09-30-2011, 10:18 AM | #7921 |
You can ship all that via UPS(little more costly) or greyhound or even some LTL trucking companies, Pitt Ohio in Harrisburg off grayson rd. could help you out possibly. That would probably be 35 to start and then whatever weight and fuel surcharge they tack on it. Thats where I used to work, dunno if they will just take it, you'll have to give them a call.
09-30-2011, 10:56 AM | #7922 |
Does anyone have pictures of an s13 hatch with Kouki aero and an aftermarket rear bumper?
Im looking for an instant gentleman rear to be specific. Kouki 180sx Aero thread is too big to search through it..Unless you can provide post#. |
09-30-2011, 02:50 PM | #7923 |
I was burning my bushings out, and I burned out one in the traction rod...the energy suspension rear kit doesn't come with those does it? It only comes with the one for the traction rod in the knuckle?
Edit: I just counted, and since I have aftermarket toe and ruca, I believe I have enough if they will fit in. Which I believe they will. |
09-30-2011, 04:51 PM | #7924 |
My friend recently repaired my HUD cluster, there was a break in the membrane. Anyway, I don't know whether the problem was caused by something he did or if it was already an issue prior to the repair. The problem is that when I give the ignition two clicks my taillights and turn signal lights are lighting up. Any idea on what this issue might be?
09-30-2011, 07:59 PM | #7927 |
09-30-2011, 09:48 PM | #7929 |
what would be the best material to use for an exhaust gasket? I see the MR. Gasket/Percy's stuff, but just curious. The gaskets I need cannot be found, exhaust isn't very common.
street dancer. GLEAM |
10-01-2011, 01:15 AM | #7930 |
AFC #1
The head to manifold? The Mr. Gasket one is very nice and not that expensive. I think I have one around here still. I would not hesitate buying another.
10-01-2011, 01:18 AM | #7931 |
^I needed a special gasket a while back and ended up cutting my own out of some gasket type paper I purchased from Napa for cheap. Not sure if they still sell it but it's worth a shot depending on what kind of gasket you need.
10-01-2011, 08:55 AM | #7932 |
wiring color codes
ive looked through all of the fsm pdf's and scoured the internet for an hour but i cant seem to find a chart with what the wire color are/do. any one have a link or know if it even exist?
89 2tone coupe 2jzgte swap in progress |
10-01-2011, 09:49 AM | #7933 |
Trader Rating: (18)
Feedback Score: 18 reviews
Do s13 mats fit well in a s14? I found a set of dmax locally but they are s13 ones.. Anyone have a photo of what the fit is like?
These are just fronts not rears |
10-01-2011, 05:15 PM | #7934 |
1. I have seen a rebuild guide for a ka oil pump and was just wondering if someone has the part numbers for a sr rebuild or if I'm stuck buying the whole front cover?
2. I am going to be rebuilding my sr and will be wanting about 350hp to the wheels and was wondering if I would be fine with stock rods or should I go to eagle rods? 3. when searching online I saw people having problems with arp main & head studs. for my power goals would either of those be needed or would I be fine with stock? I will be going with an Apexi head gasket if that matters |
10-01-2011, 06:11 PM | #7935 |
Just put some solid motor mounts/ tranny mount in my car. Threw some spacers between the mount to lift the motor some, about a 1/4 inch. Now my car overheats. Im aware that heat rises but I'm not sure if that would have anything to do with it?
10-01-2011, 10:07 PM | #7936 | |
Trader Rating: (18)
Did you mess with any coolant lines or the rad at all? Maybe air bubble in the system |
10-01-2011, 10:47 PM | #7937 | |
im needing if for the sections of the exhaust, like downpipe to mid-piece and mid-piece to axle-back. the shape is really unique its like \( )_( )/ and the ( ) ( ) being exhaust pipes so i have to cut it myself
10-01-2011, 11:03 PM | #7938 |
My engine oil gets dark VERY quickly. Any ideas what's to blame? First I had Mobil 1 5w-30 Fully synthetic. After just 1800miles it was black as tar. Thought it was Oil to blame got my self Motul 15w-50 300V. Check after 600miles - black ooze again.
