#8221 |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
can someone help me with my dcc swap, i just need to wire up my blend door actuator motor. i only have the pigtail. i need to connect it to the main harness, but i dont know where it goes.
edit: alright actually i have a couple question, im trying to save this harness and i dont really want to cop another one. so heres what i have. this is for my S13 by the way. edit: forget it im getting a new uncut harness
REVIEW Last edited by killer240; 10-23-2011 at 08:42 AM.. |
#8222 |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
How many volts should be going to the O2 sensor? On an s13 Sr20. My Powerfc is reading between .46 and .52. That about right?
IG/TikTok-ThatS14_Z06guy |
#8223 |
My steering wheel is slow and weak and doesn't want to center itself around slow corners. I have to correct the steering wheel to get the steering wheel straight again. Is that an alignment (caster) issue?, steering column issue? or rack and pinion issue?
I took this video because I'm not sure if this play here is normal. Is this normal? - YouTube Last edited by Xplat; 10-21-2011 at 10:14 PM.. |
#8224 |
MY PARKING/RUNNING LIGHTS and signals wont turn on. Of course the dash neither because it runs on the same system. I checked the notorious 15 fuse on the fuse box and the rest, none are blown. My signal switch arm i replaced new a while back. Anyone have a solution?
Also after doing my dohc 5speed swap the lights wouldn't turn on until I stepped on the gas and current ran through. |
#8228 |
I talked to a guy from Turbonetics (neglected to mention it's a BB before), and he actually said no restrictor. Which goes against everything I've ever read about BB turbos. And are you sure -8 will be fine? I mean it was what was on there, but he says -10.
#8229 |
![]() Join Date: Oct 2011
s13 headlight problem - YouTube
PLEASE HELP my headlights will pop up with the push of my button but will not go down when i push the button. please watch the video to fully understand |
#8230 |
Which Stage clutch is this?
anyone know what state clutch is Z1 Z32 NA Clutch and Flywheel Combo?
recommend any other clutch kits other than this? pls help ![]() ![]() Z1 NA Clutch & Flywheel Combo thx in advance ![]() |
#8231 | ||
![]() Join Date: Dec 2003
Your brown wire is cut. either reconnect it or go sleepy eye. pop headlights up and the double tap to lower them a little at a time.
![]() **CoUpe LOve** Member #00 |
#8236 |
Trader Rating: (24)
im running the Z32 e-brake setup with Z32 2+0 cables. i have the nut on the hand brake tightened all the way but my handle has to go like 80* up for it to make it work. i dont like it to go up that high, how can i do this? put spacers on the nut? thats the only way i can think of.
#8237 |
![]() Join Date: Mar 2007
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
SR Pressure plate bolts
I'm somewhat in a hurry to put my Trans on and Need to drop my motor in.
Will Class metric 8.8 (grade 5 i think) bolts with lock washers (w/ locktite) torqued to 24ft lbs work for SR pressure plate?? I know its a Question of "best to make it right" and get Grade 8 (class 10.9) but with that Torque Spec on them and Shear strength seems to be do able but If I really need to find Grade 8's I 'll try w/o ordering them.
z-tERty-2 |
#8238 |
just got my 240 the other day, the speedo does not work (needle is past 110, off the chart) but the RPMs do..i know it could be wiring or a sensor at the trans, but how do you fix it..pics or a DIY would be nice
#8240 |
![]() Feedback Score: 11 reviews
![]() Flyin' Miata : Chassis : Stiffening : FM frame rail reinforcement kit Has anyone made these frame rail braces for S13s? I would love to have these.
#8245 |
I mostly want it as speed bump protection and an easy jacking point since my pinch weld is destroyed. I may as well measure out the frame rail on my girl's miata and the rail on mine to see if I could make them work.
#8246 | |
Speed bump protection for frames rails? It hardly does anything and it would be easier to just use aluminum |
#8247 |
I'm going from a clutch fan to efans in my s13, i want to keep a/c. On my fan controller I bought there's a wire that connects to the "a/c override". should I cut the connector off of the old a/c fan and splice in the relay's wire in its place? If so, is it fine to leave the ground from the chassis a/c fan connector not attached to anything?
If I can't do this, where should I connect the a/c override wire from my fan controller? |
#8248 | |
#8249 |
so yesterday was the first time i drove my dual cam ka 240 and i noticed that it has some sort of acceleration problems i think dudes call it either bogging or hesitation
the car also has very high idle
looking to buy ka24de gaguge cluster |
