11-21-2011, 07:18 PM | #8611 |
Going to change my head gasket. Is it necessary to take the intake manifold since it seems to be a bitch to get off? 91 hatch. If I must take it off is there any secrets to getting that sucker off?
11-21-2011, 07:59 PM | #8612 | ||
Trader Rating: (58)
Feedback Score: 58 reviews
You don't need to take the intake at all. However the trick is to remove it in two pieces
11-21-2011, 08:08 PM | #8614 | |
Trader Rating: (58)
11-21-2011, 09:10 PM | #8616 | |
Trader Rating: (58)
atf
11-21-2011, 10:46 PM | #8617 |
I just use OEM Nissan P/S fluid. Pricey, but I know it won't kill my pump.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
11-22-2011, 12:05 AM | #8619 |
Stock S14 SR
Consequences to removing the heat shield on the exhaust manifold? Mine rattles like death and I can't figure out how to stop it. No bolts are missing and we tried bending it away from the manifold a little to see if that would help, but no success. |
11-22-2011, 12:39 AM | #8620 | |
I've been using Valvoline dex-III atf and it seems to be fine. my rack eats fluid, or leaks, so idk
street dancer. GLEAM |
11-22-2011, 10:12 AM | #8621 |
Seems to be working alright for me. Sure looks and smells like ATF. I'll look into the Valvoline stuff, but from the Nissan fluid it seems like my pump is working a little smoother. I dunno. Best advice I can give is honestly just research. See what others are using and what's working best for most people.
11-22-2011, 12:30 PM | #8622 |
Okay, maybe I'm retarded or something... But I've been searching ALL morning and can't find the how-to step by step thread on how to convert my zenki s14 into a kouki.... I've searched here and nico and can't come up with exactly what I'm looking for...
Can anyone link me to it? I'm def gonna bookmark it this time >_< EDIT: I have all the parts, I'm mainly looking for directions on where to drill my zenki rad support to fit the kouki headlamps.
Wastelandfresh.tumblr.com & soundcloud.com/eddieflo |
11-22-2011, 02:32 PM | #8623 |
Did you try google?
this was my second result s14 zenki to kouki conversion info - SFLDrifters.com now according to that you dont have to drill your rad support but you do have to drill your headlight brackets. The easiest way to figure out where you want them is to mock everything up and then measure 50 times and drill once. As soon as everything is on, save headlights for last. The add the lights and see where they need to be mounted. Its really easy if you have a marker and a drill and drill bits.
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
11-22-2011, 03:04 PM | #8624 |
would it be better to put lucas oil power steering fluid with conditioner in my power steering fluid reservoir or should i put the dexron III or whatever is the latest blend into it? I was told at autozone that the lucas oil would be better.
11-22-2011, 03:11 PM | #8626 | |
viscosity is different so all that happens is seals might leak with PS fluid
11-22-2011, 03:13 PM | #8627 | |
Yeah. Like I said, seems like it's leaking less now. But enough thread cluttering.
11-22-2011, 04:32 PM | #8628 |
Hey guy's tried the search function and google, but I can't find the part number for the USDM S14 240sx rear bumper?
Can anyone help me? It looks so much cleaner than the ADM rear bumper |
11-22-2011, 04:54 PM | #8630 |
11-22-2011, 05:54 PM | #8631 | |
FASCIA KIT-REAR BUMPER - 240SX (S14) 1995-1998 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com Site is super slow for me for some reason...
11-22-2011, 06:17 PM | #8633 |
my fan turns on now when i go into 2nd gear then turns off a few minutes after. I checked my temp gauge but it was not even at the half way mark. Why is it doing this?
11-22-2011, 06:45 PM | #8636 |
Obviously rad fan... Electric, clutch, manual, house fan mounted in there?
11-22-2011, 08:00 PM | #8638 | |
WakeBHR do you have a site? |
11-22-2011, 08:03 PM | #8639 |
a site for what?
Oh, no not yet I will be doing something along those lines VERY soon but I was just suggesting you hit up a member and have them send you one ass opposed to ordering a brand new one. Besides the fact that you cant order them online from courtesy so you would have to call them, and shipping will be just as horrendous.
