point
Send a message via Yahoo to doomviillain
This is my first time working with an SR
A headgasket blew and had a water/oil mix issue. Got a new headgasket, got the heads rebuilt and resurfaced, bolted down w/arp head studs. I still have a water/oil mix issue. Now to the question:
Is this happening because I didn't resurface the block since its also aluminum and possibly warped?
Or is this a result of a cracked water jacket?
You are seventeen.
Your argument is invalid.
doomviillain is offline   Reply With Quote
Old 11-24-2011, 12:57 AM   #8652
Irresistible
It should not. Should come all the way up from my understanding. Hydraulic clutch uses fluid, vs a clutch that uses a braided line. Just play with the pedal adjustment. Stock specs are in the FSM.
Old 11-24-2011, 02:58 AM   #8653
Wake
Wake's Avatar
ALL s-chassis are hydraulic clutches btw.
Pedal should return to normal as stated.
S.P.P.S. Member #00
Old 11-24-2011, 03:19 PM   #8654
yomisiu
yomisiu's Avatar
yomisiu is making a name for him/her selfyomisiu is making a name for him/her selfyomisiu is making a name for him/her self
im sure this has been covered but, what the hell.
This is a question about us USDM Zenki dudes with JDM headlights. (or anyone knowledgeable)
how are you using your high beams?
from what i gathered months ago after installing and recently after slightly searching online,
our high beam plug or bulb (or both, idk) is different from the JDM one.
i've read that it's possibly a h3 or h1 bulb (which? if either.) also,
will that bulb fit our connector?
i just want to be 100% certain
thanks
and gobble gobble~ lol
yomisiu is offline   Reply With Quote
Old 11-24-2011, 04:50 PM   #8655
TrueFreshness
ok thanx for the help. Im gonna be killing this thread all week lol. another thing, my car idles perfectly but when i get around 3500 or 4000 rpm my car kinda feels a little sluggish then pulls hard again then sluggish a little again. could it be running rich? I noticed a cloud of smoke today when i launched at 3000 rpm accidently so could that be a sign that its rich or is there something else causing it to feel like this?
Old 11-24-2011, 07:28 PM   #8656
280zx2by2
280zx2by2's Avatar
280zx2by2 is an unknown quantity at this point
Anyone know where to get lug nuts for Center Line Auto Drags besides Center Line's brand itself?
280zx2by2 is offline   Reply With Quote
Old 11-26-2011, 01:39 AM   #8657
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
what is the difference between MVS and MVR wastegates?
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 11-26-2011, 12:48 PM   #8658
Otto347
Otto347's Avatar
MV-R is bigger
Old 11-27-2011, 09:42 AM   #8659
Ebird
Ebird is an unknown quantity at this point
hey i have a infitniti m30 i wanna know what lowering springs i could use to lower my carr
Ebird is offline   Reply With Quote
Old 11-27-2011, 09:46 AM   #8660
Ebird
some one let me know please i just came into the game and i dont know alot about nissian and infitni really message me
Old 11-27-2011, 10:08 AM   #8661
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
Best of the best is Swift.
if you wanna be like every other civic go with Eibach.
if you wanna be loyal to a brand try Tanabe, Espiler, etc...
your better off getting coilovers so you can adjust height for your specific wheel fitment.
MadScientist is offline   Reply With Quote
Old 11-27-2011, 09:45 PM   #8662
chiboy002
chiboy002 is an unknown quantity at this point
how hard is it to replace the front fender frame rail thing on an s13?
the part that the top of the fender bolts onto, to be exact
street dancer.
GLEAM
Old 11-27-2011, 09:52 PM   #8663
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Cut off wheel/plasma/etc etc and a welder
Old 11-27-2011, 11:19 PM   #8664
Lukasss
Lukasss's Avatar
Lukasss is an unknown quantity at this point
Anyone know what rear this is?
http://mkimg.bmcdn.jp/minkara/photo/...2891097/p8.jpg
Lukasss is offline   Reply With Quote
Old 11-27-2011, 11:25 PM   #8665
JZenki
JZenki's Avatar
JZenki is an unknown quantity at this point
Is there any remedy to the faux lights for us zenki owners? They just seem like tail lights with dead bulbs!!! But I still love my zenki lights, esp with the "240sx" badge in the middle, instead of the Nissan badge, reminds me of an s13 or a z32 or heck, even a Cube lol. I would rather stay zenki all the way instead of going kouki booty, since I'm starting to find kouki tails on zenkis sorta, kinda, how should I say this.... Tacky? (No offence) since the boxy "aggressive" tails just doesn't go into lines all that well with our zenki front ends, but that's just my opinion... Question is, has anybody out there modified the zenki center garnish to light up ? My idea of how the center garnish lights should operate is as if they were just lit like the corner parking lights up front, functional, but just lit so our rear lights are hard for old ladies to miss.. tried searching everywhere but nothing pops up, shall I make a thread about this?
