03-17-2012, 02:08 PM | #811 | |
03-17-2012, 02:15 PM | #812 |
Man w/ CTSV & a Car Seat
Tein springs are softer but if its still the original shocks, it needs to get replaced. I've known guys who slapped aftermarket springs on their stock shocks and blew the shocks out in a matter of days. I was one of those people back in the days...and my car only had 35k miles on it.
03-18-2012, 10:37 PM | #813 |
Hi guys so I just got a s13 fastback and put some hks hiper d coils on it. I have a set of stock se rims. with some toyos r888 205/50/15. im scared that the front tires will rub with the coils so i was wondering if my best bet would be some spacers? im planning to track the car in april so would this be ok ro run it with some H&R hubcentric spacers? Im a little new to this, so be easy on me. I appreciate everyones help! thank you!
03-19-2012, 03:04 AM | #819 |
s13 with 17x9 +22 and 17x9.5+15 wheels, not looking for a stretched set up, just something thats functional with just rolled fenders and slight pull in the rear if have to. thinking about running 225/45/17 hankook v12 for the fronts and 235/45/17 in the rears. or would you guys run another series tires. thanks!
03-19-2012, 09:18 AM | #822 | |
Trader Rating: (38)
Feedback Score: 38 reviews
I have 205/60/15 on all 4 corners so I'm almost certain that it'll fit. BF Goodrich tires. Be aware that some brands run wider than others though. I don't think Toyo's run wider than said spec. But I'm not 100%. Even then, I don't think it'll rub. I also have 15mm spacers all around because I had z32 brakes on the car at some point but now I'm running Q45's up in front & stock ones in the rear. So with all of that said, you'll be fine with or without spacers. They should not rub. |
03-19-2012, 03:59 PM | #824 |
For an S14, how hard would it be to do:
Front: 18x9.5 +12 225/40R18 -3 to -4 camber Rear: 18x10.5 +15 235/40R18 0 to -1 camber And is that too much tire stretch in the rear? Would I be able to run close to 0 camber in the rear, or at least -1? What kind of fender work would be required? |
03-19-2012, 05:16 PM | #826 |
I know this is a bit off topic but I got some VIS 20mm fenders and the fit/finish was complete ass. I have heard origin is good, but are they predrilled? Fit oem or close? Basically I want to know what the best option is. My kouki is absolutely cherry and I don't want some sloppy looking body panels on there
Any companies out there making urethane bumpers/fenders/ect? I haven't been able to find any. Thanks for the help...it is kinda a fitment question and there are some very knowledgeable people in this thread Last edited by Breakbeat93; 03-19-2012 at 06:03 PM.. |
03-19-2012, 05:44 PM | #827 |
Hey guys,
Bout to buy new rims and tires for my s13 and have some questions for what size tires i should get. Looking to get 17x9.75 in rear and 17x8.25 in front +25 offset all around. My question are 1. what tire size's should i get? 2. Can i make this fit on coilovers and minimum camber (if any) 3. how much rolling and pulling needed, if any |
03-19-2012, 05:47 PM | #828 | |
03-19-2012, 06:36 PM | #830 | |
http://legitjapan.wordpress.com/2012...for-that-kouk/ |
03-19-2012, 06:55 PM | #831 | |
for the rears: -2.5 camber is needed for tire to be flush with body. i have -2 camber and did a tiny pull. looks great |
03-21-2012, 03:24 AM | #833 |
ok first of all whaddup everyone and id like to thank u in advance for helping me out here. i wanna run 18 inch ssr professor sp1s on my 95 zenki id like 9.5 width in the front and am open to what would look best in the back. i want a meaty looking tire in the back especially however i dont want it too hella flush or tucked. just aggressive looking stance with very minimal wheel well showing. so basically is my question is when i go to order these wheels what offset would i want?
03-22-2012, 06:43 PM | #834 |
Hey guys. I have 17x9.75 +25 offset and I was thinking of running 215/40 or 225/45 all around. What do you guys recommend? Its also for a s13 and I have stance coilovers.
Thanks. Last edited by Jason9011; 03-22-2012 at 08:30 PM.. |
03-22-2012, 09:43 PM | #835 | |
^^^ thats a pretty mild fitment. shouldn't have any issues.
03-23-2012, 10:36 AM | #837 |
Trader Rating: (24)
Feedback Score: 24 reviews
anybody with S13 running 30mm overfenders, slightly pulled front fenders, and flush fitment?im looking for a good spec of wheels. for the fronts I am set on 18x9.5 unknown offset for now. as for the rears im not sure yet 18x11 im thinking.
edit: i think i wana run 18x9.5 -15 up front and 18x11 -4 rears what you guys think of this set up? Last edited by killer240; 03-23-2012 at 03:00 PM.. |
03-23-2012, 09:19 PM | #839 |
Hi everyone, so i just put my 205/50/15 toyo r888 on my stock s13 se rims but for some reason there is VERY little space between the tire and coils i have to raise the car all the way up so that the locking rings are above the tires so that it wont rub. i was told that i would be able to clear easily with stock se rims and those size tires. but i dont know why i only have a gap that can only fit a quarter between it. I have hks hyper d coils on. can someone please help me? thanks alot