First I got oil chaged at an honest and good shop, and motul I changed m'self tilting the car in all directions trying to get every last bit of the previous oil out. I used Nissan and bosh oil filters. Compression 9.1 in all cylinders The turbo started burning oil but this started after I discovered the oil condition. <car s14zenki turbo> |
10-02-2011, 08:18 AM | #7941 | |
10-02-2011, 01:39 PM | #7942 | |
Trader Rating: (18)
10-02-2011, 05:19 PM | #7945 |
^ people dont turn yellow...
all clear coat will eventually fade, so its inevitable. The quality will determine how long it will last though I've heard its a hit and miss on Dmax hoods. some fit great, others not so much. BH had one on his s13, it fit pretty decent.
10-02-2011, 05:44 PM | #7946 | |
alright, so my car is having this issue..
s13 with SR, was auto dohc->5speed swap (no previous issues) when I shut off {the motor} and go to remove the key, the key will remain stuck in the ignition, and the button labeled "push" remains locked in place. theres a little tab right under the "push" button, and I found in order to remove the key I need to take a screwdriver or another key and click it up. Then the unlock/push button will operate, and the key will remove like normal. Odd... tried jimming it, messing with Batt. etc, cant really seem to find the problem. searched and found this key stuck in ignition - Page 2 - Nissan 240SX Forums Quote:
thanks in advance. Last edited by towlie; 10-03-2011 at 05:13 PM.. |
10-02-2011, 07:35 PM | #7947 | |
Man w/ CTSV & a Car Seat
2) Stock rods are fine, I'd recommend fresh stock rod bearings. 3) I'd upgrade to ARP headstuds. It's cheap and does a better job that the stock ones. Another thing to look into is, when you upgrade to a Metal HG, make sure your oil pump cover is milled the same level as the block. Almost on all SRs, the front cover is a few mil higher than the block. You slap a metal HG on it and you have issues sealing the #1 cylinder. |
10-02-2011, 07:41 PM | #7948 |
(no spark after fixing other unknown caused problems...)
Ok so long story short.. I swapped a 93 ka24de into my 90 hb, it ran for 3 days..nd I had a blown headgasket ( from day 1, was guaranteed nothing wrong with the motor, nd in a hurry to get my car running so i didnt tear it down nd replace with all new gaskets >I know ,big mistake<..) was smoking from first start up, thought its cuz it was running a little rich.. Anyways.. The 3rd day I was driving nd heard that nasty like metal sound u hear when u know 100% its a blown headgasket nd I parked the car and turned it off..(yes had over heating issues, but literally Mayb drove it 12 miles in all 3 days) Waited a couple hours nd tried to drive it home, but .. PROBLEM: car didn't want to start.. I towed it to My buddy pad with my other buddy gf Saturn nd a rope... Replaced headgasket, re did timing on the whole motor, new I take mani nd exhaust mani gaskets..ETC.. My fuel pump wasnt working so I wired it to a manual switch and works just fine.. Then I noticed my turn signals wouldn't work with key turned to the "on" positon(corners come on witb hazards), I don't know what caused it seeing as they were working fine b4 the blown headgasket..(still haven't fixed it, trying to get car running first) Anyways.. I swapped coils, cleaned dizzy cap nd rotor, checked and am getting power to all the sensors, literally checked all my SP wires ,SP's, coil , dizzy etc.. like 20 times..nd km stilm not getting any spark??;? Any ideas??? I need tk fet my car fixed ASAP..any help b greTly apppreciated, ThNks! |
10-02-2011, 08:08 PM | #7949 |
what is the thread pattern for the bolt on the front sway bar mount for a 93 coupe?
10-02-2011, 08:54 PM | #7950 |
Would I get any noticeable gains from Megan stainless headers and downpipe? I already have a test pipe and Spec II. Don't know if it's worth the money.
GLEAM//★☆Street Dancer☆★ IG: streetdncr // tumblr: steve-strtdncr |
