#751 |
kinda off topic but......
Does anyone have a stock manifold they want to sell? I'll be adding my EWG to it, so if its already done, even better. Also, what are you guys paying to have them smoothed/coated (forget the name of the process, but I know codyace and few others have done it)? Is there any benefit of the stock manifold with EWG over a good tubular manifold with an EWG fabbed/added, other than not having to worry about the manifold cracking? Thanks guys. Trying to get back into this car and get everything finalized. Pretty much down to the manifold/EWG/tune. |
#752 |
![]() Join Date: Jan 2008
![]() Feedback Score: 7 reviews
Hit up Codyace. He usually has some stock cores laying around. He'll weld it up and have it shipped to you in a jiffy!
Sent from my XT907 using Tapatalk
instagrizzle @meadwa |
#754 |
![]() Join Date: Jan 2003
I'm deciding to go with this turbo, but now I'm not sure on the housing. Is it going to creep regardless? Or will the .86 have less of an issue? I don't really want to go external if I don't have to...
TEAM SKIDMARKS Carbon black S13 SR Coupe |
#755 |
Anyone want to chime in? I would think the 67r would spool the same or faster than the 71r. So would that put the .86 67r closer to a 71r .64????
#756 |
Just get the 67 with the .64 housing. You won't be disappointed. And I'm sure if you take the time to read this thread, your answer will be in here somewhere
#757 |
I read the whole thread. Not many people are running a .86. And most are choosing to run an external. Just curious about less creep on a .86
#758 |
Honestly I wouldn't worry too much about creep. So what if you push a little more psi
![]() Sent from my XT907 using Tapatalk
#759 | |
I went from a 64AR to a 73 external wategate housing and lost way too much responsiveness. IMO the 86 makes a 67 or 71 frame turbo spin up way too slow.
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal |
#760 |
I would like to make 360-380whp on pump gas. Probably go with some s3 cams. And stock manifolds. Have a really snappy street car that wouldn't die too much up top. Pretty much codyace's setup minus the greddy IM and external. Man I hate the sound of externals. Lol
#762 |
![]() Join Date: Nov 2008
finally got my blacktop SR all finished and running with a tune. This car will be my daily driver + weekend track car. so, power wasn't really a goal, but overall i'm happy with it!
* some important stuff * -86.5 CP pistons, .20 over bore -DOC Race T28 exhaust mani w/ external vband WG -Tial MVS WG -gtx2867r .64AR w/ COBB Tuning internal WG locker -JWT S3HL cams(272/11.5mm), stock valvetrain except rocker arm stoppers -Apexi headgasket + ARP studs -Power Enterprises 850cc injectors on 92 pump gas -AEM EMS Series 2 ![]() |
#763 |
Does the GT-RS compressor housing make a difference in flow? The only numbers I saw were the pretty low ones a few pages back from an S15 with the housing. I tried to search gt2871r with 2/3bolt housing for comparison but am having problems finding anything.
#764 |
The compressor housing does not make a difference in my experience.
If it was my S15 being referred to, I don't think my numbers are low considering. I am getting pretty much that same peak torque as SFTMB above, I'm running less agressive/duration cams so my torque doesnt hold to the redline, so obviously my power will be a bit lower (power is calculated using torque at a given rpm). I was also having boost controller issues. Of course Dyno's on the ther side of the world will read differently - I would say 10% variance can be expected. All these factors need to be considered before making gross generalisations that some is wrong or not performing. At the end of the day it's only numbers and a dyno graph will not really demonstrate the transient reponse of the turbo while driving etc..... I highly recommend this turbo setup for the street...coming onto boost in second gives my semi slicks a hard time. |
#765 |
![]() Join Date: Feb 2004
SFTMB very nice graph! Can't wait for tax return then its gonna be on. I've already started collecting part, going with the 2867r stock comp housing on my S15 SR with poncams
#766 | |
#767 | |
What figures are those btw? WHP og BHP? I really do se the GT-RS compressor housing to be on of the big restrctions. ID of the OEM comp intake is ca 55mm. This flowes ONLY 54% of what a true 3 inch intake does.... You are able to fabricate a OEM`like 3" intake with basic fabrication skils. Attached 1 picture of 1 oem like full 3" intake. |
#768 |
![]() Join Date: Jun 2010
Compressor inlets were discussed a few pages ago, someone made a good point about how power levels on racecars are limited, with inlet restrictors.