JZenki is offline   Reply With Quote
Old 11-27-2011, 11:41 PM   #8666
doke! ドリフト
doke! ドリフト's Avatar
doke! ドリフト is an unknown quantity at this point
I'm 5' 10" 155lbs I'm looking for a snug fitting bucket seat. Outta these seats has anyone owned or felt how they feel? Obviously the Zeta is ballin but whats the best for the price?
Order from lowest to highest priced..
About $210 ¡ÚUP GARAGE¾¦ÉʾðÊó¡ÛÃæ¸ÅÉÊ¡¡ŽÌŽÙ ŽÊŽÞŽ¹Ž¯ŽÄŽ¼Ž°ŽÄ(¤½¤Î¾)¡¡ CHARGESPEED ¥Õ¥ë¥Ð¥±¥Ã¥È¥·¡¼¥È
$390 ¡ÚUP GARAGE¾¦ÉʾðÊó¡ÛÃæ¸ÅÉÊ¡¡ŽÌŽÙ ŽÊŽÞŽ¹Ž¯ŽÄŽ¼Ž°ŽÄ(¤½¤Î¾)¡¡ East Bear Sports SIGMA
$520 ¡ÚUP GARAGE¾¦ÉʾðÊó¡ÛÃæ¸ÅÉÊ¡¡ŽÌŽÙ ŽÊŽÞŽ¹Ž¯ŽÄŽ¼Ž°ŽÄ(ŽÌŽÞŽØŽ¯ ÄŽÞ)¡¡BRIDE ZETA*¶ ¥Õ¥ë¥Ð¥±¥Ã¥È¥·¡¼¥È
AEM Series 2 ECU 30-6620 and Chase Bays S14 SR20DET engine harness for sale
doke! ドリフト is offline   Reply With Quote
Old 11-27-2011, 11:59 PM   #8667
killer skittle
killer skittle is an unknown quantity at this point
Let's say I buy an oil relocation kit when I fit the an fittings together i know I use Teflon tape. So do I have to put it on a certain way cause I was thinking that tape stuff could get in the oil system...sorry for the beginner question but we all have to start somewhere.
killer skittle is offline   Reply With Quote
Old 11-28-2011, 08:51 AM   #8668
nissanfreak317
nissanfreak317's Avatar
Trader Rating: (18)
nissanfreak317 is an unknown quantity at this point
Feedback Score: 18 reviews
I use brown Permatex for oil related threaded areas. It dries hard and does not ruin oil systems if properly applied.
Then again, I just checked the Circuit Sports Oil filter relocation kit on FRsport.com and it uses a compression type fitting which does not use the threads to seal, there is a conical face that creates the seal and using anything on that fitting would be useless/bad. It is designed to be assembled without any sealer or Teflon tape.
Anyways, double check what type of fittings are on there before you do anything. And don't use Teflon tape.
nissanfreak317 is offline   Reply With Quote
Old 11-28-2011, 08:57 AM   #8669
dezzS13
dezzS13's Avatar
dezzS13 will become famous soon enoughdezzS13 will become famous soon enoughdezzS13 will become famous soon enoughdezzS13 will become famous soon enough
Send a message via AIM to dezzS13
Looking to get a new starter due to turning the key and getting one click and nothing. Just replaced the battery and I'm still having the same issue. My questions is: Will a single cam starter fit a s14 dual cam?
dezzS13 is offline   Reply With Quote
Old 11-28-2011, 10:56 AM   #8670
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Originally Posted by zooopreme View Post
You can use S14 brake pads for Z32 brakes, yes or no?
I'm aware that they are different calipers but if I remember correctly, I read somewhere in this forum that S14 brake pads fit z32 calipers. Thus why I asked.
Hate to dig up my first question again but I want to be spoon-fed for this one because I really don't want to purchase the wrong pads.
http://zilvia.net/f/tech-talk/153557...m-vs-30mm.html
^Anyway, according to that thread, S14, z32, skyline brakes all use the same brake pads. And with the responses I got in this thread, I'm STILL not 100% on whether or not this is true.
Second question, I was on courtesy parts & they're z32 brake inventory page is a bit confusing for me. I've got 30mm calipers so does that mean 1991-1996 z32's will all fit? Does N/A or turbo matter for those years?
For Sale #1 | For Sale #2
