#7981 |
![]() Join Date: Dec 2004
Trader Rating: (58)
If you've followed the FSM it would lead you to a point where it says to replace certain parts...
#7982 | |
Trader Rating: (58)
If the pinouts are the same, it should.
#7983 |
![]() Join Date: Sep 2008
![]() Feedback Score: 20 reviews
I got ichiba 25mm spacers on front ichiba 5 lugs... i got problem 5 lugs stud are not cover for wheels.. i wonder do i have to cut stud little? if you are not sure what i mean then i will post up picture tmw
#7985 | |
![]() Join Date: Dec 2010
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
![]() Quote:
2nd bump for still wanting a answer. I'm over that little orange light lol it comes on and off. One trip it'll be on, the next it's off |
#7986 |
Quick question regarding auto to manual wiring ka24de on a s13.
I cut the middle connection on the lower harness, crimped them and plugged it into the fusebox plug. (I used the auto sohc harness originally on the car). Result: it sparked as I connected to battery terminal. Now nothing turns on not even dashlights. I checked with a good source and I was told I had to jump the actual plug on the fusebox! Not the harness. How do I do this? Does some one have a picture? |
#7987 | |
he's from cali and deaf so thats why his wording is like that.
#7988 | ||
#7989 | |
![]() Join Date: Apr 2010
![]() Feedback Score: 7 reviews
Zeeeeeeeee32 |
#7990 | |
![]() Join Date: Feb 2006
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
I also removed the exhaust, though I'm not sure if that's entirely necessary. Anywho, after tilting the motor and dropping the exhaust, it took me, my frail female helper, and my floor jack less than 10 minutes to get the trans onto the engine. |
#7993 | |
Trader Rating: (58)
#7994 |
thanks to every one who responded!
i think i might just unbolt the crossmember completely and let the engine drop down 2-3 inches then get some long studs to put in the bottom holes for the bellhousing and guide the transmission onto the engine so it won't break anything |
#7995 |
![]() Join Date: May 2011
Just got all the bushings out of my rear knuckles/arms. Need advice on getting that outer sleeve out without damaging things. I tried the sawzall on one of the knuckle ones, didn't cut even. I got mostly thru it all and it won't budge at all.
#7998 |
^ 2nd'd.
harbor freight has a 20 ton hydraulic press with 2 parallels for $200, $150 with coupon IIRC. if you guys got harbor freights out in MI
Zeeeeeeeee32 |
#7999 |
can anyone tell me if there is any coolant temp sensor that will work for the rb25 s2? The one that goes to the ecu not the temp gauge.
Nothing says racecar like a stock car with no interior. |
#8003 |
Are intake manifolds from the S14 Black top the same as the ones from an S15? im looking to buy an aftermarket one and not really coming up with any options for the S15 help is much apprectiated
Who knew it was a 450hp monster?! ![]() |
#8004 | |
#8005 |
The s14 and s15 intake manis are the same, the only difference in blacktops is the s13 blacktop has shorter runners, and the plenum is above the runners.
#8007 | |
#8008 |
oil temperature and water temp....which would you usually choose to have as a gauge in your car and why?
i tend to see more water temp gauges than oil temp in interior setups...i feel like i'd prefer to go oil temp, but is water temp a more accurate guide to how hot your running or something? wouldnt oil be more accurate so you know the temp of your engine lubricant? |
