Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
08-15-2011, 06:58 PM | #811 | |
A few pics, sorry for no hotlinking, don't feeling like saving a pic. More camber = more grip = more weight transfer = looks way more baller in track pics. Nevermind the super dead grass - only 1 grass fire last event! Hart Photography & Graphics > Instructor Group - Set 2 Chasing Modded Exige (notice weight transfer on inside tires): Hart Photography & Graphics > Instructor Group - Set 1 Passed Exige (he later spun trying to keep up with me): Hart Photography & Graphics > Instructor Group - Set 1 Little Dorifto: Hart Photography & Graphics > Instructor Group - Set 1
08-15-2011, 10:51 PM | #812 |
Trader Rating: (58)
Feedback Score: 58 reviews
I've felt the car needs more camber, however on Street Tires (NT-05's) I wonder if it's worhwhile. I'll try that for the next event.
Iv'e got Pocono North, Lime Rock, Watkins in a month, so i'll have time
08-16-2011, 06:51 AM | #813 |
Def those pics are awesome! That's some serious aero. How much lap time do you think you're dropping with the wing+splitter?
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
08-16-2011, 08:54 PM | #814 |
They were worth about 2-2.5 secs a lap on a ~90 sec lap (1.7 mi track, so average speed is ~70 mph.
08-16-2011, 08:58 PM | #815 |
I ran about -2.7 with NT-05s and wear was pretty even, but I think they wanted more and would have been faster.
08-16-2011, 09:33 PM | #816 | |
Trader Rating: (58)
I'll say this, I certainly see more wear in the back with that marginal toe in than I ever have with camber. Sure it's obvious but it's crazy to the difference.
08-16-2011, 10:07 PM | #817 |
My rears wear very very evenly. My fronts still wear the outside a little bit much. The NT05s have stiff sidewalls though, so it seems to help with the outer tread wear up front. RA-1s are like sticky marshmellows, lots of roll, movement - but you can do the stupidest stuff and you won't lose it. Very very broad plateau of grip vs. slip angle.
10-13-2011, 05:39 PM | #819 | |
New Engine (Think I spun a rod.) Rocket Bunny 6666 Kit New Rims and Tires and 5 Lug Rig up a Fuel Surge Tank Get a Crashbar up front to better secure the splitter Fix up the rear end cause it clunks a little cause of a burr on the ring gear some where Paint Job too hahaha.... it will be a fun year! How are you doing?
Turn and Burn! |
10-31-2011, 01:41 PM | #822 |
Thanks for the reply, I just bought a kaaz 2 way but people were telling me that it will break loose too easy on entrance, as I'm not drifting this has kind of made me hesitate to install. But I was thinking proper rev matching via heel toe on downshifts should not disturb the grip levels too much...I do drive really aggressive so what your saying makes me want to install tonight!
10-31-2011, 06:30 PM | #823 |
WANGTOBER FEST 2011 at Gingerman Raceway Sorry I don't post on here much
http://eloquentlytrack.wordpress.com |
10-31-2011, 06:33 PM | #824 |
10-31-2011, 09:47 PM | #825 | |
Turn and Burn! |
10-31-2011, 11:20 PM | #826 | |
The rollcage helped a lot, now it looks better than before, I want to paint all the car now Bought MB Battles 17x9.5, I want to put some direzzas star spec or nitto nt05 245 and 255 in there because of rules (180 min. treadwear) Installed tein camber plates (my tanabe coilovers didn't came with them) just bought a braille 15lbs battery too, peak performance outers and tein inners and got an aligment |
12-10-2011, 05:57 PM | #828 |
Running a 2way on a grip car is just silly. Why on earth would you want your rear tires trying to keep the car going straight as you're entering a turn?! The only reason to run a 2 way is if it's adjustable and you can dial OUT all of the decel lock-up, or if you're drifting and the tires are constantly accelerating at all points in a turn. 2 ways help the drifters initiate, and help with predictability mid drift. If you're not drifting, don't install the 2 way, and don't weld your diff.
12-11-2011, 10:30 AM | #830 |
A 1.5 is hard to say, because the .5 basically means that it is half way trying to make you go straight on decel. So yes, a stock S15 diff would definitely increase your grip on corner entry, but I doubt it would on corner exit.
12-11-2011, 11:23 AM | #831 |
Trader Rating: (24)
Feedback Score: 24 reviews
No, keep your 1.5.
The helical will pegleg at autox and it's annoying. Even if it's not opening up and spinning one tire, it's always transferring power back and forth and it's not 100% predictable. I love helicals, but I much prefer a clutch type for autox because of how consistent they are and how they dig out of corners -- and of course no spinning of the inside tire. |
12-11-2011, 01:59 PM | #832 |
Trader Rating: (58)
1.5 is really the way to fly, and the best compromise of the options. I'd love a true mechanical diff like an Eaton Tru Track, but that isn't happening.
12-11-2011, 08:34 PM | #835 | |
im also planing on covering back to the standard rear bar and adding a diffuser the boot has also be reinforced to transfer the down force to the chassis |
12-14-2011, 08:49 AM | #836 |
Care to show pics of how the lift-gate was re-inforced?
Damn, down under does it HARD!
www.motoredge.wordpress.com |
12-14-2011, 12:33 PM | #837 |
You mean the rear hatch? You don't need to reinforce cause its a piece of metal, but if it was a CF hatch it would need to go to the actual chassis.
I thought STR8E180 was in the US then I would ask where the heck did he get the aluminite! I can't find it.... .unless someone knows.
Turn and Burn! |
12-14-2011, 12:41 PM | #838 |
Wouldn't the additional downforce generated by the wing cause the hatch to flex and not make full use?
I asked because I saw where he said... "the boot has also be reinforced to transfer the down force to the chassis" I love the entire setup on that car except for the front splitter but Function>Form. SR20VET FTW!
12-14-2011, 05:06 PM | #840 | |
Trader Rating: (58)
And FWIW: It's Alumalite Quick Random Google result: Alumalite | Alumalite Panel | Alumalite Sign Board | Laminators Inc.