Calling the bolt on compressor housing GT-RS is inaccurate, that is HKS nomenclature for their model of turbo. Garrett refers to that compressor housing as GT28R. |
#769 |
![]() Join Date: Apr 2004
The ID of the GT28R style compressor housing is not the restriction (it's just slightly bigger than the inducer of the compressor wheel). The real problem is that the inlet pipes have a curve with an ID just slightly bigger than this right before it. So you get pretty high losses from trying to curve the airflow at a significant percentage of Mach 1 and I'm sure there's some flow separation there. The inlet/outlet pipes were originally designed around ~170-210 rwhp of flow, so when doubling that it gets to be moderately restrictive.
The T04B cover is probably worth a little bit of power at the >350 rwhp range IMO.
#770 |
And BTW - take 5 mins with a dremel/sanding roll and give a bellmouth inlet on all the Garrett housings like the T04B/T04E housings. The big ole' fat lip and sharp corners is just asking for flow separation at high flow levels. Look at what a velocity stack looks like - replicate that. Don't touch the housing 1/4" from the compressor wheel and back (leave a straight section before the compressor wheel).
#771 | |
#772 |
Well I received my turbo today and some how ordered the gtx2863r on accident. Well after receiving it and doing some research I decided to keep it. It's a huge difference from a a s14 t28 at 16lbs to this at 16lbs creeping to 20-21lbs. I have a basic rs-enthalpy rom tune with z32 maf/denso 550s/rewired walbro fuel pump/forged bottom end and the other usual BPU's and it pulls extremely hard in comparison. Spool up is on par with the stock t28 but from there it carries way harder to redline.
BAD NEWS is it caused my Exedy stage 2 clutch with about 7k miles to start slipping slightly at 4k and above. So I guess i'll drive it till it completely gives and upgrade it in a few months. I think i'll try to loosen the actuator pretension a turn to see if I can get a lb less in boost. I wasn't expecting this much creep though. Plans by July are tomei 260 pon cams, a stronger clutch and possibly bigger injectors along with a rs-enthalpy dyno tune. |
#773 |
The creep issue sounds odd. It seems that the sweet spot for these GT28 turbines is 15-20 psi. More or less boost, an external is better. Do you have a boost controller? Perhaps you have too much preload on the actuator.
As for the Exedy stage 2 slipping, I once read that occurs around 320 lb-ft. |
#774 | |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
usually a little lower when used.
#775 |
![]() Join Date: Nov 2003
So what's the go-to clutch for this power level then? I've lived in the world of the Exedy Stage 2 being the golden child for so long! lol
-Kyle ![]() |
#776 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
This is what I run:
http://www.dxdracingclutches.com/eco...m?item_id=4113 Kevlar disc isn't good for drifting, but it works good for autox and track days and stuff. |
#777 | |
#780 |
Alright guys, I finally got my turbo, wastegate, manifold, and almost all the hardware! Install this weekend!!!
Also, I'm assuming I'm missing some tabs of some sort, or something that actually holds the exhaust housing onto the center section? This is all I got in my Garret Box.... ![]() Edit: Went to a local turbo shop, and found the hardware I needed! Should be good to go for install tomorrow! ![]() Also, when you guys are welding up the flap for the wastegate to run external, do you remove the whole flapper assembly and just weld the flap down? or what?
-Kyle ![]() Last edited by BlackZenkiS14; 03-28-2014 at 11:14 PM.. |
gt2871, gtx, gtx2867r |
