#7953 |
^Normal wear from the throw out bearing pressing on the "fingers" or "teeth". If it's wearing through the fingers then you might have a problem with your throw out bearing.
^save up for an SR or turbo the KA. NA KA is a waste of time/money. |
#7954 |
![]() Join Date: Jan 2010
Will an S14 OBDI ecu work in my S13? I have an S14 OBDI motor in the car but it has an S13 intake/dizzy on it. I'm trying to troubleshoot my ignition system
#7955 |
Hey Zilvians!
Quick Noob question, I have a custom 2.5" catback with a 3" straight thru vibrant muffler. Will a 12"x2.5" straight thru vibrant resonator quiet it down significantly? Or what are the effects (ie. tone, rasp)? Thanks. |
#7956 |
Hey Zilvians!
#7957 |
![]() Join Date: Mar 2010
![]() Feedback Score: 14 reviews
The previous owner cut out the wheel wells in my engine bay. I wanted to get those covered up before rain season comes. Is there a way to cover the wheel wells besides getting them welded??? Please lmk asap
#7958 |
Where's the best place to buy a battery from? Mine just died and I want to replace one for a low cost.
I have the battery relocation kit so it shouldnt matter what battery I get?
#7960 | |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
IG/TikTok-ThatS14_Z06guy |
#7962 | |||||
![]() Join Date: Dec 2004
Trader Rating: (58)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() is all I really want to post to most of these questions LOL Quote:
I'llnever understand cheaping out on batteries, brakes, or tires.
#7964 |
![]() Join Date: Dec 2003
People cheap out on
wheels coils brakes multilink Tires steering wheels seats All of which is silly Not to mention unsafe
![]() **CoUpe LOve** Member #00 |
#7965 |
Trader Rating: (58)
My comment wasn't really directed at the modification aspect of things, but in life in general with our shop. If I had a nickle for every customer that said 'get me the cheapest brakes you can, I don't need good ones I'm broke' I'd be a millionaire. Same can be said with tires and batteries. 'Just get me some Triangle brand tires, they'll be fine' and then in 6000 miles they are racing slicks.
#7966 |
LOL
I didnt mean mods specifically either. Yes coils, but after working at a parts store I have seen it in every aspect of car ownership. People would rather buy the most expensive air freshener and cheapest actual car parts.
#7967 |
Does anyone have any experience with a yashio factory intake mani on a s14/15 SR?
OR What you do about the coolant outlet behind the intake mani on s14/15 SR? OR does anyone have info on doing ITB's on a s14/15 SR?
#7969 |
[/QUOTE]It will help, but it's still going to be raspy and sound like crap. Put a muffler on it.[/QUOTE]
thanks for the feedback, i do have a muffler on it. the question was about adding a 12"x2.5" resonator to the combination. sorry, i shouldve been a bit more specific. but will it still get raspy with the resonator and muffler? thanks |
#7972 |
^So the kit can be used on both s13 and s14 racks....the odd shaped bushing is the same for s13 and s14 racks but the diameter of the rack casing is different. S13s casing is slightly larger so it uses the slim bushing.
#7973 | |
![]() Quote:
Do you mean the coolant outlet thats attatched to the head?
Who knew it was a 450hp monster?! ![]() |
#7974 |
im pretty sure its just bolt on but im double checking.
i wanna know if the r4 cam is just bolt on and go. what other parts do i need. any help would be appreciated. thanks |
#7978 | |
i bought a sparco wheel hub. it came with a metal ring. do i need to install the ring in order for the horn to work? i want my horn back cause of dipshit drivers.
#7979 |
can anyone give me some tips on installing a transmission back into the car
we had a hell of a time removing it and i can't imagine it being any easier to go in we have two regular harbor freight jacks someone please tell me how to make my life easier and how to stab this back in without breaking anything |
#7980 | |
Trader Rating: (58)
- Hire a friend (tempt them with reacharounds, hamburgers, or beer) -Loosen the front cross member bolts to the point where it drops the engine a 1/2 to 3/4 an inch (as in, don't fully take the botls out, just leave them one nut length engaged - One person get under the car and lay perpendicular with the car at the front of the trans, the other at the back - Have the 'front man' get the trans up on their chest -Spin the trans almost upside down at this point, and together (with the rear man) get the input shaft up into the pressure plate fingers, and then raise/push the rear up and in. - It may take some jiggling, but get the trans to 'slide into' the pilot bearing, and then once it's in, spin the trans to the top is 'up' and then slide it it 100% onto the engine and into the dowel pins. (If you get it close, you can also use the bolts to help 'pull' it in) I know that may seem barbaric, but the key is having the trans upside down or rotated like, 120* from upright and then get it up in...if you don't you'll fight the trans tunnel. (I'ts 849755% easier to show someone in person LOL)
